Question about Microwave Ovens
My faema e91 turns on but only reads p0.0 on the display. It won't steam and the espresso part works but isn't hot when it comes out.
Theres a tempature probe on the upper right side of the boiler that tends to go bad, its a brass screw in sensor with two wire sticking out leading back to the board, replace this. also verify correct water pressure, if its not the sensoe then check your elment for continuity. e
Posted on Dec 07, 2010
My microwave shuts off, black no power when ever I cook tv dinners, potatoes etc. after 2.5 or 3 minutes. After 10 minutes or so, power comes back on and it displays PF. lots of steam inside after.
Hi Kerry,
"PF" is power falure if you didn't aready know this. It sounds to me like the coolig fan might be running slow or there is blocked or restricted air flow through the unit. This cooling fan is only for the HV transformer and magnetron. Sometimes you may get air flow around the door but this is incidental. The PF tells me that the power is being interrupted either at the power source (wall outlet or circuit breaker) or the magnetron TCO is cutting out. It also could be a bad magnetron running too hot. As far as the steam goes, I usually just leave the door open on my microwave for 10 or 15 minutes to let the condensation evaporate.
Jun 25, 2015 | Hotpoint RVM1435 Microwave Oven
I have a Bosch steam iron TDS25, and the handle of the iron is getting red hot and water is coming out of the back of the iron. Help!!
Steam irons become clogged from water deposits. You may clean your iron with white vinegar and water. You should use distilled water. Make a Mixture of 1/2 water and 1/2 vinegar, and pour the mixture into the iron as you would when you fill the iron with water. Turn the iron on 'steam' and let the mixture run through. You may need to do this a few times, depending on how clogged the iron is. After cleaning use distilled water to fill the iron, becuase distilled water leaves minimul deposits behind.
May 01, 2014 | Microwave Ovens
Microwave too much steam won't cook
If there is no heat, then it's probably a defective magnetron.
May 08, 2012 | Emerson Microwave Ovens
Touch button won't work
If all buttons don't work then check that connection isn't broke through the I/O board.
If not then board is faulty.
Is you display is lightining or not.
if not then the connction is bad
thanks
please rate my work
Sep 10, 2011 | KitchenAid KHMS155L Microwave Oven
Fan turned on by self, won't turn off
The unit has a temperature sensing device that turns on the fan if it gets too hot...if it is very hot in your house it could turn this on...
If it is not overly hot then the thermistor or the main control board have gone bad and are reading an incorrect temperature...
heatman101
Aug 06, 2011 | Maytag Appliances Over-the-Range Microwave...
I have purchased Faema E98 President from Dubai. I was told that this model works on both single phase and 3 phase. I brought the electrician to fit the single phase but he didn't understand the single...
This may be useful;
http://www.home-barista.com/espresso-machines/electrical-trouble-on-faema-e98-2-president-t6943.html
There is no dificulty with single or 3 phase wiring.
Try a qualified electrician!
Mar 07, 2011 | Microwave Ovens
Ge profile microwave doesn't seem to be heating food real hot. during the last bag of popcorn we tried to pop it never even started popping it, and the microwave stopped and said on the screen...
On GE models, "SENSOR ERROR" appears on the display when:
  • Using the sensor feature, the door was opened before steam could be detected. Do not open the door until stream is sensed and time is shown counting down on the display.
  • Steam was not detected in the maximum amount of time. Use Time Cook to heat for more time.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
Otherwise, your sensor may have failed.
Nov 22, 2008 | Microwave Ovens
Samsung MU3250W Shut down
It could have been steam or humidity.
If this is an over the range model, be sure you always use the hood vent exhaust fan when you're cooking on the stove top.
Whether it's a counter top or over the range top, always be aware that the cooling fan is running when it's cooking.
When in doubt feel for air flow through the vents.
Good luck.
Oct 19, 2008 | Samsung MU3250W Microwave Oven
Microwave Ovens Logo
152 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
