Question about Refrigerators
Fridge seems to be working but freezer is not. Blower is working in freezer but after 3 hours i still don't have any frost in freezer. We had the elc. power shut down in our neighborhood yesterday, would that have something to do with the disfunction of the unit?
    Genius:
  • 1,027 Answers
The power outage should not have affected it - you may be low on freon in the system, and may need a re-charge.
Posted on Jun 19, 2008
Refrigerator is hot but the freezer is cold
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts: http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Jan 12, 2013 | Sub-Zero 650 / O Bottom Freezer...
Freezer blowing air but getting warmer and stopped making ice. Fridg also seems to be warming up. no unusual noise.
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. But if the freezer also gets warmer it can be failure of the auto defrost making the vents choked. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Sep 20, 2011 | Amana ARB8057C Bottom Freezer Refrigerator
Kenmore refrigerator Model 253-68232800 will not keep food cold in fridge and frost build up in freezer.
Top of Form
Sep 14, 2011 | Kenmore 64722 Top Freezer Refrigerator
Belling bk29 fridge freezer. freezer working but fridge not working. compressor running, thermostat set to 5, light working ok, defrost switch off.
Sep 08, 2011 | Refrigerators
FREEZER HAS TOO MUCH FROST AND COOLING, MIDDLE AND LOWER SIDE HAS LESS COOLING WHIRLPOOL 175 MODEL
More freezing on the freezer means there is frosting Now you have observed that the fridge after working for about 24 hours does not cool , check if the fridge cuts off. If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
Aug 24, 2011 | Refrigerators
My LG Refrigarator with a top freezer and water dispenser is frosting on the freezer and the refrigerator is warm
Top of Form
Aug 12, 2011 | LG Refrigerators
KENMORE REFRIGATOR FREEZER THE FREEZER WORKS FINE THE REFRIGATOR IS WARM
Jul 19, 2011 | Kenmore 64802 Top Freezer Refrigerator
The freezer cools half way top, below is warm.
Jul 14, 2011 | GE 14.8 cu. ft. / 419 liter Chest Freezer...
The refrigerator is not cooling properly. We have turned the setting to coldest and it is still too warm. The freezer seems to be working fine.
Top of Form
Jul 08, 2011 | Refrigerators
My son left fridge door open, from 1-2 hours. it doesn't seem to be cooling now. Is there a problem or does it take a while for condensor to come back on?
What has happened is that the evaporator (the cooling coils inside the freezer) have frosted up due to all the moist air which entered the refrig with the door open. This frost has blocked the normal flow of air within the refrigerator/ freezer. Turn unit off, unload freezer, and leave freezer door open for several hours to allow built up frost to melt. Better yet, remove the panel at the back of the freezer and melt the frost off with a hair blower.
Dec 02, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
50 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
