Question about RCA F27664 27" TV
Remote code for f27664 - RCA F27664 27" TV
    Top Expert:
  • RCA Master
  • 75,404 Answers
Hello
I don't know whether you are in need for a four digit of three digit remote code for your RCA tv. Any way I herewith send you four digit remotes codes to try with RCA tv. Check with all the following numbers, and find out which will wake up your Tv. If you wants three digit remote codes ask me later. Ok
0031 0004 0048 0054 0094 0100 0102 0107 0129 0191 0005 0009 0000 0162 0163 0342 0003 0015 0022 0096 0113 0125 0179 0187 0188
Direct Code Entry Proceedings
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
If you are fully locked out inform me about it. Ok.
Posted on Nov 15, 2010
How do i setup an xbox 360 on a rca f27664 tv do i need to change the input settings and if so how do i do this i do not have a remote to go with this tv
You need to select The correct AV input channel! Usually this is done from the remote......if you can do this from the TV Then it will work if not you either get another remote or another TV!
Dec 25, 2014 | RCA F27664 27" TV
Tip
Holding the open/close on the tv and menu button on the remote reset my v-chip!...
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works: Hold down MENU on the remote and VOLUME DOWN on the TV it?s self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
on Apr 09, 2011 | RCA F27664 27" TV
What is the tv code for a RCA F27664 with a uverse remote?
0026,0029,0024,0021. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device brand name list in alphabetical order. Do a search by type in the brand name of your device, at its search box, and press "Enter". Or, pull up older posts.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Jul 21, 2014 | Televison & Video
RCA TV codes: 1000,1003,1004,1005, 1008, 1018, 1049,1065,1066, 1067, 1068, 1069, 1070, 1071, 1082, 1102, 1104, 1106, 1108, 1115, 1151, 1162, 1167,1168, 1268, 1269, 1270, 1271, 1310, 1355, 1359, 1361, 1370, 1373, 1379, 1380, 1381, 1385, 1386
Jul 20, 2014 | Televison & Video
Model number 32v420t. i dont have a remote but the parental lock is on
Hold down the display button for 3 secs it will come off
Apr 23, 2010 | RCA F27664 27" TV
Remote will not work!! Tried numerous new batteries.
If the original RCA remote is being used and not a universal, the remote sensor in the TV has gone bad. This can be a tricky repair and original parts for this set are getting hard to come by. Have a shop check it for you just to make sure. Thanks for using fixya.
Jan 11, 2010 | RCA F27664 27" TV
I forgot the password for unlock the parental control
Jul 20, 2009 | RCA F27664 27" TV
RCA F27664 27" TV Problem: HELP
Intermittent loss of lower frequency channels ie Ch:36, higher channels ok
Dry joints in UHF tuner, resolder the PCB to casing earth connections inside tuner
Channel reception lost if tuner socket moved
Dry joints on IC522, IC521 and IC541 (located in the big heatsink about middle of the main pcb)
Nov 24, 2007 | RCA F27664 27" TV
Parental locks
If the universal remote you're using is an RCA it should work for you. Other brands probably won't. Stargazer
Aug 19, 2007 | RCA F27664 27" TV
TV Clicks on but does not start
sound like you have a bad capacitor in the horizontal deflection circuit check c14406 & c14402. each part is about $10.00. + you local shop rate. good luck.
Jan 30, 2007 | RCA F27664 27" TV
RCA F27664 27" TV Logo
80 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
