Question about Hitachi Deskstar® (H3080A72S) 80 GB SATA Hard Drive
Can't detect my harddrive - Hitachi Deskstar® (H3080A72S) 80 GB SATA Hard Drive
  • Hitachi Master
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to boot
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
problems
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Posted on Nov 15, 2010
Bios no longer detects the harddrive
Is it set to run disc or hard drive 1st?
if reinstalling windows it needs to boot up from cd drive 1st and this will automatic copy to new garden drive, after that change bios to boot up from hard drive.
Jan 14, 2014 | Toshiba Satellite M55-S331 Notebook
Detect a new harddrive
don't worry , just use your install disc and every thing will be ok
Apr 01, 2012 | Averatec Computers & Internet
I have a asus Eee pc notebook,when i turn it on the message REBOOT AND SELECT PROPER BOOT DEVICE appears how do i do that?
check if there is any fashdrive or memory card plugged in. if it shows that message it might mean your pc cant detect a bootable harddrive. was it working before? was it dropped or bumped maybe the harddrive got loose. at the bootup screen do you see your harddrive? if your pc can still detect your harddrive try installing a fresh copy or your operating system. hope this helps.
Aug 24, 2011 | ASUS Eee PC 1000HE Netbook
"disk read error occured". After
This can be indication that your Harddrive is not being detected by the system. You can try loading the defaults in BIOS or re-detect your harddrive automatically. See if it is listed in the boot devices in BIOS. You can also try to check if power is correctly supplied in the harddrive. Open your CPU box, take out the cables (especially the molex) for the harddrive and put them back in firmly.
You can try to use the 32 bit harddrive diagnostic of dell to check if your harddrive is still working or not. Here's a guide: Click Here
Hope this helps.
Aug 05, 2011 | Dell OptiPlex GX260 PC Desktop
Laptop says no operating system found wot do i do as its a samsung notebook
Check if the harddrive is detected in BIOS (Basic Input/Output System) setup by pressing F2..or F12 (depends on what key is designed for the BIOS setup).
- If the harddrive is detected in the BIOS (usually shows the harddrive name or values beside "Drive 0"), your operating system is corrupted. You need an operating system disc to install it.
- If the harddrive is not detected in the BIOS ( no value beside "Drive 0"), either the harddrive cable is loose, the harddrive is not inserted properly or is defective. Check the harddrive compartment at the bottom of the laptop and use screw driver to reveal it. Try to reinsert it or use a good known hard drive.
Hope this helps.
Jun 10, 2011 | Samsung N150 Notebook
Lap top can't find hard drive
Here are some steps that you can try.
- Check if the harddrive is recognized in the BIOS (Basic Input Output System). Normally you will see values beside "Drive 0" at the first page if the harddrive is detected. If it says none or blank, then it is not detected. Reload BIOS default settings and try to boot up the unit to see if it will pick up the harddrive.
- If the harddrive is not detected in the BIOS, you need to unscrew the harddrive compartment at the bottom of the laptop.
- Reinsert the harddrive and check harddrive cable. Also try to use a good known harddrive if yours is defective.
Hope this helps.
May 27, 2011 | Samsung Notebooks 14.1 W P460 Professional...
Hello I have a LENOVO-Y430 laptop, suddenly my laptop stopped functioning, It gets stuck in the STARTUP LENOVO SCREEN, I get two options in the bottom of the screen, press F2 for SETUP & Press F12 for...
Welcome to Fixya
Make sure first that there are no devices plug in to the usb when you boot up the computer. Check if the harddrive is being detected by the computer. Press F2 to go to BIOS menu and see if the computer can detect you harddrive. It should be under the main menu and will say below harddrive. It should give you infromation of the harddrive. If there is no information of the harddrive then the problem there is the harddrive already.
Please reply to this email for any update.
Thank you for using Fixya!
Feb 02, 2011 | Lenovo IdeaPad Y430-3231U Notebook
Tried to install win xp but windows cannot detect harddrive harddrive detected in bios
GOTO BIOS and change your hardisk LEGECY MODE
that is show in advance option
Hope this helppful
Jan 12, 2011 | Computers & Internet
Computer not reading the hard drive
i have formatted the hard drive and put in all three recovery discs and it still won't load windows xp home edition.. i thought that was what the recovery discs were for.. maybe the hard drive is bad i don't know but if someone is having the same problem i could sure use some help here..
May 10, 2008 | Balance CN6555 Notebook
Ibm thinkpad 390
This issue showed that the harddrive is not found. Try to fixed hardware connecting from harddrive and the board.
did you see hard drive detected in the bios at start? if your are sure that the connection cable is firmly fixed and the hard drive still not detected by the bios. so there is a problem with your harddrive. you should/may replace that.On the other hand if in case your hard drive is detected and still thesame problem encountered. then, you should reinstall your operating system by inserting the original operating system recovery/ windows bootable installation disc to refresh the state of your system.
any problem srising this solution please notify me.
Jan 23, 2008 | IBM ThinkPad 390 E Notebook
Hitachi Deskstar® (H3080A72S) 80 GB SATA Hard Drive Logo
35 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
