Question about Bionaire W12-UC Humidifier
Where can I buy replacement water-tank caps for a Bionaire W12? Also, what's the difference between Bionaire W12 and W12-UC?
I just ordered a replacement cap for the w-12 it has a funnel on the end the one i have don't but the man said it will do the same thing. the funnel is for pouring the water in. the website is appliancefactoryparts.com it cost around 28.00 thats including the shipping and handling of 7.99
Posted on Dec 31, 2010
When I turned on my ultrasonic humidiifier it worked for 10 sec, then I observed the water coming through the bottom. When I removed the tank and the bottom full with water. How can I fix this?
Bionaire BWM401 leaking - YouTube
? 0:39
https://www.youtube.com/watch?v=Gy7VKJJeb3o
Jan 20, 2013 - Uploaded by urhorh
My Bionaire BWM401 leaking through the bottom. ... Review ofBionaire Cool Mist Humidifier BCM7932P-CN from Costco HD - Duration: 1:41.
Nov 28, 2015 | Bionaire Humidifiers
The water from my bionaire humidifier keeps leaking well not leaking pouring out of the humidifier base. I checked and no there is no cracks on the water tank and it does not leak from the tank itself. But...
try to check the insulation of your drain pan because of your water came from your unit is cold that create moist on the tank when hit by hot air from sorrounding air apply insulation on the tank.
Mar 27, 2011 | Bionaire Humidifiers
Looking for a manual for BU4000 Ultrasonic Humidifier.
It took much longer than I thought it would but your manual is here:
http://homeappliance.manualsonline.com/manuals/mfg/bionaire/bu4000.html
If it does not come up make sure that you choose the BU4000 only in your search. The BU4000-UC will not bring up the manual.
Thanks for choosing FixYa.
Kelly
Sep 16, 2010 | Bionaire BU4000-UC Humidifier
Need product manual for bwm2600 humidifier - red light is on
http://www.bionaire.com/Manuals/MANUALS/BWM2601-U_43_27612514.PDF
here is the website that you can download the manual if you have any other questions please let us know
Jan 31, 2010 | Bionaire BWM2600-UC Humidifier
Cleaning a Cool Mist BCM6100U Humidifier
usually it calls for one cap full per gallon of water that the unit has. what you do then is that you put the solution in the water then you put the tank back on the base and then you turn the unit on and let the solution run through your unit.
Mar 22, 2009 | Bionaire Cool Mist BCM6100U Humidifier
I have bionaire cleaning product but no directions on how to use
the cleaning product that you have you need to use once cap full per gallon of water. so if it's 5 gallons you need to use 5 cap fulls. so forth and so forth. that is the easiest way to tell you. and then you let the unit run with the solutions and the water for the hole time until the water runs out. and your unit will be cleaned
Mar 22, 2009 | Bionaire Warm Mist BWM0400-U Humidifier
Water tank broken
Hi, I think you can purchase from amazon. take a look here: Maintain Your Home Environment From Anywhere. I hope this helped you. Have a nice day
Mar 20, 2009 | Bionaire Humidifier BCM657U Humidifier
What works best in removing Calcium deposits (I believe)? I've got the BWM2600 filterless and this deposit has hardened on the inside and seems to be slowing down or preventing the vapor from coming...
one thign that you can do is get a solution for any hardware store or any store that sells humidifiers. then you would take 1 cap full of the solutions per gallon of water. and let it run through your unit.. or if you don't want to do that. what you can do is rinse the tank portion out with bleach and rinse really well. get a soft toothbrush and lightly brush off the build up off the coils. if that doesn't work please let me know and i'll see what else i can do.
Jan 04, 2009 | Bionaire BWM2600-UC Humidifier
White dust coming out of humidifier
A concern is minerals in the water. Impeller and ultrasonic designs send these minerals into the air. If the water in your area contains a lot of minerals, you will notice them as dust. The EPA does not issue health warnings about minerals in the air, but does recommend using low-mineral water (such as distilled water) in your humidifier. Many ultrasonic models feature a demineralization cartridge that filters minerals out of the water to prevent the dust.
Good Luck
Apr 05, 2008 | Bionaire BU4000-UC Humidifier
Bionaire BCM630
Remove the water tank from the main unit. Now look down into the unit where the water tank sits. There is a small knob that you need to turn counter clockwise and the lower part of the unit incl the filter will slide out.
Sep 23, 2007 | Bionaire BCM6010 Humidifier
Humidifiers Logo
412 people viewed this question
Top Bionaire Humidifiers Experts
Vernon Taylor
Are you a Bionaire Humidifier Expert? Answer questions, earn points and help others
