Question about Whirlpool Refrigerators
We have a Whirlpool Side by side fridge with water & ice dispensor. It has stopped making ice. We have gone through the troubleshooting guide and even emptied it and turn it off for several hours to see if it had just frozen up, with no success. Do you have any other suggestions before we call a service person? Could it just need the filter changed and if so where can we get one. The model # is WFK-S21. Thanks for your time.
    New Friend:
  • 53 Answers
It could be your optics...or your water valve not getting water to ice maker.. Water filter would affect your water dispenser also if it was clogged..
Hope that helps
Posted on Jul 10, 2017
  • 33 Answers
SOURCE: Amana Side-by-Side Fridge Model SBD21VPSE
If there is a reset button on your ice maker try pushing it. Many ice makers have two holes for reset. A general rule of thumb is if the ice maker fingers are stopped in a slightly vertical position then your ice maker unit is working. If the fingers are stopped anywhere else then it needs some sort of attention or replaced. Make sure there is water, or ice in the ice maker tray, if not then the problem is with water supply.
Posted on Nov 29, 2008
  • 478 Answers
SOURCE: freezer does not make ice
You need to check and see if ice maker has any water init. if not check the fill tube that goes thru the back wall for stoppage while you have it out rin the maker thru a harvest mode and listen for the sounds of the solonoid opening. If tube is full you'll need to replace the slow leaking valve a common problem. for parts call 704-819-6557
Posted on Mar 14, 2009
  • 17 Answers
SOURCE: GE side by side refrigerator: water/ice dispensor
I bought a brand new smartwater replacement filter and after a very short time, my water stopped coming through the door.. took out the new replacement filter and inserted a brand new one .. problem solved.. apparently some of the g.e. smartwater filter replacement cartridges don't have the high enough two plastic inserts which are attached to them at the top of the filter when you screw them on... if you have taken your cartridge in and out a few times, i think it wears down the plastic so it doesn't fit properly and won't put up whatever it is supposed to push up to make the water come through.. I personally think this is a g.e. problem with the replacement filters...
Posted on Mar 16, 2009
  • 744 Answers
SOURCE: my water dispenser suddenly has stopped working.
Yes, it could be the water filter. Also check to make sure the water is turned on and that any lines to the refrigerator aren't kinked or crushed somewhere. It's also possible that you will not be making any ice as well if your appliance has an ice maker
Posted on Apr 06, 2009
SOURCE: GE Eterna side by side fridge Model ESS2SLGMAWW
I've got the same problem...have de-thawed everything, (this was how we fixed it before) and still can't get water to dispense. Guess another 75 bucks service call...urgggg...
Posted on Feb 15, 2011
I have a whirlpool side by side fridge with water dispensor and ice maker. The light is on that the filter needs replacing but I can't find it. Where is the filter located?
For most side by side refrigerators, the filter is in the grill at the bottom in the center (approximately) of the freezer side. Just push in on the cover over the filter (it is a circular piece).
For exact information, you need to provide the model. Many Whirlpool appliance manuals are available here: . Type in the model in the Manuals & Literature box.
I hope this helps.
Feb 14, 2011 | Whirlpool Refrigerators
first thing to check is that you have water going on the inside of the ice maker tray simply stick your finger inside and see if there is water if there is no water you would then look at the water valve or the line in the back of your fridge if there is water or rather there is ice inside the tray you would want to remove the ice maker and run the tray under hot water then reinstall to test if this does not work then replace the ice maker hope this helps
Jul 25, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge makes a clicking sound, stops if lever for ice/water press
this model has a p c control in the back and the clicking sound is common when its failing . Pt # wr55x10656 ) there is a up date kit for this frig . ck on the kit before replacing the board as its included in the kit . hope this helped ****
Jan 04, 2010 | Hotpoint HSS25GFP Side by Side...
My ice maker stopped making ice all the sudden. there is no water in the ice maker
do you have a water dispensor in the door? if you aren't getting water check the filter. if the water line is not clogged you may have a bad water fill valve or the motor/gear in the ice maker is bad.
Sep 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Doors got to hot
Check the warrenty on fridge . Usually you have a 5 year warrenty on the compressor AND sealed system ( parts and labor ) . However , a service call charge may apply . Also check to see if something got sucked into the compressor cooling fan blade causing the noise , after you cleaned the coils .
From the description about dispensor leaking and ice getting stuck , sounds like the water valve needs to be replaced . Small ice cubes ( from not enough water ) will get caught between the rake and fingers . A leaking water dispensor , usually indicates that the water solenoid is not closing completely when letting off the water dispensor arm . Both solenoids come togather as the water valve ( located where the wall waterline connects to refrig ) .
Aug 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Need to unplug fridge- Whirlpool Gold Side-by-Side
you will have at least a foot of flexable water hose. Pull it out slowly to make sure its not tangled.
Jan 05, 2009 | Whirlpool GD5SHAX Side by Side...
Ice dispenser motor not working
try removing the ice bin from unit, try using dispensor now, can you hear it turning now??? if so empty your ice bucket possible frozen water on bottom of bucket preventing auger from turning
Feb 25, 2008 | Whirlpool GS6NBEXR Side by Side...
Our fridge does not make ice - Whirlpool Gold side-by-side GS5SHAXNT00
Same as others. Whirlpool Gold side-by-side. Water was running yesterday but minimal ice. Now that's gone and I don't even hear the water. Turned on/off the infrared sensor. Still get drinking water, just no ice in the bin. There's a couple cubes in the maker itself when I open the door (which I've closed completely). Help?
Dec 02, 2007 | Refrigerators
Refrigerators Logo
61 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
