Question about Horizon AFG 3.0 AT Treadmill
Making a loud whirring noise when running. - Horizon AFG 3.0 AT Treadmill
  • 42 Answers
Hi i think that the running belt is too loose and touching the underbody of the treadmill, if you can have a look underneath.
Posted on Nov 16, 2010
Dryer makes loud whirring noise when try turn on, won't start
I am guessing that it does not do anything after it makes the noise?. If you hear something running after the whirring noise, but the drum is not turning it is possible the belt has broken or slipped off the motor pully. If you hear no noise after the first startup and it completely stops making any sounds then it may be a motor problem. I am no pro, just a do it yourselfer. www.repairclinic.com can help ya more than me. Just have the model number ready when you go there and look at the symptoms. Hope this helps.
Oct 11, 2014 | Dryers
Wine Enthusiast Silent Wine Refrigerator is making a loud buzzing/whirring noise.
Since this unit doesn't use a compressor, the only moving parts are the whisper fans inside of it that circulate the air. One of those fans may be going bad. If you are handy you can remove the back to see if all the fans are working but your best bet is to use the one year warranty and have a qualified techncian figure it out.
Jan 07, 2014 | Refrigerators
Washing Machine making a loud whirring noise when water is filling and when the machine is spinning out
Check the motor bearings If your washing machine is making a high-pitched whine or squealing noise while running, the main culprit is usually worn motor bearings. To check the motor bearings, remove the belt and run the motor by itself, listening for the noise. If it makes the noise, than the problem is most likely the result of worn motor bearings and has nothing to do with issues in the rest of the washer. Check for Obstructions Sometimes coins, bra underwires and other metal objects come loose in the wash and become stuck between the tub and the drum. Using a flashlight, take a good look inside the washing machine. If you see dents, scratches or dings, that's a sign that there either are or have been items bouncing around in there that can make a horrible racket. Check for Grease Spatter A high-pitched squealing can be caused when the grease thins around the bearing that's located under the tub. Open up the washing machine and check the interior for grease spatters or spots. That could mean that the grease has thinned out around the bearing and it's making the noise because of rubbing. Check the Drum for Irregularities Spin the drum by hand, listening for the noise. If it makes the noise in the same spot with each rotation, the problem could be with the washing machine drum itself. Parts of the drum can corrode over time, leaving it vulnerable to cracks or rust.
Aug 06, 2012 | Washing Machines
My Dyson is making a really strange loud sound. It appears to be working. I just took it apart and cleaned the filter and the wand. When I put everything back together, it started making a heavy whirring...
Check the tips of the beater bar. I "bumped" mine to hard and broke a tip. Still worked! Just noisy. Called Dyson support and they sent me a new one no charge. Note. Mine had a loud whirring and a vibration.
Jan 30, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
The dryer is making loud noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
er789
Jun 05, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My samsung 42 inch hdtv is making a buzzing noise
First. The whirring or buzzing sound you hear is the Color Wheel and it needs to be replaced. Second, since I do not know when and if the original lamp has been replaced it is a good idea to replaced the lamp. The bad Color Wheel is the one causing the set to shut down.
Apr 04, 2010 | Samsung HL-R4266W 42" HDTV-Ready...
Toshiba Portege r200 is making whirring noises
Its problem two things. One, the fan on the heat sink or your hard drive. More than likely your hard drive.
Feb 06, 2010 | Toshiba Portege R200 Notebook
Ice behind panel in refrigerator and loud whirring noise from refrigerator. also periodically leaks water onto the floor
IF STILL RUNNING OK, MAKING ICE ? ETC ITS PROBABLY THE CONDENSATE DRAIN OUTLET EITHER FROZEN OR PLUGGED ALLOWING CONDENSATE TO FREEZE THUS PLUG
Aug 23, 2009 | Samsung Refrigerators
Loud whirring noise at start-up
The first thing to check would be to make sure the power steering reservoir is not running near empty, locate the filler cap for the power steering pump it should be marked and then add the appropriate amount making sure you don't over fill, that may make the sound go away if not we must move on to the next possibility, by the way if the noise gets louder when you turn the steering wheel it is most likely the power steering pump or fluid level is low.
Jul 14, 2009 | 1998 Mitsubishi Galant
Intermittent Loud Whirring Noise
sounds like the evaputaor fan motor.. may need to replace.. check to see if anything maybe hitting fan blades
Sep 30, 2007 | Frigidaire FRS23R4A Side by Side...
Horizon AFG  3.0 AT Treadmill Logo
245 people viewed this question
Top Horizon Exercise & Fitness Experts
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
