Question about Samsung DV448AEE Electric Dryer
My Samsung steam dryer (model DV448AEW/XAA) has stopped heating. Everything else is working fine, Is there a user accessible fuse for the heating element or is there a diagnostic it can run to let me know what the problem is.
This is for the ELECTRIC MODEL Only. I have the DV448AEPl and had the same problem... I cleaned all of the lint from every nook and cranny and ordered a "repair kit" from Sears (http://www.searspartsdirect.com/partsdirect/part-model/Samsung-Parts/Dryer-Parts/Model-DV448AEPXAA/1482/0151200?searchedModel=dv448&blt=) there is even a blow up of the parts there - I ordered part numbers , DC47-00015A, thermostat, DC47-00018A - thermostat and DC47-00019A - dryer heater. The heater is relatively easy to get to if your not squeamish about removing some screws and taking the front off the dryer. Once the front is off you can clean even more lint from the dryer. Remove the heater unit by unscrewing the single screw accessed from the front of the dryer and then disconnecting all of the connectors.
Lastly - once I took the heater assembly out I found that a dime had made its way into the heater coil and was shorting it out... Probably could have got by by just removing the dime and cleaning the coil but I figured that since I was elbow deep in the thing I might as well clean it all up and install the new parts.... Cost of parts was about $80.00 w/shipping. Cost of a repairman to knock on my door here is $150 so I came out ahead on this one... Good luck.
Posted on Dec 08, 2010
Samsung elec dryer, Model dv5451aew xaa 01. Drum not spinning. Belt ok. Dr Sw ok. Changed both fuses on heating element. Nothing.
Samsung dryer won't spin, belt is fine - Fixya
www.fixya.com/support/t8946132-samsung_dryer_won_39_t_spin_belt
Apr 14, 2011 - Question about Samsung DV218AEW Electric Dryer. 2 Answers ....Samsung dv410aer/xaa motor hums but drum will not spin. Mar 21, 2014 ...
How to Fix a Samsung Dryer: the Drum Won't Spin
www.ehow.com > Home
From time to time a dryer's drum can fail either by jamming up, a technical error ...Support US Samsung: The Dryer Drum Does Not Spin · Repair2000: How to .
Oct 16, 2015 | Samsung Dryers
Does Samsung DV448AEW/XAA dryer have a reset switch ?
If it over heated most dryers use thermal fuses. They must be replaced if they have blown. Samsung is one of the most difficult that I have seen.
samsung dryer not heating YouTube
Searching Model For Search Your Way DV448AEW 4
SEARCH SAMSUNG
Oct 10, 2014 | Dryers
Dryer does not dry. Wont heat up.
I am directing you to Repair Clinic.com as that will help you diagnose the issue that you are having as there isn't enough info for me to get specific info for you!
The link is; http://www.repairclinic.com/Shop-For-Parts/a8b160d1420640-x73616d73756e67206476353437316165702f786161/Samsung-Dv5471aep-Xaa-Model-DV5471AEPXAA-Samsung-Dryer-Parts
Good Luck!
Rich Lilja
Oct 06, 2014 | Samsung DV5471AEP/XAA 7.4 cu. ft. Capacity...
Samsung dryer over dries
Sounds like the thermostat sensing tube did not get placed back in it's original position.
Oct 01, 2014 | Samsung DV448AEW 7.4 Cu. Ft. Electric...
Dryer heats for maybe 1 minute then stops. Samsung Model DV328AGW/XAA
In the rear of the dryer is a thermal limiter which will kick in when the exhaust temp is too high and can cause a fire. One link will show what the limiter looks like and the other will show how to commonly get to the limiter. Your mileage may vary.
Samsung Dryer Model DV328AGW XAA Fuse Thermal Fuse Breaker Parts Take Apart Samsung Dryer Samsung Dryer Repair Help
Jul 30, 2014 | Dryers
Samsung dryer won't turn off
Do you habe wrinkle guard turned on. If so try turning off the option. If not the timeing sirsuit on the control board is faulty.
Jan 29, 2014 | Samsung DV5471AEP/XAA 7.4 cu. ft. Capacity...
How do i fix a belt that slipped off my samsung dryer model number dv448aew/xaa ?
There is a tensioner in the pulley that should keep the belt from slipping off.n most cases they work very well at keeping the belt tight.In your case the belt may be stretched too much ,I would check it and replace it if necessary
Mar 07, 2010 | Samsung DV448AEE Electric Dryer
The dryer drum stopped turning.what could be wrong?
That is most likely a broken belt.
I have repair photos HERE
Feb 15, 2010 | Dryers
Samsung DV448AEE Electric Dryer Logo
4,190 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
