Question about Garden
17.5hp single cylinder B&S intek, recent engine swap. After swap engine ran fine for about 20 minutes, then quit, unable to restart. Have since replaced the fuel filter, air filter, spark plug, has compression of 90si, replaced head gasket, valves adjusted to .003 for int and .005 exh, has fresh battery and gas, and is getting both fuel and spark. Was able to get it started but it only idles, moving throttle cable has no response and manually moving throttle gets no response, governor does not seem to move? Any suggestions? Thanks.
  • 78 Answers
SOURCE: craftsman riding lawnmower shuts off after 15 - 20 mins.
I have a Troy-Bilt push mower that does the same.
Try this - Run the mower until the point of quitting. Keep the hood up and be ready to remove the gas cap. As soon as you feel it start to stutter like it's going to quit, unscrew the gas cap and see if it comes back to life and doesn't quit.
If that works, then what is happening is that the gas in the carburetor bowl is getting depleted faster than the tank can provide it, possibly because of a clogged vent that's supposed to allow air back into the gas tank as gas is used.
You can try running with the gas cap not quite tight, to let some air seep in that way, but that's more prone to sloshing leaks. You could also try drilling a hole in the gas cap - about 3/16" is plenty, and stuffing a piece of natural sponge in to keep the gas in and dirt out. Synthetic sponge will deteriorate in gas.
Posted on Jun 09, 2009
smartr10U
  • 1305 Answers
SOURCE: Craftsman mower with 20hp B&S Intek won't start/run
That throttle cable issue sounds like it may be the culprit. the cable housing (the outer casing for the wire throttle cable) may not be anchored correctly. Which may be allowing you to move the throttle without any change at the butterfly control on the carb. make sure the cable housing is anchored at both ends.. by the throttle control and at the carb area.. That may be your problem... hope it is that simple...
K
Posted on Jul 23, 2009
SOURCE: Popping out exhaust, loss of power, wont run at full throttle.
I had the same problem. If it is a 2 cylinder, remove the valve covers. On one side, the rocker arm had slipped off of the push rod. It was real loose. Put the rocker arm back on the push rod and tighten it down. I think this will do the trick.
Posted on Sep 01, 2009
backwoodsctr
  • 169 Answers
SOURCE: DLT 3000 Intek 18.5 Carb Float Stuck?
If it starts cold and runs for 10 min then it sounds like the fuel cap is not venting properly, try runnin engine with fuel cap loose and see if it dies. 9 times out of 10 the fuel cap is the culprit. Let me know
Posted on Nov 30, 2009
ginko
  • 19396 Answers
SOURCE: Husqvarna riding mower w/20 hp
Hi.
There is gas smell in the carburetor because the engine is not starting and carburetor is flooding.
As first thing ensure that there is spark, pull the spark plug wire and put the end near to engine block while cranking. You will see the spark. If there is no spark, check distribution coil and wires.
If there is spark, check if there is fuel pressure, if there is smell from carb, then the fuel pressure should be Ok.
Once you are sure that the pump is doing its job, and that there is pressure, check the carburetor settings. The mixture is probably too rich or too lean, and for that reason it is not igniting.
If it is not a matter of carburetor settings, then the carb must be taken apart to check carburetor filter.
To get parts and diagrams see: Outdoor Distributors - Lawn Mower Parts
Posted on Sep 26, 2010
What is the compression lbs for a 18 hp brigg/stratton intek engine
Not sure where to get compression pounds for this, but let me refer you to the Briggs website for detailed product specs and power curves.
Intek can be twin or single sylinder.
For Twin....
http://www.briggsandstratton.com/us/en/engines/rider-mower-engines/intek-series-v-twin
For single....the are in 1/2 HP ratings but the link is below....
http://www.briggsandstratton.com/us/en/engines/rider-mower-engines/intek-with-xrd-single-cylinder
If further detail is required, I will need the model type and trim found on the valve cover.
Aug 18, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
20 hp intek v twin one side is over carbureting .how do I correct this
have you checked your oil if the gas ran into your oil it will come out one cylinder before the other
Sep 19, 2012 | Briggs & Stratton Briggs Stratton Intek V...
2002 mercury grand marquis wont start when engine at normal temperature must wait 15-20 minutes
I have exactly the same problem started last winter, ran fine all summer then as soon as it got below freezing again if I start it and run for 15 20 minutes wont restart I have to let it sit for 20 minutes or so and then it will start again. no codes and just turns over without starting. cant be fuel pump like i said had this problem last winter then ran fine all spring summer and fall! Anybody got the answer for this one??
Mar 09, 2012 | 2002 Mercury Grand Marquis
The engine on my 2000 MPV cuts out and dies when I press the accelerator. After it sits for an hour or so, I can travel for 20 min. or so before the problem starts again. HELP!
if its been a while change the fuel filter and then have the fuel pressure and volume checked.these symptoms are very common for a fuel pump problem.
Feb 07, 2012 | 2000 Mazda MPV
Riding mower won't start
take the spark plug out and see if the engine will turn over then, gas will probably come out of the cylinder cause you flooded it when you turned it over after you get the gas out of the cylinder, put the cleaned spark plug back in and it should start
Jun 03, 2010 | Garden
17HP Briggs Intek engine ran good then quit. Now
Intake and exhaust valves need adjustment. Intake .004, exhaust .012.
look for wear or loose rocker arm bolt before adjusting valves.
Nov 22, 2009 | Briggs & Stratton Garden
I recently installed a fuel pump on a 1993 cadillac deville. i also changed the filter,emission control,plugs and wires. it fired up and ran for about 14 minutes. it ran very sluggishly then quit. i have...
was it the correct fuel pump with the propper psi?
have you checked you wires to make sure none got crossed. are the spark plugs propperly gapped?
Mar 07, 2009 | 1993 Cadillac DeVille
Stalls / Dies / dead
this engine fuel pump prassurae low. it fuel pump celan. Your problem sovel
Jul 13, 2008 | 2003 Ford E150
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
