Question about LG Refrigerators
Need door handle replacement for model GR - 602 TVF
Door handle broken. I want to find a replacement handle without replacing entire door.
The door handle can easily be replaced on MOST microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle (if required) usually runs about $20 - $40. Replacements may be purchased at the websites listed in the link I provided. Several of these sites also have helpful exploded view parts illustrations to assist you with parts identification and how disasemble/reassemble your appliance.
NOTE: I would need a MODEL NUMBER in order to determine if your appliance repair parts list the door as an entire assembly, or if you can purchase the handle separately. You can also view the websites I have listed in the link provided.
The door handle is a simple repair that can be done with the door in place, or with the door removed. You do not have to uninstall the oven if this is an over the range model.
NOTE: If you wish to remove the door, all you need to do on most models is open the door all the way and lift straight up at the hinges. You may have to remove the grille cover located above the door on some models to accommodate being able to lift the door.
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
May 05, 2011 | Microwave Ovens
2000 pont. gr am pass door only opens when you use door key to unlock and pull handle at same time , the door lock are auto. you can hear it unlock but cant open it normally
there has been lots of problems with the power door lock actulator on this model . you will need to remove the door pannel and then remove the door lock latch assembly and inspect to see if the actulator is broke . If it is broke then you will need to replace the latch assembly as i dont belive that the actulator comes seperate from the latch . but check with your local parts store or dealer
Mar 04, 2011 | Pontiac Grand Am Cars & Trucks
Door handle has broken loose at bottom of handle and needs to be replaced. How can this be accomplished?
If you have any questions, please post back and let me know. I hope this helps you.
Nov 10, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Door Handle broke off on a 20 year old GE spacemaker microwave over oven. It still works well and I would like to fix the broken door handle.
Oct 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Replace door handle
Aug 23, 2010 | General Electric Advantium 120 Microwave...
How do you take the door off? I too have a broken handle and door...
If only the door handle is broken, it can easily be replaced on MOST microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
The average cost for a replacement handle usually runs about $20 - $40. Replacements may be purchased at the websites listed in the link I provided.
The door handle on this model has two parts (items 3 and 8). Depending on what is broken, you may only need to order one or the other. Both parts, combined, is still only about $20. The part numbers are WB15X10119 and WB15X10120, respectively.
Jul 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
1992 dodge Gr. caravan side door won't open
Probably needs a handle or latch,both have cheap plastic retainers & the latches are a common issue.
Jul 22, 2009 | 1992 Dodge Grand Caravan
My LG GR-602 TVPF fridge needs the freezer door replacing.
I have been billed for your service when I was told I would not be as your service was of no assistance to me.
Oct 08, 2008 | Refrigerators
Refrigerators Logo
203 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
