Our washer was running. It stopped and started flasing the letters LE. I do not know what they mean. Any thoughts?
  • 31 Answers
What brand/model #?
Posted on Nov 15, 2010
  • gvince4
    gvince4 Nov 15, 2010
    I found out It's an LG.
    The LE error code stands for “Locked Motor Error.” In the LG washer, the LE error code is usually caused by the burned out hall effect sensor.
Drum not spinning, seems to be stuck
LE error means "Motor Error" that your machine's motor is faulty and needs to be replaced.
Dec 22, 2013 | LG WM-1832C Front Load Washer
Lg front loading washer flasing LE and stops midcycle
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
OVER SUDDSING
Jun 16, 2012 | LG WM-2277HW Front Load Washer
Drum starts to move then stops then Le appears and a slight hissing noise from direct drive motor. Looks like intemittant fault
The LE error message means "locked motor error" which means the control is not seeing the motor running.
The problem can be caused by a broken wire or loose connection but the most likely cause of the problem is a bad hall sensor.
The sensor can be accessed by removing the rear panel and the rotor assembly. See the image below for help with this. Remember to unplug the washer first.
Make sure the rotor and drum rotate. Anything blocking the tub rotation might trigger an LE code.
Aug 11, 2011 | LG WD-1080FD Front Load Washer
The washer is saying LE what does this mean. I had it on delicate cycle and now there is water in the machine and it needs to spin out. Help.
Apparently "LE" can mean a million different things - everything from "your drain motor is burned out" to "your drain filter is clogged" to "you used too much soap". I have found that usually it is the latter. I gather that what "LE" really means is that the drain flow rate is not high enough. Here's the quick fix that you hope will work, and that has always worked for me (knock on wood):
1. Get a 5-gallon bucket (or a little less)
2. Open the little door on the bottom left of the front (pry it open with a quarter, like it says in the owner's manual)
3. There is a drain hose with a plug in it. Pull out the plug and let the water drain into the bucket
4. There is a gross trap/filter in that same door. After draining, unscrew that filter, remove and clean out, then screw it back in place.
5. Replace the plug in the drain hose, and close the door back.
6. Try running the washer again, but don't add any soap. If it was the filter that was clogged, the washer will run to completion, everything is fixed, and you can start your free happy dance.
7. If it stops again and gives the "LE" again (likely), then drain the water into the bucket again, replace the plug, and start the washer at the beginning again without adding any soap. Usually by the third time I do this, the washer will run to completion and I can commence the free happy dance, followed by the gentle reminder to my lovely spouse not to use too much soap, that the washer actually cleans better with the right amount of soap, even on those extra dirty clothes.
Hope this helps!
Feb 21, 2011 | LG WM-2277HW Front Load Washer
Error code is LE. Washer fills up with water and
If water runs in when the machine is OFF but stops when the tap is turned off it means a faulty watervalve.replace water valve. Probably a double valve. Dont mix up the hoses or the wires........Nomess
Apr 18, 2010 | LG WM1812C Front Load Washer
Washer won't run display flases LE
You have a bad hall sensor(tach) it plugs onto the bottom of the motor after removing the back cover. Use a 10 mm socket to loosen the motor unplug the old hall sensor plug the new one in and reverse what you did. If this does not work, you have a bad motor which is warrantied for 7 years.
Jan 21, 2010 | LG WM-2077C Front Load Washer
My washer say LG what dose that mean
My washer stopped and displayed the LE error code. I turned off the power button and tried again, but after a few seconds it want back to LE. Finally, I unplugged the power cord, plugged it back in, and the washer ran normally.
Dec 21, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Washer / WM2487H*MA...2 days old. Wash setting...."Bulky/Large QUESTION:::When attempting to select additional "wash options" from the Option Buttons panel, I keep getting a display...
My LG Tromm washing machine just stopped in the middle of the cycle, It started flashing the letters LE, what does that mean. I have had it for 4 years and this has never happened.
Jul 27, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
