My machine type is dlp3001 - Digital Mobile Olympia Projector Random drive disappeared, unable to connect projectors, please help me find this model of software? Software download url can also.Thank you very much!
SOURCE: sanyo pro xtrax
I am not understand the exact problem.
Can you pls explain briefly about your problem?
Posted on Dec 24, 2007
leroyal
  • 2120 Answers
SOURCE: I am a librarian in
Probably just a burned out bulb. Look in your Yellow Pages for a Minolta Dealer or Google...Minolta MTP101 bulb / lamp.
Posted on Sep 10, 2008
SOURCE: projector can't connect to laptop
We just solved a similar issue. Most likely your PC or laptop is currently set to a display resolution that is too high for the projector or is one that it cannot handle. Try setting your computer display to 640 x 480 or 800 x 600 and see if you can get the projector to work. If it does, then you can figure out the maximum display resolution you can use. Also consult your projector documentation for supported resolution modes.
For the PICO in particular, it looks like those are in general for small mobile devices (320 x 240 or less displays), and the PK102 model has native VGA (640 x 480) support with extended support for 800 x 600. You will not be able to use this on most modern computers except at the lowest resolution setting for the PC.
Posted on Oct 16, 2009
SAFFOTO
  • 77 Answers
SOURCE: aries digital camera model # atc-0017: can not
Look here:
http://www.bioticaindia.com/atc-0017.html
(You may have to register but it's free)
Posted on Feb 03, 2010
SOURCE: HOW TO CONNECT MY PROJECTOR TO MY LAPTOP?
I have hp laptop with hdmi & vga, sharper image projector with rca connector what do I need to connect these two
Posted on Jun 23, 2010
Am using emachine N270. Am unable to connect it to projector. please help me...
Your netbook may not have adequate graphics capabilities for the projector and you will need to include the projector's model number for a definitive answer.
Mar 26, 2015 | Computers & Internet
Denon avr-1312 receiver and mitsubishi hc3000 projector - Video keeps dropping out
Hi, it could be a number of things, go to your browser type in the model followed by support, look at there info, is there enough life in the bulb? if it were mine i would clean the shutter and go on from there but try that what i have said example >>.denon avr-1312 support << hope this helps :)
Nov 30, 2013 | Mitsubishi HC3000U Multimedia Projector
I am trying to connect my projector to my laptop. Can you help me with the cable sequence? I have red, green, and blue cables to connect with red, yellow, and white on the projector. So far nothing is...
You need the correct lead.
You need a vga lead to an rgb lead.
have a look at pins and connector types on computer and projector.
maybe somewhere like radio shack will sell correct lead.
Please dont forget to vote this answer was helpful
Many thanks
Feb 18, 2011 | Sharper Image 1617293 Projector
Hi im tony i have a benq mp610 projector and i cant find the battery for the memory where do i locate it
Well there is no battery for any kind of memory in the projector, there is only a remote battery.......
For which purpose you need to find battery for memory?
If you like to reset your projector then go to main menu>>settings>>reset it helps you to reset your projector and returns all settings to the factory preset values. The following settings will still remain: Mirror, Language, Password, High Altitude Mode, Phase and H Position.
Do not reset if the lamp is not replaced as this could cause damage.
i. Press and hold the Exit ^ button on the
projector for 5 seconds to display the total used
lamp time.
ii. Press Auto on the projector or on the remote
control to reset the lamp hour to “0”.
iii. Wait about 5 seconds to let the OSD disappear.
Please post comments for more help or information......
Good Luck!!
Thanks
Mar 22, 2010 | Office Equipment & Supplies
When we r trying to connect the dell DLP front projector 1800MP model to dell latitude D830 laptop, unable to connect as nothing displaying the projector. please help me out with the solution
May need to hit Function+F8. This is Dell's standard button for pushing video out different sources, such as the VGA / DVI connectors in the back of your machine. You may also want to start with a "standard" screen resolution, such as 1280x1024 to make sure the projector can handle it.
-J
Oct 21, 2009 | Computers & Internet
PC expands and shrinks text/images when connected to projector
the resolution doesn't match. go into the menu on the projector and select auto image. this should clear up the resolution prob.
Jun 24, 2009 | InFocus LP 425 Multimedia Projector
Connecting Macbook with a compaq MP1400 digital projector
You're going to need a conversion dongle that goes from the Mini-DVI to VGA.
Then:
  1. Connect one end of the projector signal cable to the Video Graphics Array (VGA) connector on the projector.
  2. Connect the other end of the projector signal cable to the Digital Video Interface (DVI) connector or VGA connector on the notebook computer and tighten the screws.
  3. Connect the projector power cord to the power cord connector on the projector.
  4. Connect the other end of the power cord to an electrical outlet that is easily accessible and close to the projector.
  5. Turn on the projector first, then turn on the computer.
Nov 09, 2008 | Computers & Internet
Unable to Connect DV10
Hello!
Which are laptops? I use IBM R40e and HP laptop and I usually connect them with DV10 for conferrence. It's well! I have just a problem with Asus EEE. It unable connetc with DV10. I try use Video jack to connect. Result: It can display but the quality is very bad. Now I try to find another way to connect them together. Some information to share with you. Thanks you!
May 03, 2008 | Optoma MovieTime DV10 Multimedia Projector
White vertical line in the center of projected image
I have a Dell 2400MP projector that had the same problem of vertical white lines appearing over the screen.
This may seem like a simple solution, and I don't know if this will work for you, but the way I solved the problem was simply to press the bottom side of the projector, until the white lines disappear . Until now, the problem has yet to resurface.
Here's some simple steps:
1. Turn on projector
2. Connect projector to computer
3. Focus projector
4. If white vertical line appears, firmly press underside body of projector
5. See if vertical white line disappears
6. If not, try slowly pressing other parts of the body of the projector and see if white lines disappear.
7. If solution doesn't work, you may need to send it to the service center.
Hope this solution works for you.
Best Regards,
Ghazali Ridzwan
http://www.ghazaliridzwan.com
Nov 28, 2007 | ASK Proxima Proxima DP2000S Data Video...
210 people viewed this question
k24674
jasbo
jasbo
