Question about Emerson LC195EM9 19 in. LCD TV
Power inverter board didnot solve the problem. when the power button is pushed the green light comes on for just a sec and then reverts back to the red standby light. Have already tried leaving the thing unplugged. Have replace the inverter board.
  • Emerson Master
  • 8,457 Answers
This problems is the causes of the power supply board.The power supply board have problems,it is not giving the tv the wright voltages anymore.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Posted on Nov 15, 2010
VIZIO tv it powers up for about 5 min then a load screech then powers off. We can do that over and over no change we did factory reset and the power button hold for 30 sec no change
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Aug 30, 2016 | Vizio Televison & Video
When turning on from standby the screen flashes (1 sec)LG logo and then reverts back to standby
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
Apr 11, 2016 | LG 55ls5700 55 Edge Led Smart Tv 120hz...
Screen is black but led power lights come on ,yellow/green
Sounds like back-light inverter fault. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Mar 14, 2016 | Televison & Video
Monitor comes on but the screen gets dark after a 3 sec
if the power indicator at the front panel stay lit but no screen display or black screen, it could be a sign of bad power inverter board or screen back light. now to ensure if it was the cause you can do a voltage checking, at this time you will need a digital tester. you need to know if their is a bl_on voltage at the power inverter board around 3-4.4v to turn on the inverter board that supply the back light.if the power inverter board has 12v dc and has bL_ON voltage then the cause will be a bad inverter board. you must check also for a dry joint connector going to back light.
Nov 15, 2012 | ViewSonic VG2030wm LCD Monitor
I turned my t.v. on w/the remote. it came on then turned right off. at least i thought it did. there was no picture and the power light was blinking on and off with a green light. I pushed the power button...
Hello; This problem is likely caused by bad inverter board(s). I think there are 2 on the left side on this model. If either inverter doesn't start, the microcomputer on the main board see's this and generates one "lamp error" . Once it counts 5 lamp errors, the screen will not light and led(s) will flash. These boards are about $100 each and no way to know which is bad. It can also be caused by a bad LCD panel ( cost more than the TV sold for). You can verify a lamp error problem by doing a "forced start" . The set must be unplugged. then"I think" Hold the channel up and volume down buttons on the set or VISa Versa, and plug in without releasing these buttons for several seconds. If the set makes a buzzing noise , the power supply board is bad. If the set comes on and stays or goes off this is the inverter and/ or LCD panel problem. John
Dec 10, 2010 | Sharp LC-32SB24U 32 in. LCD TV
When I push the power button it blinks and never turns on
I recently repaired this exact TV that sounds like the exact problem. First you can take the back off and unplug everything from the Inverter board. The inverter board has the pink and white wire plugs going into it. Then try to power on the TV and if the green light comes on, and stays on, then you know the problem is in the inverter board. My problem was in the inverter and I found Q1500 (N Channel MOSFET) shorted Gate, Drain, and Source together. Just for safe measure I also replaced Q1550 that is the same exact part on that board. I was able to order the parts from http://www.utsource.net/ and the part # is 2SK2417.
Aug 31, 2010 | Sylvania LC320SLX 32 in. LCD TV
Power light comes on for about 30 secs, something clicks and both power and ocp lights start blinking contineously. the screen does not light up
I have this model of the sharp tv.Happen to me very often the Power and OPC LED light indicators blink continueosly.Not the power supply board,it the Tuner board that take in the comming broscast signal that have the problems.You still can used this tv.Push the power button sometime the tv it will work right away.Not,each time POWER and OPC lights continueosly blinks.Just push the power button again each time the POWER and the OPC continueosly blinks.Just have push power button again about 4 times each time Power and OPC blinks recycles,it will finally show the backlight and picture come on.My guest,if u do this by pushing power button to recycles about 10-12 times each time the POWER and OPC blinks it time to change the Tuner signal board.
Jun 03, 2010 | Sharp LC-C4655U 46 in. LCD TV
Power on 2 sec. then off won't turn mitsubishi wt-42313
with this model there may be a liquid spill on the signal board this is because one of the tubes is leaking
Jun 17, 2009 | Mitsubishi WT-42313 42" Rear Projection...
Vizio L37hdtv10a fails to fully turn on
You will have to isolate the main board and Inverters.
Unplug the inverters and turn on the set.
If it "turns on" then try re-connecting each inverter seperately to see if only one is causing the problem.
Mar 04, 2009 | Vizio L37 Television
Emerson LC195EM9 19 in. LCD TV Logo
204 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
