Question about Goodman GMS90703BXA Heater
MY Goodman furnace mdl #GMS80703AN would not come on. Diagnostic lite flashed in threes. I called Installer who instructed me to stick a small wire or other object carefully into hose connection from the small motor to the exhaust manifold. I did so -turned furnace on and it ran OK for hours. Sometime later it quit. I repeated above procedure but no luck. Installer very busy now - not answering the phone last Thursday & Friday. Will probably connect tomorrow (Mon.) but any suggestions as to the problem or possible solution?
    Novelist:
    Champion:
  • 230 Answers
This code is for a pressure switch failure. Do not stick anything into the pressure switch or blow into it. Either will damage it. You may however do as your technician suggested and clean the inducer motor port as well as the hose. If this does not fix it, begin inspecting the flu for blockage and make sure there is enough combustion air supplied to the room for combustion to be sustained. If all of this checks out ok, You can use a Ohms meter to check the continuity on the pressure switch. If this is ok you may have a gas pressure problem. Do not attempt to adjust the gas pressure if you are not certified to do so because the gas valve can be damage in the process not to mention the risk of explosion. Good Luck!
Posted on Jan 06, 2011
I have installed a wood burning furnace and was hoping to run the blower on my goodman gms80703an and thermostat without having to ignight the gas furnace
If I am understanding you correctly, you are just wanting to circulate the air with your gas furnace and heat the air with your wood burning stove. You should be able to set the fan switch to the ON position and leave the heat/cool/off switch in the off position.
Nov 29, 2015 | Goodman Heating & Cooling
Heater does not come on gms80703an
There are too many reasons for this to happen so we would have to narrow it down. The sequence of operation on a Goodman furnace is usually:
1: Inducer draft motor comes on
2: Hot surface ignitor comes on and glows
3: Gas valve opens, lights burners
4: Flame sensor detects flames
5: Blower comes on
If the inducer motor never came on, then you start looking at power to the unit, thermostat issues, or inducer motor issues. Just a few places to start. Hope this helps!
Dec 05, 2013 | Goodman Heating & Cooling
Just how do i get an online copy of the following: owner manual Goodman furnace md GMP100-3 I can be reached at Cliffieallen@ATT.net thanks Cliff
Go online and just type in goodman furnace and mdl # any goodman broker will send you a owners manual. I hope it helps good luck
Aug 09, 2010 | Goodman Heating & Cooling
Goodman furnace new in 07 flashed three code..It
you will neede to defrosted the flue clear any bushes or trees from flue if there ther eshould be a window on the front where you can see the lights hope this helps
Jan 10, 2010 | Goodman GDS80703ANA Open Flame Mid-Size...
Need help with a goodman gmt070 furnace...error code flashes three times, i have replaced pressure switch, still flashed, replaced board, still flashes three times...flue is clear, draft inducer motor is...
it may be clogged at the barbed fitting on the induced draft motor where the pressuer switch tubing connects. take a paper clip and **** it out make sure you can stick it thru freely till you can feel the Inducer wheel then reconnect and try again.
Nov 04, 2009 | Heating & Cooling
Hello I have a goodman gas furnace
On a call for heat, the 24 volt thermostat2.gif sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the ignitor. The ignitor will glow and you will be able to see it if viewed thru the small inspection port. Once the ignitor gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the ignitor does not energize (bad control, bad ignitor), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not lite (dirty pilot), the burner does not lite (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Most newer furnaces will have a diagnostic center or control built into the control module. You may be able to view it as it is running thru a small viewing port. Some models will require the removal of an access panel prior to finding it. On the reverse of the access panel, there will be a diagnostic chart that will aide you in understanding any error code recorded (usually a blinking light).
Oct 18, 2009 | Goodman Heating & Cooling
Goodman furnace blinked 1 time
Furnace attempted to start but failed after so manay tries. This may help you.
Sequence of operation, Gas Furnace.
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the ignitor. The ignitor will glow and you will be able to see it if viewed thru the small inspection port. Once the ignitor gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
This is why we technicians earn the big bucks!
Dec 05, 2008 | Goodman GMS90703BXA Heater
Goodman ac/gas furnace unit mdl. # gmp075-4
i HAD THE SAME PROBLEM, TURNS OUT IT WAS THE FLAME SENSOR, CLEANED IT, AND ALL WAS GOOD
Nov 27, 2007 | Cozy (W352E) Heater
Goodman GMS90703BXA Heater Logo
518 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
