Question about RIM BlackBerry 8700g Smartphone
Why does the battery wear down so fast? - RIM BlackBerry 8700g Smartphone
  • 68 Answers
Two possible reasons..
Most probable reason is that the battery has worn out..
many possible reasons for the battery being worn out.. one of them is that you might be charging it for extend periods of time everyday...
Also it is possible that your phone itself is somehow damaged..
But once again it is most likely your battery that requires to be changed..
Posted on Nov 15, 2010
2005 jaguar VDP 4.0L. Very hard start. Have replaced map and crank sensor, egr valve and intake.
in what way is it hard to start does the engine turn over fast or slow, fast is low compression in the piston chambers slow can be the battery or the starter motor wearing out. ( starter motor has bushes to turn the motor these wear out and cannot turn the engine over fast enough to start.
Aug 10, 2017 | Jaguar Cars & Trucks
Does anyone know why my batteries are running out so fast on my xbox controller
It all depend on the setting of the controller and obviously how long u been playing on it. The batteries will drain a bit faster than norm if u have the vibration setting on, fyi. As with everything over time things wear down and out, prolly could jus get a new rechargable battery, so keep those things in mind.
Jan 23, 2013 | Microsoft Xbox 360 Wireless Controller
I have a yard cruiser blade clutch engages then slows down when it gets under a load to the point of stopping let cool down same thing
Most likely it's a worn out pto clutch (electric blade clutch) one is a warner brand and one is ogura for this line. but first you should check two things:
1. Belt condition and tension (It should be pretty snug
2. make sure your battery is putting out at least 12 volts, you may try a new battery or have the battery tested for free at a local auto parts store. If they find the battery is low, your charge circuit may have a problem. If they find the battery is fine, and the belt is good, it's probably time for a new clutch. I say check the battery first because even if you replace the clutch and the battery is worn out, it will actually wear out the clutch quite fast. This is a common reason for the clutch to wear prematurely.
Apr 28, 2012 | Snapper Garden
To slow, i need it to go faster
Are your batteries fully charged? Are the batteries 2 years old or older? Even with a full charge older batteries will not generate amperage to make the chair go as fast as when new. Also the motors tend to slow down with age due to brushes wearing down. Now, if the batteries are new and the motors are not that old then you need to find a wheelchair provider that has a PP1 programmer and have then check the settings for forward speed etc. If the speed is not set to 100 then they can increase the forward speed to 100%. Hope this helps you
Sep 21, 2010 | Jet 3 Ultra Power Chair
Cold starting problems
depending on how fast it turns over if its turning over at a normal speed then your o2 sensor could be the cause of the problem a lot of your auto parts stores will run a free diagnostics check if they have the proper reader for your year and model
Dec 30, 2009 | 1996 Mazda Protege
Camera turns off within seconds batteries are new
Are You Using Regular Or Alkiline?
cameras eat batteries fast. the best cameras have rechargable battery packs.
i'd use energizer or duracell. try to stay away from alkiline rechargables as they wear out fast. try Nickle Medal Hydrate Batteries (NiMH).
Aug 13, 2009 | Nikon Coolpix 5700 Digital Camera
Flashes low battery with only a few shots. Battery is new. Also what brand of rechargable batteries do you suggest?
Aug 10, 2009 | Canon PowerShot A560 Digital Camera
Battery wears down too fast
verizon will tell you its okay, because in a way it is. when you first get your cell if you use it before you charge it, it will drastically effect its overall battery life. the solution would be to buy a new battery and to not use your phone until the new battery is fully charged.
Apr 18, 2009 | Samsung Renown Cell Phone
I received a Sanyo VPC-S880 digital camera for mothers day of 2008. It has a memory card, but I don't know how much. When I insert the batteries (size AA) *Panasonic alkaline* the batteries wear down...
The best batteries to buy for this camera is Energizer.... No matter what batteries you use, they are going to go fast, but I noticed these last the longest.
Jul 07, 2008 | Sanyo Cameras
RIM BlackBerry 8700g Smartphone Logo
102 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
