Question about Garden
I press to prime the fuel then go to pull the rope but it will not start i tried repeating about 20 times now and still nothing
  • 1,871 Answers
Hello! Without knowing the model # and brand name of the engine, it will be difficult to solve your problem...Send a comment..............Guru....saailer
Posted on Nov 15, 2010
How do you start it/
Check:
- Gas in gas tank
- Oil level correct.
- Tiller drive in off/disengaged position.
Start procedure:
- Fuel selector - ON
- Ignition switch - On
- Choke - On
- Throttle position - Slow
- SAFETY - No children within 10 feet/
Pull Starter rope......
Repeat 3 - 5 times only.
If engine starts, release choke as required until engine runs smoothly.
If no start,
- set Choke to OFF, Throttle to FULL,
- pull starter rope 3 - 5 times only.
- if start, reduce throttle to obtain smooth idle
- if No start, start check for:
- Spark at plug
- Fuel in the jug
May 22, 2015 | Garden
Poulan pp5020av. the pull start binds up.
When you remove the recoil shoot a little oil on the moving parts. sometimes they get dry or even rusty and binds.
Jan 18, 2018 | Poulan PP5020AV 20 in. 50cc Gas Chainsaw
How to start poulan 18 inch wildthing chainsaw
Hello Wade,
There should be starting instructions on back on saw, if not its usually the same for most saws. Fill tank with proper mixed fuel. Add bar and chain oil if necessary. Pull knob out to "start" position. Pull choke all the way out. Prime unit 6 times. Place saw firmly on floor, slide right foot under handle and have left hand firmly on top handle. Pull throttle and lock it in high. Pull rope 4 to 5 times until unit pops.Then, set chock lever on half.(this is usually pushing in half way). Pull rope again 4 to 5 times until unit starts, then after 30 seconds or so push choke knob in to turn choke off. If this procedure doesn't work, give it 10 minutes or so, because unit may be flooded, then try again. Good luck!
Sep 28, 2013 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I have just purchase a Sears 22 Lawm mower, with a Briggs and Stratton 158cc engine. I prime the motor it act like it wants to start but then dies. I pull it and try to strat it several more times and it...
The procedure for starting an engine is as follows:
  • Check that you have the throttle in the start position and/or on high revs with choke on
  • Prime the engine by pushing the button about 5 times
  • Pull out the cord until you meet resistance. Then let the cord go fully back into the engine and then pull the cord out sharply. Repeat this until the engine starts but not more than a few times.
  • If the engine doesn't start, try pressing the primer button another few times then try to pull start the engine
  • If the engine doesn't start after a few pulls it may have flooded so leave it for a few minutes before pulling the starter rope
Apr 30, 2011 | Briggs & Stratton Briggs Stratton Intek V...
How do you prime the fuel injectors on an isuzu rodeo 1994 I4 2.6l engine? changed fuel pump and all fuses are good but not getting any fuel to system. i turned key on and let the new fuel pump kick on but...
What you need to do is turn the key on and let the fuel pump run. Turn the key off and repeat about 20 times or so. Eventually it will start it just takes some time to get it primed. You can also do that and on the fuel rail there is a re-leaf valve. Crack that open to get the air out until you get a steady fuel stream.
Jan 16, 2011 | Isuzu Rodeo Cars & Trucks
I have been trying to turn on my chain saw. Ive pulled the handle back by the trigger gave a few pull on the rope. then i pushed the button in on the side also the push the button back in by the trigger...
The chainbrake should be activated when starting the chain saw. Activate the chain brakeby pushing the front hand guard forwards.b>Cold engine Start position, 1: Set the start/stop switch in the choke position by pulling thered control outward - upward.Decompression valve: Press the valve to reduce the pressure in the cylinder and makestarting easier. Once the machine has started the valve will automaticallyreturn to its original setting.Air purge: Press the air purge diaphragm repeatedly until fuel fills thediaphragm (at least 6 times). The diaphragm need not be completely filled.Grip the front handle with yourleft hand. Hold the chain saw on the ground by placing your right foot throughthe rear handle.Pull the starter handle, 4: Pull the starter handle with your right hand and pull out thestarter cord slowly until you feel a resistance (as the starter pawls engage)then pull firmly and rapidly until the engine fires.Push down the red choke control: As soon as the engine fires which can be heard through a"puff" sound, push down on the red choke control.Pull the starter handle (6): Keep on pulling the cord powerfully until the engine starts.
Nov 18, 2010 | Husqvarna 450 e-series 18" Chain Saw
Will not start. I prime the unit by depressing the bulb 7 times, the choke is full and the throttle is full. It simple does not try to start.
take the spark plug out pull the rope and see if gass comes out of thr cylinder which tell you theres to much gas coming out if your getting to much gas pinch your fuel line pull till it starts thenunpinch it if its firing it will start
Nov 05, 2009 | Garden
New 445 husqvarna chainsaw will not start
Drain the fuel tank, look inside the tank to ensure that the fuel line inside still has a fuel filter attached to it.
Look at the on/off switch ensure that both the wires are still attached to the switch securely.
Check that the plug still has spark, if unsure replace the plug.
Check the air filter to ensure that it is clean.
Mix the gas 50:1.
Sep 17, 2009 | Husqvarna Garden
My poulan chain saw sat for about 2 yrs with gas in it. I emptied the tank, put new gas in it along with a carburator cleaner but it will not start. lost the manual for it and don,t know which position to...
Empty out the gas and replace with proper gasoline mixed with oil in the proper proportion. Always use a good quality 2-cycle oil that contains a fuel stabilizer.
To start the generic chainsaw, follow these steps:
1. Pull the choke all the way out
2. Press the fuel bulb serveral times to prime the carb - you can feel when the fuel flows into it.
3. Set the lock on the trigger to full speed.
4. Now, pull the starter rope until the saw sounds like it tried to start.
5. Press the choke in to the 1/2 way position.
6. Pull the rope until it starts.
7. Release the trigger lock and push the choke all the way in.
If starting it when it is warn, skip steps 1 and 4.
It is unlikely that the spark plug is the problem. If you replace it without properly setting the gap, you may make it worse. If you start trying to adjust the carb without knowing exactly what you are doing, you will make it much worse, You can try spraying some carb cleaner into the carb and pulling the rope to such the cleaner into the jets.
In the future, always add fuel stabilizer or oil with a stabilizer to you gas/oil mix. This prevents the varnishing caused by aging gasoline.
Jul 11, 2009 | Poulan Garden
Starter rope too hard to pull on Yard Machine By MTD
Not sure if this will help. Don't want to sound like a **** but....Have you made sure nothing is caught or jammed inside it. This could make it hard to start with the cord..
May 19, 2009 | Troy-Bilt Pony Garden Tiller
Garden Logo
20 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
