Changing the drive belt on a Sporty is a snap compared to a big twin. First you'll have to remove the rear brake master cylinder and pedal or at least take the bolts out and move it out of the way. Remove the front pulley cover. Remove the rear wheel and the shock on the right hand side. You should be able to work the belt off the front pulley and get the new back on.
When you put the new belt on and tension it, make sure you keep the adjuster bolts of either side of the swingarm about the same length. This ensures that the rear wheel is aligned with the swingarm.
SOURCE: how to drain oil from 2001 harley sportster
The drain hose comes down the back of the frame and looks like it attaches to the frame.
SOURCE: Not just changing oil, but is there gear oil to
Yes, there is oil in primary and transmission of your Sporty. To drain the oil, look for the drain plug on bottom of rear section of the primary area, back near the large round section of the primary. Drain the oil here and replace the plug. Add the oil at the top primary chain inspection port, large plug with a large "screwdriver" slot or two small bolts in it. Add 32-36 ounces of H-D "primary lubricant for Sportsters".
SOURCE: 2000 Harley Davidson XLC Sportster 883 won't start
the heat from the bulb being continiuosly on may have melted a wire inside your headlight?
