Question about Canon PIXMA MX350 Wireless All-in-One Inkjet Printer
How do I scan using the Canon Pixma MX350 - Canon PIXMA MX350 Wireless All-in-One Inkjet Printer
SOURCE: canon pixma mp220
I had the same problem, and this is the fix.
1. Go to Canon's website and find the "Drivers and Downloads" section. From there, you will need to specify the subcategories of your hardware, and then your specific model (for example: Hybrid (i.e.-Printer & Scanner), Inkjet, MP470 Series)
2. When you find the proper page for your model printer, select your operating system from the drop down list.
3. Scroll down the page. You will see all versions of the drivers and programs to download. Download the latest version of the driver. You should also download the "My Printer" program. This is useful for troubleshooting and maintenance.
4. Keep scrolling until you find the "MP Navigator" program. This is a very important program, and is necessary for the scanner to operate properly. Download this program.
5. One MP Navigator is downloaded, verify that the scanner will use this program when it operates. To do this, go to the Start menu, click on Control Panel, click on Scanners and Cameras, click the printer that you will be using, then click properties. Click the tab at the top that says "Events." You will then see a drop down menu with the options Save to PC, Save as PDF, etc. Verify for each option that your computer is either opening the MP Navigator program, or that the computer will prompt you on which program to open.
This should get your scanner working. Hope this helps!
Posted on Sep 15, 2009
  • 76 Answers
SOURCE: canon MP600 won't scan
i would say maybe first step os to unistall all canon mp600r software includin scanning programs and reinstall them and see if it then works. this might cure your fault but make sure you do it from the setupdisc not the canon website.
Hope this helps
Posted on Oct 20, 2008
rhoncruz
  • 134 Answers
SOURCE: how to scan using canon pixma mp150
Acquire Text The following instructions will give you the basic instructions to acquire text from a scanned document in Office Word 2007 using OmniPage SE.
  1. Ensure the Canon scanner driver and OmniPage SE are installed and that your scanner has been setup.
    Note: If OmniPage SE is not installed, the required Add-in for Office Word 2007 will not be installed
  2. Place the document(s) to scan on the platen or on the Automatic Document Feeder (ADF) (if applicable).
  3. Open Office Word 2007.
  4. From the ribbon menu, select the 'Add-Ins' tab.
  5. In the Add-Ins tab, click 'OmniPage' and then select 'Acquire Text Settings (OmniPage SE)'.
    The Options window will open.
  6. On the Direct OCR tab, click the 'Image Source' drop-down to select 'Scan'.
  7. Confirm 'Scan' is shown in Image Source section and then click 'OK'.
    The Options window will close and you'll return to Office Word 2007.
  8. Click 'OmniPage' and select 'Acquire Text (OmniPage SE)' to scan your document.
  9. After the document(s) is scanned, make corrections to the text items as appropriate.
I hoe it helps!!!
Posted on Dec 01, 2008
  • 1570 Answers
SOURCE: canon mx350 Won't scan. Goes through
Hi
Try to set up again new scanner with the same name and remove the old scanner icon.
Also, uninstall and reinstall the printer software might help you solve your problem.
Regards
Posted on Feb 20, 2011
Joed911
  • 4338 Answers
SOURCE: MX350-Can't scan to an editable "Word" document
Here are links for some free OCR programs:
Top five free OCR:
http://www.thefreecountry.com/utilities/ocr.shtml
http://www.freeocr.net/
http://www.simpleocr.com/
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Posted on Feb 24, 2011
The "Open Scanner" won't work on my computer
Will the buttons on the printer work normally? If so, then it's a software or driver problem in the computer.
Jan 23, 2014 | Canon PIXMA MX350 Wireless All-in-One...
Canon pixma mx350 printer ink level shows exclamation mark about the icon
If you are using an ink refill kit (or buying ink that has been refilled, the ink level will not show accurately) also, if refilling yourself you must clean the pint area of the cartridge with alcohol before installation, and then run the 'clean print head' tools from you Canon menus.
I recommend buying Canon ink, at least for 1 in 4 refills to reset your ink levels.
Nov 20, 2013 | Canon PIXMA MX350 Wireless All-in-One...
How do i install canon mx350 wireless scanner in my laptop?
install the pc suite and then connect with the bluetooth.before that add your hardware over bluetooth.
Apr 28, 2012 | Canon PIXMA MX350 Wireless All-in-One...
I'm using a wireless canon pixma mx350 but am unable to print web pages, in particular from a HSBC site. As soon as I click print, the printer disappears!
1.Try doing Ctrl+S and saving the webpage to your computer first. Then open the saved webpage and try printing from there. 2. If that doesn't work, try right clicking in the portion of the page you wish to print, and doing "Print This Frame". 3. If that is not an option, try using Ctrl+P instead of clicking on the print button. This should bring up the print dialog. 4. Otherwise, try using Ctrl+A to select everything, Ctrl+C to copy it, open a new Word document and use Ctrl+V to paste it. Then try printing the Word document.
Good luck! And PLEASE leave me positive feedback!
Jul 27, 2011 | Canon PIXMA MX350 Wireless All-in-One...
I have a Canon Pixma mx350 that I bought new and have been using for just a few months now. Recently, everytime I go to print something, when it picks up the paper it immediately jams and has an error. Is...
This is a rear feeding machine and i suspect something has fallen into the sheet feeder and causing your jam. Remove the cartridges, turn the machine upside down and give it a shake. Hopefully the object will fall out. If not then unfold a paperclip and gently slide it down into the feeder and see if you can dislodge the object then shake again.
Good luck.
Jul 21, 2011 | Canon PIXMA MX350 Wireless All-in-One...
When i try and print a document from my work computer to my Mx350 a message comes up and says that "printer is not responding"
Try unplugging power from the printer and restarting. If this does not work, check the USB cable or the wifi connection to the printer. If this does not work, delete the printer from your computer and add it back. If the computer does not see it, then you know you have a connection probem either USB or wireless
May 13, 2011 | Canon PIXMA MX350 Wireless All-in-One...
Where is the serial number??
From Canon's support page for this printer located at http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx350#ServiceAndSupport
  1. Open the Paper Output Tray.
  2. Lift the Scanning Unit (Cover) and fix it with the Scanning Unit Support .
  3. The serial number is located on a white sticker on a metal plate to the right of the print head carriage inside the printer.
    It starts with four letters and ends with five numbers. Example: ABCD01234
Mar 05, 2011 | Canon PIXMA MX350 Wireless All-in-One...
Top five free OCR:
Thanks, Joe
Feb 23, 2011 | Canon PIXMA MX350 Wireless All-in-One...
My computer will not recognize the PIXMA MX350 printer wirelessly. I can use it with the usb but not wireless. I tried using an ethernet card to physically hook my computer to the router and thend download...
You may want to follow the instructions on setting up your PIXMA MX350 printer properly through this LINK01. Full lists of on how to setup your printer for your wireless network can be viewed/downloaded from this LINK02. Remember, softwares and drivers are limited from the manufacturer's releases.
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
Feb 21, 2011 | Canon PIXMA MX300 All-in-One Printer
Canon mx350 Won't scan. Goes through all the steps. But will not scan to pc.
Hi
Regards
Feb 20, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA MX350 Wireless All-in-One Inkjet Printer Logo
492 people viewed this question
old marine
old marine
