Computer My CD/DVD rom will not run! It just makes a grunting noise when I put in a disc.It's a fairly new dell desktop and I don't know what could have happened to make it stop working. It will not play a cd/dvd, I can't burn anything. I've tried going to START, RUN b/c I thought it just wasn't running automatically, but it just makes a grinding noise like it's trying to start working, but can't. I went into the device manager & made sure the DVD/CD-ROM drive was enabled. I checked for updates....I don't know what else to do. Any ideas?
    Scholar:
  • 141 Answers
Hi gavo,
since its still new, you still have the receipt with you right? better bring it back to where you bought it and let them check it instead, we dont like to void the warranty. :)
were you able to use it even just once? try a different cd, if you use cd in your first attempt, try dvd the next, try movie cd or audio cd, just to isolate the problem.
just post your feedback here,
Posted on Jun 19, 2008
Dell gx 260 there is no disc in the drive.
OK, first of all you said you put a blank DvD in the drive. Make sure your dell has a DvD writer. Look on the drawer of the drive and see does it say DvDrw or DvDROM. It has to say Rw for rewritable and not ROM for Read Only Media. Maybe you have a Combo Drive that is DvDrom and CDrw which means it will read both DvD's and Cd's but in can only Write CD's.
If in fact you do have a DvD writer make sure you're not trying to put a Blue Ray disc in the drive.
Lastly, remove the DvD from the drive. Click Start/My Computer. Notice what it brings up as to your DvD Drive. Does it Say DvDrw or just plain ole DvD. DvD means it will only read a DvD.
Mar 20, 2012 | Dell OPTIPLEX GX260/SMT P4 2GHz 512MB...
Inset disc, wont run
which disc are you talking about?if cd/dvd must be problem with your hardware.try replacing your cd/dvd rom
Nov 05, 2011 | Dell Inspiron 530s Desktop Computer
Hello i want buy solution cd-rom driver..... my
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties you will have options under general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
Jan 16, 2011 | Dell (074JH) Internal 48x CD-ROM Drive
CD-ROM drive doesn't acknowledge DVD-ROM, what's wrong?
CD-ROMs dont play dvd becuase they are not designed to read dvd.
If a dvd drive for your model is not available, you can buy an external usb dvd drive.
That should solve your problem
Dec 28, 2009 | Dell Dimension E521 PC Desktop
I got a new desktop Dell (runs on Vista) to replace my old Dell laptop (runs on Windows XP). I inserted the software CD for my HP Office Jet K80 All in One printer and it literally exploded loudly inside...
Vista has identified your printer. It loads up its default printer driver (stored in vista OS) in your new computer. This usually have the basic features only. You need to run again the CD to install or enable the added features of your said printer. If you have lost the CD you can do an alternate option by downloading the software on this link. ftp://ftp.hp.com/pub/united-states/pse/hppse1.12.0.46enu.exe
For the the CD that was crumbled inside your cd-rom. You can try to pull out the CD from the Tower casing and try yo maually open the CD rom unit itself. Or may i suggest that you can buy a new one. (CD/DVD roms are cheaper now a days)
The causes of CD crashing inside your CD rom;
1. wrong placement of CD/DVD disc
2. Hardware failure of the CD/DVD roms
Sep 26, 2009 | HP Office Equipment & Supplies
Cd rom not working and computer keep on freezing
try with other disk if all disk getting same issue then you have to first clean your cdrom or dvdrom lense.
For that you need disk cleaner disk pur chase it and put in rom then play it.
then it clean lense.then check.
if still face problem then you need to repair or replaced lense if it in warrenty replace it.
Jul 29, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
I can't insert any cd's.
Maybe the laser eye is jammed. It tracks back and forth reading data from the disc.
You may either replace the drive or have it repaired.
I had one on my PC do the same vibrating, clicking noise. It only cost 40.00 to replace.
But for a laptop, you're looking between 60-100 dollars to replace.
You can see how much it would cost to repair first, but my guess is it would be cheaper to replace.
Jul 12, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Lat. D600 will not read cd and does not recognize cd
this tool will fix it
use this tool to reset the cd in the registry
after you run the file - reboot the computer -
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
May 30, 2009 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
Dvd drive not working
Typically, the grunting would indicate a bad drive. Replace it. They're fairly inexpensive nowadays ($20-$30).
Jan 03, 2009 | Siemens Computers & Internet
My Computer Wont Read DvD's or CDs!
Is the CD drive display in my computer? yes
then clean up your CD/DVD rom for there is dust in it, specially on the lazer lens that let the rom read the CD/DVD.
If no, then; Fix some cable connection towards your CD/DVD rom for it was lessen.
If not fix the problem verify the disc if it is readble by your Rom. Please try another disc in your Rom.
if same happen, then maybe its time for a new CD/DVD ROM.
one last try:
try your new purcahse disc in another computer that is compatible with your disc.
hope this help, melnavz
Feb 05, 2008 | Dell Dimension 3100 PC Desktop
Computers & Internet Logo
David Payne
David Payne
