Question about Refrigerators
Applied power to a Shinco KFR-50GWZ/BM and there is an ERROR CODE "P0" on the inside unit display. I checked the voltage at the unit and there was 209.9 vac there. Checked name plate info for the unit and it is 230 vac. Would the low voltage here cause this error? If so I can get the Power Company to change the tap on the Transformer to give me 230 vac. I see on a chart that this ERROR CODE "P0" indicates DRIVER BOARD IS FAULT. Where is the DRIVER BOARD located and can this fault be reset? Thanks
bestdarngood
  • 3037 Answers
SOURCE: compressor runs, fans don't
hi thomasej
There is no reset button anywhere for the fans. Like you said, it could be a burnt out transformer or it could be that the defrost timer went bad. Let me know what you decide to do and if you are able to fix it. If not, let me know and I would be glad to help you with any further questions or concerns that you may have.
Posted on May 27, 2008
  • 50 Answers
SOURCE: No power on GE Profile Spacemaker II Microwave Oven
SWITCHES ARE THERE FOR A PURPOSE-----SAFETY,,SAFETY...ALWAYS CHECK A MICROWAVE WITH THE POWER CORD REMOVED---YOUR MESSIN WITH A RF VOLTAGE THAT WILL KILL YOU!!!! UNPLUG,,UNPLUG,,,UNPLUG
TRY TO CHECK THE FOLLOWING...SINCE YOU HAVE THE COVER OFF,,LOOK AT THE DOOR LATCHES WHEN YOU CLOSE THE DOOR AND MAKE SURE THEY MAKE CONTACT ON THE DOOR SWITCHES,,3 OF THEM,,,--AN OHM METER IS THE TRICK FOR THIS - SOMETIMES YOU CAN SEE PLASTIC BROKEN ON THE SWITCH ITSELF...ALSO LOOK AT THE COMPLETE SWITCH HARNESS (CHECK FOR BROKEN PLASTIC PIECES) THAT HOLD THE SAFETY SWITCHES...THE MIDDLE SWITCH (MONITOR SWITCH) CLOSES WHEN YOU "OPEN" THE DOOR,,YES "OPEN "THE DOOR AND IT WILL BLOW THE MAIN FUSE..IF IT'S SHORTED.
THERMAL PROTECTORS RARELY GO BAD--IF YOU HAVE A PROBLEM WHERE IT TAKES 25 MINUTES TO COOK A BAKE" POTATOE"--JUST LIKE THE VICE PRESIDENT--THAT'S A THERMAL PROTECTOR..
PLEASE BE CAREFULLLLLL TUNICA
Posted on Oct 30, 2008
meBNme
  • 334 Answers
SOURCE: hello i have proble with air conditioner and heater is a split system unit
What its telling you is that there is an outdoor "thermostat" that senses the outdoor temperature.
The system has found a failure on this area.
It is telling you to check the sensor to see if its actually the sensor thats bad, or something else.
Then its telling you to check the wiring and connection of the sensor to the control board for any loose wiring or broken connections, and to repair it if so.
It then says if niether of those two checks reveal any problems that the problem is the board itself and it should be replaced.
To answer the question, resetting it probably will not work.
There is a small chance that due to power surge, flickering lights, or just a fluke one time glitch that there is nothing rally wrong and resetting would work.
95% chance that is not so.
Posted on Dec 10, 2008
mrgrzz
  • 88 Answers
SOURCE: Senville Mini Split Error Code
thanks for your question, you will need a set of gauges on the unit to determine if the unit came precharged, if it didn't then you will need to vacuum down the unit, at least three times, after each time release a little 410a into the system them evacuate again, 410a is bad for drawing moisture, did you put an in-line filter dryer on as well ? after you find out about the freon level, then look at the name plate rating for amount of 410a needed, before adding the freon, use nitrogen to leak check the system, then weigh in the proper amount of 410a, unit should run really well after that, hope that helped, thanks again for your question, please feel free to come back if you have any more questions, thanks, mr.grzz
Posted on Jan 21, 2009
mohammed387
  • 1952 Answers
SOURCE: Kenmore SBS ice maker quit
adjust the cooler control
Posted on Feb 25, 2009
Code p2118
DESCRIPTION
The ETCS (Electronic Throttle Control System) has a dedicated power supply circuit. The voltage (+BM)
is monitored and when it is low (less than 4 V), the ECM determines that there is a malfunction in the
ETCS and cuts off the current to the throttle actuator.
When the voltage becomes unstable, the ETCS itself becomes unstable. For this reason, when the
voltage is low, the current to the throttle actuator is cut. If repairs are made and the system returns to
normal, turn the ignition switch OFF. The ECM then allows the current to flow to the throttle actuator so
that it can be restarted.
HINT:
The ETCS does not use a throttle cable.
MONITOR DESCRIPTION
The ECM monitors the battery supply voltage applied to the throttle actuator.
When the power supply voltage (+BM) drops below 4 V for 0.8 seconds or more, the ECM interprets this
as an open in the power supply circuit (+BM). The ECM illuminates the MIL and sets the DTC.
If the malfunction is not repaired successfully, the DTC is set 5 seconds after the engine is next started.
Jun 27, 2016 | Cars & Trucks
Error code E1 and E4
PDF]SERVICE Manual - Quietside
https://www.quietside.com/archives/.../Service%20ACC1800C.pdf
When error occurs in air conditioner, error code is displayed on indoor unit .... Display priority order at overlapping error : E1?E4?E5?P0?P0?P5?P6?t1? ...
Midea air conditioner error codes
airmaster.net/midea-air-conditioner-error-codes/
Midea air conditioner error codes. Indoor unit error code explanation: R series: ... E1, Indoor / outdoor units communication protection. E2, Zero-crossing signal error ... E4, Outdoor unit temp. sensor or connector of temp. sensor is defective.
[PDF]Download the Fault Error Code Booklet - Samsung
Dec 05, 2015 | Heating & Cooling
The red light is flashing on my air conditioner SHINCO KFR 50GW, and the outdoor unit is off?
Sorry didn't really know how rusty me Japanese was until I went on their support page and could not read but half good luck
Jul 03, 2015 | Heating & Cooling
Shinco fault code e2
I recently had the E2 error code on 2 units a KFR-35GW/BMVE and KFR-50GW/BMVE. I recommend checking the refrigerant. Our's was extremely low and having it filled/charged resolved the issue. In all of the Googling, this solution never came up.
Initially the error code would come on and flipping the breaker off for 10 mins or so would reset it and it would work. Probably did this about 10 times every so often (like over weeks). Eventually this did not work and researching online led us to believe that either the indoor pipe sensor or indoor PCB was bad. Spent lots of time online trying to find these replacement parts to no avail. Was finally able to get a friend of a friend that is an A/C person to check them out and discovered the Freon was too low. Hope this helps someone else out there stuck with these "unserviceable" units.
May 06, 2013 | Heating & Cooling
Dishwasher error code P0
Hello Alan Gibson - Are you certain the error code is P0? This manufacturer does not have an error code P0 for any dishwasher or other units. Could you please try reprogramming the unit by flipping the household circuit breaker off or unplugging it? Wait approximately ten minutes and restart dishwasher. If the unit is experiencing a generic communication error, it should be follow by another fault code. What is the error code? If it continues to display P0 then consult a professional to move forward accurately.
Feb 05, 2013 | Electrolux EWDW6505GS Fully Integrated...
Senville mini split codes
Put gage on low side and check the pressure running. if it is less than 125 you probably have a leak.
Apr 30, 2009 | Heating & Cooling
Jan 21, 2009 | Heating & Cooling
The E4 light on your system is saying there is a commiuntion problem between the inside unit and the outside heatpump unit.Make sure there are no loose wires and you wired it properly,The S wire is the commiuntion link wire make sure it is a solid run between both units.I had the same problem with my system and it was the s wire not making a good connection.
Nov 03, 2008 | Heating & Cooling
Refrigerators Logo
159 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
