Question about Campbell Hausfeld 5 Peak / 1.7 Running HP, 17 Gallon Husky Air Compressor
SOURCE: i have a husky 26 gal compressor that will not
do you drain the water from the tank if not try it
Posted on Jul 12, 2009
SOURCE: HUSKY 26 Gallon Shuts Down After <75PSI!?
Possibly the pressure switch needs to be adjusted to reach a higher pressure. Trace the power cord into a box that also is piped into the pressure line from the compressor. If the pressure works itself back down again, use thread-locker fluid on the adjustment screw to hold it's setting.
Posted on Sep 08, 2009
SOURCE: I have a Husky Pro 30 gal a/c. How do I adjust
The adjustment for "Cut-In" and "Cut Out" can be found under the pressure switch cover, if available. Some switches are sealed to prevent tampering that might compromise safety.
If you remove the cover you will see the four electrical connections and one or two screws with springs under them. Most times if the adjustments are accessible you will find a set of instructions under the switch cover. One screw will adjust both the "Cut-In/Cut-Out" pressure and one to adjust the "Cut-Out" pressure only.
However you need to remember some important issues regarding these adjustments. The first is that the "Cut-In/Cut-Out" pressure is set at the factory and is set there for a reason. The only reason to change these is because over time the adjustments can change or you are installing a new switch. The other thing to remember is that the safety relief valve is set just above the "Cut-Out" psi. So any meaningful increase will only trigger the safety valve.
If you need to readjust your compressor back to factory settings make sure you do it with small adjustments. 1/4 to 1/2 turn of the screws. Run the compressor and check both the "Cut-In" and "Cut Out" psi setting before making another adjustment.
Hope this helps, good luck and please be careful.
Posted on Dec 14, 2009
SOURCE: Describe your vt631402aj (Husky Pro 7HP 60 gal,
send me a photo of your pressure switch with the cover off and I will see if I can help you!
send to steve@morrismachineservicesllc.com
Posted on Mar 03, 2010
Nov 30, 2017 | Air Tools & Compressors
Jan 10, 2017 | Air Tools & Compressors
May 17, 2016 | Air Tools & Compressors
Jul 31, 2014 | Campbell Hausfeld 26 - Gallon Air...
Dec 13, 2013 | Air Tools & Compressors
Mar 30, 2013 | Air Tools & Compressors
Aug 12, 2011 | Craftsman 33 gal Air Compressor 6 hp...
Oct 26, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Jul 12, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
537 people viewed this question
