Question about Kodak S100 Webcam
My installation disc won't go any further than language selection, how do i fix this?
How to convert windows in english for arabic
Within Control Panel select Region and Language. Select the language you require and download the language from Microsoft.com if it is not on your install disc.
Hope that helps.
Mar 29, 2011 | ASUS Computers & Internet
Reset my administrator password
To reset the administrator password using the Mac OS X disc: step_1.gif
Insert the Mac OS X Install disc and restart the computer.
When you hear the startup tone, press and hold down the C key until you see the spinning gear.
When the Language Chooser appears, select your language and click Continue.
Choose Utilities > Reset Password.
Follow the onscreen instructions to change the password.
Quit the Installer and restart your computer while holding down the mouse button to eject the disc.
You can change your login keychain password in Keychain Access to match your new account password to unlock your keychain when you log in.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 04, 2011 | Apple iBook G3 Mac Notebook
Win xp heberw to English verian how can i read English.everything is program heberw. so i need to English translat.im trying but nothing
Hi there !
You have to go to language or regional setting to change your language setting. Go to control panel and choose language and regional and try to update it by installing desired language using internet connection.
I hope it helps you.
Jan 21, 2011 | ASUS Eee 4G Notebook
Good Morning Sirs, I was wondering to know, after having installed Windows 7, on my HP DV9000 Series Laptop, shift 2 = at and Shift 3 = hyphen are not working, in that place of @ and £ are...
The keyboard layout / Language of your PC may have been changed, so follow these steps to select the International keyboard layout:
- Go to Control Panel - Region and Language settings
- On the Keyboards and Language tab, click Change keyboards.
- Click Add.
- Expand the language that you want. For example, English (United States).
- Expand Keyboard list, select the United States-International check box, and then click OK.
- In the Default input language list, click Language name - United States-International (where Language name is the language that you selected in step 4), and then click OK two times.
- In the Regional and Language Options dialog box, click OK.
Notice that the Language bar appears on the taskbar. When you position the mouse pointer over it, a ToolTip appears that describes the active keyboard layout.
- Click the Language bar, and then click United States-International on the shortcut menu that appears.
Let me know if any further clarification/ assistance is required.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 10, 2010 | HP CPQ175KB Keyboard
My daughter deleted some programs on my g4 17" now all i have is a white screen
Install gray disc 1, shut down, press and hold C to boot from disc, select install in English or whatever language you speak, go to the top and select utilities, select disc utility, select your hard drive on the left side of the screen select repair disc permissions, and let the laptop do it's thing. Then select repair disc and let the laptop do it's thing. Now quit, and restart from hard drive. See if that don't help you any old chap.
Nov 06, 2010 | Apple PowerBook G4 Mac Notebook
How can i change the french language to english language because our laptop was a french language and i dont know how make it english
Go into Control Panel, select Region and Language, choose a display language by installing English first.
You may need your Windows Installation Disc!
Oct 17, 2010 | Acer Computers & Internet
Keyboard won't type in English, Hit the M key and 3 letters come up! Help! How can I fix this?
Steps for windows xp
1 Go to Start ? Control Panel ? Regional and Language Options ? Add other languages. 2 Note that, in the lower box, you need to check the check box next to the words "Install files for East Asian Languages". 3 Hit the "Details" button in the upper box. 4 Keep in mind that, on the right of the list of languages you have on your computer, you should now click "Add..." 5 Choose your language and hit "OK". 6 Select "Apply" (this is the window with the "Add..." button on it). 7 Select "Apply" (this is the first window that you opened). note you may need the windows xp disc to do this to install the proper language file.
Steps for vista
1 On your desktop, click the "start" button. 2 Then, click "control panel" 3 On the right hand collumn, click "change keyboards and other imput methods", (which is situated under "Clock, Language, and Region") 4 Click, "Change Keyboards" 5 There, you should see all the languages your keyboard is currently programmed to. Click "add" 6 Here is a list of languages to select. Tick the box of the language you choose, and click "Ok" 7 This will take you back to the previous screen, where your selected language will be added to the list. Click "apply" to finish. 8 To use your chosen language, look at the toolbar. There is an icon which is "EN" (if the default language is English.) 9 Click the icon and then the new language to type in it.
if you need further assistance please let me know. If this helped you with your problem please rate it accordingly. Thanks, Midwest-tek
Aug 31, 2010 | Ideazon MERC Stealth Keyboard
Hello i have a cannon copier and printer all in one and i lost my reinstal disc.what do i do. its a cannon mp210
Here is the link from the manufacturer's website: http://software.canon-europe.com/products/0010485.asp
Just select your operating system and the language you want. If you do not find *********** language on the list select English.
If you need further assistance or if you have further questions please leave a comment. Cheers
Aug 25, 2010 | Canon Office Equipment & Supplies
I have a problem. the computer started to produce
Can give me more detail how to fix the problem
Jul 18, 2010 | Computers & Internet
How to change language from japanise back to english
Hi!
To set or change the default language on your Xbox 360 console, follow these steps:
  1. Start your Xbox 360 console without a disc in the disc tray.
  2. Move to the System section of the Xbox Dashboard. Note On the NXE Dashboard, select System Settings.
  3. Select Console Settings.
  4. In the Console Settings area, select Language.
  5. Select the language that you want to use.
  6. Press the A button on your Xbox 360 Controller or on the remote control.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Apr 26, 2009 | Microsoft Xbox 360 Console
Kodak S100 Webcam Logo
195 people viewed this question
Top Kodak Computers & Internet Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Kodak Computer and Internet Expert? Answer questions, earn points and help others
