Question about Lanier UNKNOWN
Our older tivo unit (7-8 years) appears to have stopped working. We have a green light on the right and red light on the left. Does the unit need to be replaced.
  • 8,457 Answers
Tries unplug,replug the Tivo box back like an hour later.The unit now will,reset itself back to the factory setting and rebooting up softwares.The unit should work again.If not,the unit is pass it prime and having problems with it PCB circuits board.Yes,it time to buy a new and update verision of the Tivo box.
Posted on Nov 15, 2010
The towing plug has been cut off. Trying to wire
in most red is stop ,yellow is left signal , green is right signal, brown or black is parking lights ,white is ground use a test light to comfirm what your doing , like turn left blinker on test wire and tempararly connect and so on ,be sure to hook up ground first. if you need more help just send a message in comment section at bottom
Oct 08, 2014 | Cars & Trucks
How to wire trailer plug
hope this helps
6 pin socket
6 pin plug
7 pin socket
7 pin plug
5 pin socket
5 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
12 pin socket
12 pin plug
small 6 pin round plug & socket
1 tail, clearance - brown
2 left hand turn - yellow
3 right hand turn - green
4 stop - red
5 electric brakes - blue
6 earth - white
small 7 pin round plug & socket
1 left hand turn - yellow
2 reverse - black
3 earth - white
4 right hand turn - green
6 stop - red
7 tail, clearance, side markers - brown
roundskt.jpg round socket
large 5 pin round plug & socket
3 earth - white
5 right hand turn - green
6 stop - red
large 7 pin round plug & socket
2 reverse - black
3 earth - white
6 stop - red
7 pin round heavy duty plug & socket
1 earth - white
2 left hand rear , clearance and marker - black
3 left hand turn - yellow
4 stop - red
6 right hand rear , clearance and marker - brown
7 reverse/auxilary - blue
7 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
7_flatsocket.jpg flat socket
12 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
8 battery supply - orange
9 auxiliaries - pink
10 earth - white
11 rear fog lamp - grey
12 auxiliaries - violet
Feb 02, 2013 | 2004 Toyota RAV4
2000 ford expolar need 2 know the color of speakers wires
2000 Ford Explorer Stereo Wiring
Front Speakers 5" x 7" Doors
Left Front (+) Orange/Light Green
Left Front (-) Light Blue/White
Right Front (+) Dark Green/Orange
Right Front (-) White/Light Green
Rear Speakers 5" x 7" Rear Door
Left Rear (+) Gray/Light Blue
Left Rear (-) Tan/Yellow
Right Rear (+) Orange/Red
Right Rear (-) Brown/Pink
Constant 12V+ Light Green
Switched 12V+ Yellow/Black
Ground Black
Illumination Light Blue/Red
Dimmer n/a
Amplifier Remote Blue
Antenna Right Front
Best wishes!
Jan 05, 2011 | Ford Explorer Cars & Trucks
I need a radio wiring diagram
Constant 12V+ Green/Purple
Ground Black/Light Green
Dimmer n/a
Antenna Right Front
Right Front (+) White/Light Green
Right Front (-) Dark Green/Orange
Rear Speakers 5" x 7" Rear Doors
best wishes
Jan 01, 2011 | 1992 Ford Explorer
95 ford f250 trailer wiring trouble what does each wire work and what color
The basic 4-flat trailer wiring colors are as follows.
Yellow-Left turn/Stop, Green- Right turn/Stop, Brown-Running Lights and White-Ground
7-way trailer wiring colors are as follows.
Yellow-Left turn/Stop, Green- Right turn/Stop, Brown-Running Lights, White-Ground, Red or Black-auxiliary power, Blue-Trailer Brakes and Purple-Reverse lights
Jan 15, 2010 | 1995 Ford F250
Need color code diagram for sterio
I'm not sure what year you have but this color code works for 87-93 mustangs.
Radio Connector:
Light Green / Yellow - Hot at all times (Fuse 8)
Yellow / Black - Hot in ACC or Run (Fuse 11)
Light Brown / Red - Goes to instrument panel dimming rheostat (Fuse 4)
Red - Ground
White / Purple - Hot in ACC or Run (Fuse 11)
Speaker Connector:
White / Light Green - (+) Right Instrument Panel & Door Speaker
Dark Green / Orange - (-) Right Instrument Panel & Door Speaker
Brown / Pink - (+) Right Rear Speaker
Pink / Light Brown - (-) Right Rear Speaker
Pink / Light Green - (+) Left Rear Speaker
Tan / Yellow - (-) Left Rear Speaker
Light Brown / White - (+) Left Instrument Panel & Door Speaker
Orange / Light Green - (-) Left Instrument Panel & Door Speaker
Hope this helps.
Jun 19, 2009 | Ford Escort Cars & Trucks
I need no color code for 2006 ford taurus
+12V DC Battery(Constant) Red/yellow - Control unit in left side of luggage compartment 17 20 amp Junction box in front center of engine compt.
Switched Accessory Red/orange - In-line with the starter relay 27 5 amp Junction box in front center of engine compt.
Ground Black/lt.green
Remote Turn On(output) Brown/orange Pin 8 of CD changer. Also light green/black between rear control unit (C388B-2) and front panel (pin 4).
Illumination See notes *
Left Front + Orange/lt.green
Left Front - Lt.blue/white
Right Front + White/lt.green
Right Front - Dk.green/orange
Left Rear + Grey/lt.blue
Left Rear - Tan/yellow
Right Rear + Orange/red
Right Rear - Brown/pink
Notes
Information listed in the harness section refers (in this case) to the rear control unit in left side of the luggage compartment.
* Illumination is controlled from the integrated control panel, thru dark blue/white at pin 2.
INTEGRATED CONTROL PANEL has white/red for battery input (pin 11), with fuse no. 33 of 15 amps in the junction box under left side of dash; black/pink for acc. power (pin 6), with fuse 22 of 15 amps in the junction box under left side of dash; red/yellow for hot in start or run (pins 5 & 16), with fuse no. 32 of 10 amps in the same location.
AUDIO connections between the integrated control panel (front) and the rear control unit (rear) are as follows:
R+ dark blue/white wire between pin 9 of front unit & pin C388B-7 of rear unit;
R- gray wire between pin 19 of front unit & pin C388B-20 of rear unit;
L+ brown/light green wire between pin 20 of front unit & pin C388B-6 of rear unit;
L- white/pink wire between pin 10 of front unit & pin C388B-19 of rear unit.
AUDIOPHILE SYSTEM has right and left tweeter speakers branching to right and left front speakers with the same colors.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 12, 2009 | Car Audio & Video
Pioneer deh425 plug discription
I have one right in front of me and can tell you what color each wire is, from top left of plastic wiring port.
Black/ green ?
Grey/black ?
Blue Power Antennae
Black Ground
Black/white ?
Green/black ?
Red/green ? Left Lower row
Gray/red ?
Red Accessory/Ppwer
Orange Battery Memory power
Green ?
Dec 25, 2007 | Pioneer DEH-425 CD Changer
Volume and mute buttons suddenly stopped working
Try changing the batteries. Most times the "tivo" buttons will work but the "tv" buttons will stop working when the batteries are low.
If you have done that, go back into settings and program the remote again for your tv, then give it a shot.
Nov 05, 2007 | Tivo DirectTV Remote Remote Control
Lanier UNKNOWN Logo
Top Lanier Televison & Video Experts
Electro Med Services...
Are you a Lanier Televison and Video Expert? Answer questions, earn points and help others
