Question about APC Smart-UPS 1500VA Shipboard (SUA1500X93) UPS System
Beeping and clicks off - APC Smart-UPS 1500VA Shipboard (SUA1500X93) UPS System
  • fmb1994 Jun 19, 2008
    what is ac is that power? it's a 4 year old unit and I will get new batterys tomorrow.
    do you think that will do?
    Genius:
  • 1,027 Answers
When it beeps, that is the internal alarm indicating that incoming AC is not there. It probably clicks off due to the batterys not being charged.
Posted on Jun 19, 2008
I am getting a beep beep space beep beep space beep beep
if you changed out the start device or orerload and relay and the compressor is clicking you have a bad compressor
Jul 18, 2013 | LG LRFD22850 Bottom Freezer Refrigerator...
Seagate 2 tb external hard drive beeps and clicks
Hard drives are easily damaged when dropped. The clicking noise is known as "The click of death".
This hard drive cannot be fixed. You need a new one.
If you need to recover data from this hard drive, then there are companies that can recover data from faulty hard drives BUT it will cost you an arm and a leg for their services.
Aug 23, 2012 | Computers & Internet
Hi my laptop developed a strange problem. I formatted the system drive and installed a fresh copy of windows 7 ultimate sp1. now at the boot up the laptop makes loud annoying ringing bell sound for a few...
Is the "ringing bell" sound a series of beeps? A computer will have beep codes at start up for the user to identify system errors. Count the beeps, one long and 2 short or 3 short beeps or one continuous beep, etc. Then you can search to find what that specific beep code stands for. As for the the touchpad you may need to go into the system properties, right click on my computer, click properties and then click device manager on right. Click the "+" next to mice and other pointing devices. Double click on the touchpad device and then the driver tab. Click update driver and see if it finds a better driver. Or do a windows update. Sometimes the problem can be fixed there. Lastly, and oddly enough, try to take out your battery when the power cord is plugged in. I have seen cases where a bad battery can cause problems with the touchpad and keyboard. I hope one of these helps!
Sep 24, 2011 | Computers & Internet
Bios beep code on new motherboard = 3 long beeps, pause then repeat
Please click on following link and go through the complete list of beeps codes and what they mean.
http://www.computerhope.com/beep.htm
In your case 3 long beep stands for Keyboard/Keyboard card failure.
Jul 05, 2011 | Computers & Internet
Everytime I max the volume, there's a beeping noise coming from the speaker.
If you want to turn of the Beeping sound,You can disable the Beep device by doing this steps.
Just go to (right click) My Computer > properties > device manager > clicl view menu > show
hidden device > under Non-plug and display driver, go to Beep > right click then properties >
under Beep properties go to Driver > current status then press stop > under start up then TYPE >
click the window then click DISABLE.
Thank you for visiting FixYa...
Jun 28, 2011 | Computers & Internet
My laptop makes a loud annoying beep when its plugged in or unplugged. The cord is getting tired and often makes this noise for no apparent reason. I've tried to go into the speaker properties but...
this issue might be occurred due to weak battery or either battery is getting weak.Just remove the Battery for a while and check the result
Jun 13, 2011 | Computers & Internet
Del Latitude PP01L won't boot up
there may be a problem of ur RAM, it might not be fit properly in the "RAM SLOT" or it might be a hardware fault of ur RAM..
Aug 29, 2009 | Dell Latitude D600 Notebook
Dryer just says beep beep beep everytime I push start
sounds like you may have a bad door switch(mach thinks door is open when it is not).open door and look on front panel that door pushes into.you should find a small button covered in a grey rubber boot.push on it and listen for a click,if u dont hear a click the switch is bad.if u do hear a click it could still be bad or you can have a open thermal fuse
Sep 29, 2008 | Whirlpool GEW9250 Electric Dryer
Innovage (1604007) Corded Phone
Here is the fix for that problem...
1st click the set button on the bottom left of the keypad. Press the "up" button (located to the right of the the keypad) until you get to option number 7 IPP. Click the set button again (so you can change the settings for that option) and press the down button to turn off the option. Click the set button one more time and finally press the delete button to get out of your settings mode. No More beep, beep, beep......
Hope This Helped--WICC-
Feb 07, 2008 | Innovage 1604007 Corded Phone
CAMERS TURNS ON LENS OUT THEN BACK IN... 3 STEADY CLICKING SOUNDS
well i´m the bad news guy, it could be two things, or u droped the camera and the zoom lens is out of the place and the sensors arent working properly or it´s just the sensors that are no working, the only way is to send to a repair centre normally they just replace all the lens. All the beeps it´s just to say that the lens is lost.... can´t locate it self.
Feb 04, 2007 | Canon PowerShot A95 Digital Camera
APC Smart-UPS 1500VA Shipboard (SUA1500X93) UPS System Logo
273 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
