Question about Car Audio & Video
I lost the cover to of the fuse box so now I have no way of identifying which fuse goes to the right place or the wattage.
    Sergeant:
  • 389 Answers
Contact the manufacturer and see if you can get a new cover ordered by model number or search online by model number and see if you can locate a diagram.
Hope this helps....
Stormi
Posted on Nov 15, 2010
Sounds like i have the same trouble ...no radio ...dome light and door locks ....can t locate the fuse ......and nobody seems to be amswering the question ....WHAT FUSE IS IT ? LOL
you need to locate the right fuse box to start with most are under the bonnet in the motor department or behind the kick panels passenger side or drivers side , or a common place is under the dash and the fuses come in a flip down arrangement so you can inspect them, to identify each fuse and know what part of the electrical system that they are dedicated to can be found under the fuse box cover lid where it is imprinted so you can reference the fuse and it will say something like this ..... 25 amp lighter radio acc lights .... 15 amp indicator lights and regulator ....10 amp horn and park lights ... if you can not locate the fuse box because it is in a unusual or hard to find place , try looking it up in a manual on line for your make and model
Jun 05, 2017 | Cars & Trucks
What is the diagram for the inside dash fuse box?
the glove box oper guide lost.
get one?
the fsm covers that and is free.
chapter 8w>?
not only the fuse numbers but all loads on all fuses and
drum roll, the tree distribution of said wires.
page 8w-11-1 (posted like 100 times now, by many)
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
click 95 GC , wiring
really that one pdf , its all there. (can be saved too, ask)
Feb 12, 2015 | 1995 Jeep Grand Cherokee
Where is the fuse for a 1995 goe tracker and where does it go
There are several fuses in your car. The cabin fuse box is on the driver's side, left of the steering column. It's a black box just above the kick panel. Squeeze the cover to remove it -- there's a diagram inside the cover that identifies the size and function of each fuse. You also have a main fuse & relay box in the engine compartment, close to the battery.
Jan 31, 2011 | 1995 Geo Tracker
Where is the fuse box located?
Passenger compartment fuse panel / power distribution box
The fuse panel is located under the right-hand side of the instrument
panel. Remove the trim panel and fuse box cover to access the fuses.
To remove the fuse box cover, place
a finger behind the PULL tab and
your thumb above the PULL tab as
shown in the illustration, then pull
the cover off.
To reinstall the fuse box cover, place the top part of the cover on the
fuse panel, then push the bottom part of the cover until you hear it click
shut. Gently pull on the cover to make sure it is seated properly
here is a link to Ford site, u can download the onwers manual there it is free. The above info was copied from the owners manual.
https://www.fleet.ford.com/maintenance/owners_manuals/results.asp
Oct 19, 2010 | 2004 Ford F150
Lost hb mazda929 fuse box cover how do we get
Contact a local auto salvage yard (Yellow Pages under Auto Salvage) and ask for a Mazda 929 Fuse cover. They may tell you that they do not have one but... most salvage yards can do a computer search of other local yards and find it for you.
Kelly
Apr 25, 2010 | 1988 Mazda 929
1997 Mercury Sable. My sister lost the fuse box cover(interior by steering column). and I assume it had a label which identifies a fuse number location. The owners manual only identifies a fuse size and...
If you don't have the fuse information send me your email and I will send you the diagram of your fuse box with pictures. outdoorsman592003@gmail.com
Sep 04, 2009 | 1997 Mercury Sable
Where is the fuse box on a 2000vw passat
here are some try this According to the MANUAL (:-)) for the 2001 Beetle, most fuses are in a compartment at the left side of the dashboard. Place a screwdriver into the slot to pop the lid off. The Fuse Card identifies fuses with silly Symbols, and there is no Legend (on the card or in the Manual) indicating what they mean.
There are also 3 or 4 fuses in a compartment atop the Battery-box, and there is no indication (symbolic or otherwise) of what they are for.
When you open the driver's side door, it is located on the side of the dash. Just pry the cover off with a screw driver. There should also be a diagram in the cover.
Jun 30, 2009 | 2000 Volkswagen Passat 4Motion
Can someone email me where the fuse box is for a 03 corolla s and where the fuse for the compressor would be it doesn't seem to be under the hood with the other fuse's?
Under the dash, on the left side of your steering column is a narrow fuse box with a cover on it. You can remove the cover and see that it identifies what fuse goes to what. The A/C fuse is a 10 Amp.
The A/C relay is in the larger fuse box under the hood of your car. with the cover removed and looking towards the windshield, the relay is first on on the left, about 1"x 1/2" rectangular.
Jun 13, 2009 | 2003 Toyota Corolla
Fuse
you found the fuse box right?
There will be a diagram on the back side of the fuse box cover. Use it to identify which fuse belongs to the sound system.
If you don't know where the fuse box is, let me know.
If you still can't figure out the right fuse, give me the options that are in the box and I will let you know which one it is. thanks
May 16, 2008 | 2005 Saturn ION
Car Audio & Video Logo
16 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
