Question about Nespresso D150 Espresso Machine
My nespresso machine keeps blinking silmutaneously between the expresso button and the lungo button...how do i fix this?
2 Suggested Answers
SOURCE: My Nespresso citiz lungo button will only give
Ok, what you have done is programmed your machine. If you hold down the button for 3 secs you get 3 secs of coffee, so turn on your machine wait for it to warm up then without using a capsule press and hold the button until you get 110mls for a lungo and this will be stored in the memory. If this doesn't work there is a on/off switch on the right handside turn it on with your finger down on the lungo button for 5 secs and then release the button and this will take it back to factory settings.
Posted on Jan 25, 2011
My machine both Expresso and Lungo lights keep flash, how do I fix it?
Expresso is not coffee. Espresso is. So I assume you don't have a real coffee machine...
Jan 01, 2015 | Nespresso Pixie C60 Espresso Machine -...
I have no water coming into the machine, how do I fix this Nespresso D-120
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 29, 2014 | Nespresso Citizmilk D120
Why too little coffee
The machine is calibrated to produce a certain amount of water depending on which button is pressed (Lungo or expresso - larger or smaller cup). This can be altered by holding down the relevant button - check this manual..
http://www-media.nespresso.com/ecom/websites/manuals/inissia/inissia_C_krups.pdf
Aug 23, 2014 | Nespresso Inissia
Nespresso magimix
Check the relay on circuit board
Jul 20, 2014 | Nespresso Le Cube
Nespresso descaling
Make sure the machine is ON and you have power, then proceed as per instructions.
Jan 12, 2014 | DeLonghi Coffee Makers & Espresso Machines
New machine but water does not dispense
I have the same issue except sound comes but the water level in the tank is still the same
Dec 06, 2012 | Nespresso Citizmilk D120
Nespresso citiz won['t exit descaling mode
I had the same issue, and took it to the repair shop, where the guy did the same thing, just pressed both cup buttons for 3 seconds. It worked. He said the Lungo button had to be pressed a little harder, as it had some connection problem, and thats why it didnt work for me. If you have the same problem, the machine will start buzzing for about half a sec if you press the lungo button while in descaling mode.
Nov 29, 2012 | Nespresso Citiz C110
My Nespresso citiz lungo button will only give expresso amount of water
Jan 13, 2011 | Nespresso Citiz D110
When I hit the Americano button, it comes out like an espresso, not enough water comes through. I've just descaled. How to fix?
The amount of water is programmed by holding in the button. Put your cup below, and press the button. Keep holding until you are happy with the amount of water that came out - and then let go.
Next time you use it, you just need to do the normal short press on the buttom.
(Both the Espresso and the Lungo button can be programmed.)
Jul 31, 2010 | Nespresso Le Cube
Nespresso C1OOB not sucking water out of the tank anymore
I had the same issue and spoke to Nespresso this morning.  To solve this you need to reprogram-put a capsule in the slot and place a cup on the drip tray-press and hold the lungo button until the coffee has reached the desired height in the cup and then release the button.  That should work and every time you make a lungo cup it should be that amount. Hope this was helpful.
Oct 19, 2008 | Nespresso C100B Essenza Single-Serve...
Nespresso D150 Espresso Machine Logo
675 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
