Question about Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402
Leeking water from bottom - Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402
Either the bottom or top element is leaking.If not that the glass tank that holds the water could be cracked.Or lastly the drain valve could be leaking because its plastic.All of which is a fairly easy fix,just time consuming
Posted on Nov 15, 2010
  • Anonymous Nov 15, 2010
    The tank is not glass. It's made of enamel coated steel that is called 'glass lined.'
I wrote a page on leaking water heaters with resources and information:
Page lists things to check.
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html
Also run hand over tank to find warm spot that says where leak is coming from
A rusted tank cannot be repaired.
If your tank is rusted out, it might burst open and flood the area.
Hot water inside tank is under pressure.
Turn off heat source to water heater.
Turn off water valve located above tank.
Open tub faucet on hot side and relieve pressure from tank.
You can limp along with a leaking water heater by turning it on when hot water is needed.
For example a shower uses 5-9 gallons hot water.
Turn gas water heater on for 15-20 minutes.
Turn electric on for 20-30 minutes.
To conserve resources with next heater:
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Leaking water
shut off the water supply !!! look real carefull at direction of leek (not just down) as there is a temp/press valve on side that can leak , that's easy to change but if leak is coming from bottom heater needs to be replaced , quickly b4 it ruptures and dumps all 60 to100 gal of water to your floor !!!!
Aug 15, 2016 | Water Water Heaters
Greenstar 30si
this is your safety valve letting by first try and check ur pressure bladder shud b 28lbs squr inch if it isnt pump up to 28 what happens if the bladder has no pressure then the water has no were to go but out through to pipe water expands when hot and thats why un have to top up the other problm is safty valve worn out needind replacment hope this helps u Susan
Sep 21, 2013 | Water Heaters
After freezing weather the Noritz N-0751M-OD started leeking water and now there is no power to the unit or panel..is the unit toast?
I believe you killed it,I've installed two units direct vented through side wall in Minnesota and the cold wind blew in flu and froze up units,water stopped running in houses so we were able to save
Jan 28, 2011 | Noritz NORTIZ Outdoor Propane Tankless...
I have a forty gallon electic rheem water heater with a pipe going in the bottom and one in the top which wone is the cold water inlet the bottom????
The one with the pipe going to the bottom is the cold...cold water goes in on the bottom and the hot comes off of the top...hot water is lighter then cold water and rises to the top...
heatman101
Oct 11, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Cold water pipe is leeking...place a bucket under it but fills up fast...plumber will be her tomorrow what to do in the meantime
Find valve ahead of the filter and turn it off. If you can't find that turn off all the water in the house.
Jul 21, 2010 | General Electric GE SmartWater Household...
It quit working and I removed panel and reset it.now it seems to make the water hoter and it is making constant noise and leeking a little from the pressure relief valve
The pressure relief valve is bad if it is leaking due to too hot of temp or it has gone bad. If it is hotter turn down the temp on thermostat and see if it quits dripping..
If it's making a noise it may be heating the water the way above the limit for the relief valve.
If it is the relief valve they have them at most hardware stores and can be replaced. When installing use teflon tape on threads if this is the problem.
May 21, 2010 | Water Heaters
I have hot water for a minute then it goes to warm. I took off the 2 wires on each element and I have 15 ohms on the top and 5.5 on the bottom. Is my bottom element bad?
Sounds like bottom element may be bad but usually reads open circuit if bad. Also tan k would run about 8 gallons hot water then go cold. lots of warm water usually means bad dip tube.
Check if tank is hot at bottom element when not used for a while. If bottom element is still cold then bad element.
If bottom element is hot - (all water in tank is hot then you have a bad "dip tube" This is allowing incoming cold water to mix with outgoing hot water. The dip tube is usually A part of the cold water nipple or B located under the cold water inlet nipple.
Jan 18, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Combi boiler wont re-pressurize when i turn the little valve under boiler it just seems to run and run and the pressure gauge dosent go up at all? there are no leeks. but a minute a go it went right up to...
the little valve is a one way type. this means the pressure should only flow one way. it's a good chance that the valve body is allowing the pressure to back flow. i would replace that valve. this should take care of it. please rate this thanks
Aug 29, 2008 | Water Heaters
Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402 Logo
276 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
