Question about Microsoft Xbox® 360 Core System Console
Xbox 360 has an "E-74" error. 1 ring lit.
  • Mike57 Nov 16, 2010
    Does it really provide a solution? I hate to spend $$ if its just a scam.
  • 122 Answers
This type of error occurs in xbox usually..dont worry u can easily solve it by visiting this site..its working ..i also did the same when it happen to me
Posted on Nov 15, 2010
Xbox 360 elite showing no picture on screen...?? Have tried both HDMI and composite cables. Any suggestions
If the console turns on (you hear fans running and the ring of light is lit), possible issues may be:
1. TV is not on the correct input setting.
2. Graphics card failure (If under warranty, you should be able to send the console to Xbox for refurbishing).
3. Other hardware/software failure.
If the console doesn't turn on (No fans or lights), check the following:
1. Is the power brick plugged into a wall socket?
2. Is the Xbox plugged into the power brick?
3. Is the power brick LED lit? (If you answer no to this, the power brick is likely the problem.)
Mar 10, 2011 | Microsoft Xbox 360 Elite Console
How do i fix an error 74 on an xbox360
The E74/E6x/E4x/E8x are famous error codes that have plagued many Xbox 360 gamers. This error codes will be displayed on your screen, each indicating different problem with your Xbox 360. It's usually defined by the single red light or 1 Red Light Error lit up at lower right quadrant on the Red Ring of Light on your Xbox 360 console.
E74: There is high chance it's a scaler chip problem (the "ANA" or "HANA" chip near the AV cable connection) it can also be caused by a faulty AV cable so check that first. In some cases it is a problem with the GPU and may be repairable by using the Xbox 360 Repair Guide. Xbox 360 E74 error has reported to increasing a lot for the newer Xbox 360 version.
Hope this was helpful?
Feb 26, 2011 | Microsoft Xbox 360 Console
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
When you turn on the console it has a weak hum and there is only one red ring where the 4th player green ring is supposed to be and its on a black page and it says"system error. Get help." or...
E74 is due to an inherent engineering flaw and will continue on new consoles until Microsoft institutes a revision.
Call Microsoft XBOX support and provide with them with your Xbox's serial number and the description of the error code.
u can download repair guide click here
Dec 17, 2010 | Microsoft Xbox 360 Console
When i turn on my xbox I get a the "red ring of
order the red ring of death self repair kit,,very simple,,also try blowing xbox out with a aircompresser,,worked for mine,,and geta hex head screww driver tighten screws on the botom of xbox 360,,,may hlp...
Nov 03, 2010 | Microsoft Xbox 360 Console
Red rings on the xbox 360 wont connect to live wont let me recover gamertag
The red rings are a fatal Xbox 360 error. There is no way to solve this problem except by having a qualified professional perform a reflow to the problem Chip. This can usually be determined based on the number of quadrants lit.
  • 1 Red Quadrant is usually System Error. A "E##" error code will be displayed on the screen. Most common is E74.
  • 2 Red Quadrants indicates the console is overheating.
  • 3 Red Quadrants indicates hardware failure. A secondary error code can be acquired by pressing and holding the sync button then while continuing to hold the sync button repeatedly pressing the eject button and noting the number of red quadrants that becomes lit.
  • 4 Red Quadrants indicates that either no A/V (Audio / Video ) Connection is available.
Good Luck! Let me know if you have any further questions. If you tell me which number of quadrants or the error code I can point you in the right direction.
Jun 04, 2010 | Microsoft Xbox 360 Console
3 ring
We can help in getting the red ring of death fixed for you. Contact us at 888-389-3038 for a free quote today.
- You've been helped by a Wired Extreme technician.
Apr 16, 2010 | Microsoft Xbox 360 Pro System Console
Xbox 360 system error
How many quarters of the red ring are lit? 3 of 4?
If 4, you need to check your audio/video cable.
If 3, you need to contact Microsoft support for a repair.
Dec 12, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox® 360 Core System Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
