I have a lap top that doesn't turn on, my friend told me that is the mother board, I just want a second opinion. Thank you
    Brigadier General:
  • 10,406 Answers
It could be the power-supply unit.
It could be a "tripped" circuit-breaker in your home, not getting any power to the power-supply.
It could be the motherboard.
It could be the on/off switch.
Posted on Nov 15, 2010
My screen is black what can i do
You can: try to restart the camera. and if that doesn't work:
plug the camera into your lap top and access its menu. You may have dropped it and split some mother board connections unknowingly, if so the screen probably cant be fixed
Aug 20, 2011 | Kodak EASYSHARE Z1485 IS Digital Camera
How to unlock bios of toshiba portege m500
two options
1. look on the mother board for a small round battery about the size of a nickle, remove it, start pc, after start up shut down, replace battery, start up again... or remove battery, let sit for about 30min, replace battery start pc.
2. look for a small red or yellow toggle switch or button on the mother board, (should say "reset bios") push button, restart pc.
i assume this is a lap top so there will be some disassembly of the unit, not to extreme though, usualy the battery and the switch/button are next to one another and located toward the front of the mother board, and if in lap tops the battery or batteries are in a plastic covering wired to the mother board with a small connector, just unplug connector if you cant find the reset button.
hope that helps
Mar 23, 2011 | Toshiba Computers & Internet
Sound error, no sound card no mixer
hi, first you need to know ur mother board model number, once u get to know that try google to search for drivers based on your motherboard. You should find all the drivers required. Also if ur mother board has a inbuild sould card the sould drivers could easily be found online
Jul 05, 2009 | Packard Bell (030069) Sound Card
Acer turning off
Yes this does sound like a mother board problem replace the mother board.
Feb 05, 2009 | Acer (ACERMOTHERBOARD)
White thin line verticaly middle of lap top screen
Sounds like the monitor. Do you have another monitor to hook up to the laptop? If so, that will tell you precisely if it's the monitor or video card.
Dec 21, 2008 | LG Flatron L1750S 17" LCD Monitor
Mother board
If your PC is still in warranty, call the manufacturer for a possible warranty repair.
Otherwise, no offense, but if you are asking this question, you should probably take it back to the shop and let them fix it. You could always get a second opinion from another shop if you suspect foul play. Make sure they back up your personal files from your hard drive, if they decide they must reinstall the operating system.
Oct 29, 2008 | Computers & Internet
Laptop won't turn on
If you know someone who has the same laptop, try testing your battery and adapter on that laptop just to make sure that they are working fine. If not, it might be a motherboard issue and replacing a laptop motherboard would cost a lot.
If you have a geek friend, ask him/her to use the multimeter to check that the power supply is delivering the correct voltage to the motherboard.
If you dont, try to get another opinion from another place to check if they say it's the same problem.
Oct 27, 2008 | Gateway (4000274) Motherboard
I have problem agian
Several things you need to check before replacing actual parts.
First, check the connection to the inverter for the lcd. Sometimes the connection can become loose causing a blank lcd but the motherboard is working fine. Next would be to actually replace the inverter if only the lcd does not power on at all. Even if lcd is blank you can see that the lcd is on but no picture in which case your video card could have failed and in many cases requires changing the motherboard because video is integrated into the board. Good luck.
Aug 16, 2008 | Computers & Internet
System board
I hate to say your getting scammed but...........
First. Price for service is unreasonable.
Second, Slow boot=new mobo? I am very sceptical about that diagnosis.
A few questions if I may.
Are there more than 6 icons in your system tray?(lower right corner)
Are there any programs in the startup folder? Start/allprograms/startup.
Have you de-fragged the comp in a while?
After that, consider this. Can you get a newer laptop for 700 bucks? OK, not as nice as yours. Isn't it still under warranty?
Jan 26, 2008 | Toshiba Satellite P25-S5263 Notebook
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
