I am looking for a manual for an Ager Air Conditioner model RCM-220H can you help? Thanks Rod
flatech
  • 111 Answers
SOURCE: Hello
You can download the PDF owners manual from here just go to service and pick your Model type.
http://www.convair.net.au/Convair_Service.htm
Good Luck!
Posted on Nov 13, 2009
  • 34 Answers
SOURCE: looking for a panasonic r410a air conditioner
To change between heating / cooling / fan / dehumidify / auto, press the mode button. Each time you press it , it goes to the next mode.
Posted on Apr 24, 2010
  • 34 Answers
SOURCE: can't find a manual for air conditioner
BTU means "British thermal units" and is a measurment of cooling and heating capacity. Other units are Kw "Kilowatts", and HP "Horse Power".
To convert
Multiply by
To obtain
kW
1.341
hp
kW
3,413
Btu/hr
hp
2,545
Btu/hr
Posted on May 21, 2010
SOURCE: Air Conditioner Error code?
I have a portable air conditioner by Airlux and todat an error code is on the display reading E5. What does this mean and how can it be fixed? thx
Posted on Jul 08, 2010
SOURCE: our ager air conditioner seems to revert to timer
Seeking to purchase a remote control.
Air Conditioner Brand: Ager
Code on Remote control back: ZH/LW-03
Posted on Feb 15, 2011
I need manual for Garrison 5200 btu window a/c. Where can I find one? Thanks
You will need the complete model number which looks like the following 123-4567-8. The manual can be viewed\downloaded from http://www.manualslib.com/brand/garrison/air-conditioner.html by selecting the correct model number as described above. If your model is not listed you can call customer support at 800-387-8803.
Hope this is helpful.
Aug 02, 2016 | Heating & Cooling
Does the GE APE08AJM1 air conditioner come with a dehumiderfer on it?
Yes, the unit has a 4 pint per hour dehumidifier as one of it's features.
More information on this model portable AC unit and a look at & print it's Owner's Manual, click on the following link. http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=APN10AA
I hope this helped you and thanks for choosing FixYa.
Sep 07, 2011 | GE APN10AA Portable Air Conditioner
Looking for a free Manual for a Model MOB 10KDCR mobbil air conditioner
To have an Owners Manual emailed to you in a pdf format, call Boston Innovative Products, Customer Support 1-866-454-2588.
Hope this helped you. Please let me know. Thanks.
Jun 15, 2011 | Heating & Cooling
Searching for instruction manual for ZH/LW-01 remote for ager a/c
look you yonan mini split in USA - one of their dealers has both manuals posted
Feb 04, 2011 | General Heating & Cooling
Looking for a panasonic r410a air conditioner manual Its a CSE18GKR Model.The place that i rent doesnt have a manual for it. Thanks 4 yr help Donna
Apr 20, 2010 | Heating & Cooling
Dash lights went out, so i had some fuses removed to see which one was bad. next thing i know the airbag light was on.
You just need to turn it off again. You created a false trigger of the light. You may have to have dealer do it with scan tool.
Prove Out Procedure
Turn the ignition switch from the OFF to the RUN position and visually monitor the air bag indicator with the air bag modules or restraint system diagnostic tools installed. The air bag indicator will light continuously for approximately six seconds and then turn off. If an air bag supplemental restraint system (SRS) fault is present, the air bag indicator will either:
  • fail to light.
  • remain lit continuously.
  • flash.
The flashing might not occur until approximately 30 seconds after the ignition switch has been turned from the OFF to the RUN position. This is the time required for the restraints control module (RCM) to complete the testing of the SRS. If the air bag indicator is inoperative and an SRS fault exists, a chime will sound in a pattern of five sets of five beeps. If this occurs, the air bag indicator will need to be repaired before diagnosis can continue.
----------------------------------------------------------- Restraints Control Module (RCM)
The restraints control module (RCM) performs the following functions:
  • signals the inflators to deploy the air bags in the event of a deployable crash.
  • monitors the air bag supplemental restraint system (SRS) for faults.
  • illuminates the air bag indicator if a fault is detected.
  • flashes the air bag indicator to indicate the lamp fault code (LFC) detected.
  • communicates through the data link connector (DLC) the current or historical diagnostic trouble codes (DTCs).
  • signals the generic electronic module (GEM) to activate a chime if the air bag indicator is not available and another SRS fault exists.
NOTE: The safing sensor is internal to the RCM and is not repaired separately.
The RCM monitors the SRS for possible faults. If a fault is detected while the ignition switch is in the RUN position, the RCM will illuminate the air bag indicator located in the instrument cluster.
When the ignition is cycled (turned off and then on), the air bag indicator will begin its prove out sequence. During prove out the air bag indicator will illuminate for six seconds, go off for two seconds and then, if a system fault exists, flash the two-digit LFC. The air bag indicator will flash the LFC five times, then it will remain illuminated for the rest of the key cycle. The RCM will also communicate the current and historical DTCs through the DLC, using a scan tool. If the air bag indicator does not function, and the system detects a fault condition, the RCM will signal the GEM to activate an audible chime. The chime is a series of five sets of five tone bursts. If the chime is heard, the SRS and the air bag indicator require repair.
LFCs are prioritized. If two or more faults occur at the same time, the fault having the highest priority will be displayed. After that fault has been corrected, the next highest priority fault will be displayed.
The RCM includes a backup power supply. This feature provides sufficient backup power to deploy the air bags in the event that the ignition circuit is damaged in a collision before the safing and air bag sensors determine that deployment is required. The backup power supply will deplete its stored energy approximately one minute after the battery ground cable is disconnected.
Electrical System
The electrical system that supports the air bag supplemental restraint system (SRS):
  • is powered from the battery through the ignition circuit.
  • provides the electrical path from the restraints control module (RCM) to the air bag modules.
  • provides the electrical path from the RCM to the air bag indicator.
  • provides the electrical path from the RCM to the data link connector (DLC).
  • provides the electrical path from the RCM to the generic electronic module (GEM).
Restraints Control Module (RCM) Diagnostic Trouble Code (DTC) Priority Table DTC a LFC b LFC Priority Description Action To Take — — 1 The Air Bag Indicator is Illuminated Continuously — RCM Disconnected, Inoperative, or Lost/Low Ignition Feed Go To Pinpoint Test A . B1342 24 2 RCM Is Faulted INSTALL a new RCM. B1231 19 3 RCM Crash Data Memory Full INSTALL a new RCM. B1921 21 4 RCM Bracket Ground Resistance High Go To Pinpoint Test B . C1414 29 5 Incorrect Vehicle Identification Code Go To Pinpoint Test C . B1887 15 6 Driver Air Bag Circuit Shorted to Ground B1916 15 7 Driver Air Bag Circuit Shorted to Battery or Ignition B1888 16 8 Passenger Air Bag Circuit Shorted to Ground B1925 16 9 Passenger Air Bag Circuit Shorted to Battery or Ignition B1932 32 10 Driver Air Bag Circuit Resistance High B1933 33 11 Passenger Air Bag Circuit Resistance High B1934 34 12 Driver Air Bag Circuit Resistance Low B1935 35 13 Passenger Air Bag Circuit Resistance Low B1892 — 17 Air Bag Tone Warning Indicator Circuit Shorted to Ground or Open B1891 — 18 Air Bag Tone Warning Indicator Circuit Shorted to Battery or Ignition B1869 Tone c 19 Air Bag Indicator Inoperative B1870 Tone c 20 Air Bag Indicator Shorted to Battery — — — No Communication with the Restraints Control Module
Feb 24, 2010 | 2004 Ford Mustang
Error "FL" is coming It is not going by applying suggesstion in your booklet kindly enlighten
Mar 16, 2009 | Haier Energy Star ESA3183 Air Conditioner
Heating & Cooling Logo
510 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
