Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
The picture will be okay one minute and then it will go green off and on
  • 10,594 Answers
It seems green picture tube in this Sony KP51WS510 rear projection became defective and causing this problem. Replacement of green picture tube will fix this issue but it would be costly fix and professional will do it as it requires lots of adjustments after tube replacement.
Please check with local vt repair shop and ask an estimate of repair.
Thanks.
Posted on Nov 15, 2010
Green light flashes when i stop for a few minutes
Hi, okay but does the scooter still run okay ? if so, it maybe warning you that the batteries are getting low, sometimes the voltage detection circuit can get sensitive or simply faulty.
Regards
Rob
www.gewizrepairs.co.uk
Dec 31, 2013 | Lynx L-4 Motorized Scooter
Evenly spaced vertical lines
Hello
Check the smoothing capacitor to video output supply voltage, usually derived from any one winding of the LOT. It will come around 10uF350VDC to 47uF 350VDC range. If this capacitor is faulty, or gone less in capacitance with time, this type of fault will occur. Check the green volour output transistor on the video output card, can be located attached to the neck of the picture tube; for any loose soldering or leakage. OK.
Oct 19, 2011 | JVC AV-32P903 32" TV
Tv okay when switched off last hight.This mirning
make sure the lesrd are pushed in on dvd avd tv
Dec 16, 2009 | Sharp Televison & Video
Sony 65" Rear Projection loses picture, then gets diagonal lines
This is common problem on this tv, picture tube is bad. Blue and green is more % bad.
Thank you
Aug 07, 2009 | Hitachi 51F59 51" HDTV Projection...
After few minutes LCD picture went black but sound works ok
most likely the power inverter, also suspect the p/s. best to have a trained tech check it. Julio at milleniumtvsvc@gmail.com
Jul 21, 2009 | Memorex MLT3221 32 in. LCD TV
Rca d52w14 hit power green light blinks three times wont come on
could be power supply problem or high voltage problem. check caps in main power supply first.look for caps that have tops puffed up ususlly three or four.....
Feb 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Pictures are coming out green
It seems like the previous owner messed with the color effect feature on this phone. After you take the picture and its under your picture file, you can edit it. view the picture and go to options. scroll down to image editor and clikc okay. click on tools (right hand side). scroll down to color effects and click okay. now you have a menu where you can change the coloring of the picture. You may want to try the enhance green feature first and make sure its not set completely to the +5. The default settings have red, green and blue all set at zero. Hope this helps!!
KC
Oct 26, 2008 | LG Shine KE970 Cellular Phone
Nikon D80 Green Dashes
is it a logic line or like a dust thing?
try anyway just to see if it happens in a different computer so we can be sure about that
Jul 30, 2008 | Nikon D80 Digital Camera with 18-135mm...
No Picture - Lamp Indicator Blinking
This may be the main power supply, or the lamp supply. This is providing that the new lamp is okay.
The service tech will swap out the modules to service the set.
Jerry G.
May 15, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
479 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
