Question about HP OfficeJet d145 InkJet Printer
Having printing problems-Won't print my fed-ex label
  • 15 Answers
SOURCE: Zebra 105se blank labels problem
I would say the roller isn't the problem. I had the same problem on many Zebra printers, but often the calibration helped. Then it could do, when printing task label is for larger/longer than the label size is set in the printer system (conflict of software with printer settings after calibration). It could be set too down to bottom in Y axis. Or it could be in the software settings - as action after print - not sure.
Try to open the printer queue while the label is printed and check if the label has proper number of pages or there's 1 page more. If it is the right number - then the problem is on printer side (recalibrate, reflash it). If the number is about 1 higher, the problem is with settings of the label size (barcode software, printer settings) or action after print on PC side.
Posted on May 30, 2008
SOURCE: Label Printing
I had the same issue when using Avery labels, here's what resolved it for me.
Go to Control Panel, Printers, go to the active default, right mouse click, click Printing Prefrences..., change the drop down "Type is:" to 'Other Photo Paper" and apply.
You should then be good to go!
Posted on Aug 27, 2008
  • 2976 Answers
SOURCE: print problem
You should make sure you have the label program set for the same size label you are printing and calibrate the printer before you start a roll.
Posted on Feb 05, 2009
SOURCE: HL-2030 printer won`t print labels with Word 2007
If it's the same as my Hl-5250DN, you have to use MP Tray mode. The MP (multi-purpose) tray is cleverly hidden on the front of my printer.
Posted on Feb 25, 2009
Sakeninja1
  • 5 Answers
SOURCE: PRINT WILL NOT STAY ALIGNED ON EACH LABEL-RUNS ONTO NEXT LABEL
Check the tension on the Ribbon Take-up Spindle there is a nut on it that sometimes can loosen or tighten its self and will throw off the lables. Its a nut that has a of couple Hex nuts on the corner, screw the nut to about the 3rd thread from the top of the bolt facing you then tighten the hex nuts on the corners of the nut. Then try printing the labels make sure the media guide also is set to the lable size that is installed.
Posted on Mar 27, 2009
Label splits
because if label lengh is ex. 20mm and you set up label print area as 21mm, it will over the size and it will skip the next one. the print area shoul be less than the label length. please verify software or driver.
Jan 22, 2014 | Zebra LP 2844 Thermal Printer
Printing and counting problem with Zebra ZM400. We have connected a Zebra ZM400 to our network and we now have a problem with printing. When we print he prints the labels 1 by 1 instead of de total...
if you sending a file (ex. pdf or picture). to the printer, can do this, if you send the proper format with normal fonts (caracteres))to the printer, work fine. build new label from zebradesigner
May 20, 2010 | Zebra Z4Mplus Label Printer
I have pixma mx300 Can I print CD labels? Thanks Bryan Will my Cannon Pixma MX300 print Cd Labels.For standard printing the paper is fed from the back.
You can print adhesive sheet labels (such as avery 5931/8931) with no problems. Some canon printers will also print directly on CDs; check this website: http://damnprinter.com/. They have lists of printers that will work and pretty good instructions. I didn't see the MP300 listed. I managed to get a canon 6600D printer to print directly onto CDs, but I had to buy a tray (ebay-$12.00) and it took about an hour to convince it to do the job. The website says to follow the steps "several" times if necessary; it took a while.
Aug 03, 2009 | Canon Office Equipment & Supplies
Printing problem
Problem has been solved, thankyou,
Printer was unistalled and then re-installed.
Jul 22, 2009 | Citizen CLP-521 Thermal Label Printer
Zebra LP2844 Thermal Printer won't print from a browser
I posted this problem last week and since that time discovered the problem (at least for me). I had to replace the HD and failed to update a current version of Java. Without Java in place I could call for it to print but the print job would disappear into thin air. After installing a current version of Java the machine began printing again and has worked perfectly.
Jan 14, 2009 | Office Equipment & Supplies
May 30, 2008 | Zebra 105Se Thermal Printer
Labels printing in reverse order
It's not the printers, has to be the software.
Contact your vendor for support.
Steve
Mar 04, 2008 | Zebra Stripe S600 Thermal Label Printer
Label Printing
Feb 10, 2008 | HP DeskJet F380 All-In-One Printer
Print Problem?
There are two small "hooks" that feed the tape through on the tape cartridge. Make sure the tape is fed through both hooks.
Jan 15, 2008 | Dymo LetraTag QX50 Thermal Label Printer
Printing out of square
If the problem is with the single sheet feeder try running regular paper through it - does it have the same issue? Is the paper skewing as it is fed in or is the print itself. If the paper is skewing look for problems with the feed rollers possibly a label has become attached to one of the rollers. If not try cleaning them with (90% or better) isopropyl alcohol on a soft rag
Jan 13, 2008 | OKI B4350 Laser Printer
HP OfficeJet d145 InkJet Printer Logo
185 people viewed this question
Seeker5211
Seeker5211
