Question about Whirlpool Refrigerators
My tenant reports that the upper freezer section gets cold, but the lower refrigerator section does not. The refrigerator is 19 months old and was purchased from IKEA. Is there anything I can do to fix it? How do I find a qualified repair person? Thanks
    Guru:
  • 1,524 Answers
Http://www.acmehowto.com/howto/appliance/refrigerator/check/defrosttimer.php
Posted on Nov 15, 2010
Fridge does not get cold during propane gas function only. Upper Freezer section does. Whole unit does perform and freeze and cold function fine with electric and generator function. Why only during...
According to the manual the following is the most likely items to cause that failure. But since it is only in the frigerator section and not the freezer section it could be the lower circuit board.
LP Gas
Orifice
Flue Baffle
Flue Tube
Burner
Lower Circuit Board
Sep 10, 2011 | Dometic RM2652 Refrigerator
Not cooling 1/2 the refrigerator and freezer
If the lower section of the freezer is whats freezing and not the upper portion, or fresh food section,what you need to check is the fan in the freezer to see if its running to circulate the cold air
Gene
Aug 12, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
I have a freezer top refrigerator in a rental unit of mine. It is only a few months old. My tenant said the freezer is working fine, but the fridge is not cold. He has tried putting the cold switch in...
Have him put a thermometer in a cup of water overnight and set the upper freezer
knob to the middle position and the temp control to midpoint. The refrigerator temp should
be between 34 and 38 degrees. You can get a thermometer at walmart or an appliance
parts store. If you continue to have the problem then change out the defrost termination
thermostat (this was a common failure in many of my frigidaire units). It is located in
behind the freezer back panel, it is clipped to a tube and has two wires coming to it.
Remember to unplug unit before servicing. The part is under 20 dollars usually.
The model number is located in the fresh food compartment on the left side. Hope this helps
Apr 25, 2011 | Frigidaire Refrigerators
Kenmore 106.536323000 S/S: Not Cooling Enough
YOU HAVE A DEFROST PROBLEM. FROST HAS BUILT UP SOMEWHERE AND THE FAN CAN'T BLOW PAST THE BLOCKAGE. OR ONLY A SMALL SECTION OF YOUR COILS IN THE FREEZER ARE COOLING DUE TO A CLOGGED FILTER OR BAD COMPRESSOR. PULL THE BACK COVER FROM INSIDE THE FREEZER AND LOOK AT THE COILS. THEY SHOULD HAVE A LIGHT FROST AVER THE ENTIRE COIL.IF IT IS A BIG BLOCK OF ICE YOU HAVE A DEFROST PROBLEM.
Oct 28, 2009 | Kenmore 53642 / 53644 Side by Side...
Does the single temperature control guage affect both,freezer and
check in the freezer section for a knob to control the freezer. Turn this knob back to center and return refrigerator setting to 5. What is happening is the freezer control is just a baffle that divides the air flow into the fresh food and freezer section. If the freezer knob is turn to 1 or cold it is sending all the cold air into the refrigerator, then when you turn down the actual cold control, the system isn't allowed to run long enough to allow the freezer to stay frozen.
Jun 19, 2009 | Kenmore 64802 Top Freezer Refrigerator
I have a GE GSS25WGMD BB Fridge. I have already replaced the Defrost Heater and Freezer Thermostat. The lower sections of the fridge and freezer are very cold. The ice maker will not produce ice and the...
First, when the refrigerator is running, open the freezer door and hold in the light switch so the freezer light goes out. You should be able to hear the freezer (evaporator) fan running. If it is running, then you most likely have a problem with the air damper. It is a motorized door in the very upper left side, back corner, of the fresh foods section. The door needs to be open for air to flow into the refrigerator section. If you place your hand near the vent holes at the upper refrigerator section and the freezer fan is running, FF section warm, you should feel cold air entering. If not, the damper door may have broken. It is not real easy to get at to replace, but that is where your problem may be. Be sure to check the freezer fan first, as a non-working icemaker may point in that direction.
Jun 09, 2009 | GE GSH22JFR Side by Side Refrigerator
Profile refrigerator section not cooling
We are not sure what precipitated the temperature swing up; however, within about an hour of emptying quite a lot of foodstuffs from top and bottom sections of the unit, I felt the cold air start to flow out of the rear vent. Within two hours, the upper section had dropped to about 50 degrees and by the next morning to 36. The freezer seemed to recoved on its own too, having risen to almost 8 degrees and then recovering to 0. Just patience and a smaller food payload?
Oct 02, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
125 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
