Question about LG LFX25975ST (247 cu ft) Side by Side Bottom Freezer Commercial French Door Refrigerator
I open the frige and no light or compressor sound. I checked the power source and no issues.... how do i reset the power board control ??
    Guru:
  • 1,524 Answers
Http://appliancedigest.com/index.php?/files/file/135-lfx25960xx-lg-247-ft-french-door-refrigerator-with-ice-in-door-service-manual/ Closes I found.
Posted on Nov 15, 2010
My samsung frige, french doors keeo ringing
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Mar 19, 2015 | Samsung Refrigerators
GE refrigerator profile arctica Not cooling frige or freezer PTS25LBMARBB
well if the compressor dont have power so how could it work or cool?
Jan 16, 2008 | Refrigerators
Ge profile frige does not run but still lights up. both fresh and freezer not cooling. 5 years old. controller inside fresh does not work or light up.
Time to unplug the refrigerator. We need to check the compressor, start capacitor and start relay. If you do not unplug the internal overload inside the compressor will be damaged.
Your refrigerator has a control board located on back behind a cover that is tightened in place with sheet metal screws. With the refrigerator unplugged I want you to open the cover and examine each side of the board for burn marks or loose solder connections. IF you are not comfortable to do it. its time for the fridge to be service and replace burn our parts.
Jan 19, 2011 | GE PDS22MIS Bottom Freezer Refrigerator
Had power outage now everything in my freezer/ frige has one bad is there a reset button the i need to push to reset obtw I have a samsung refrigerator
in the lower rear area there is a cover for the compressor,remove it and in there will be a circuit board replace it as this controls all functions of the unit
Dec 22, 2010 | Samsung RS2534 Side by Side Refrigerator
Control board reset?
Amana version of adaptive defrost : Press refrigerator light switch five times in six seconds to initiate defrost cycle. Pressing five more times within six seconds will cancel defrost and go straight into the run mode. Similar operation on both bottom mount and SxS refrigerators. After the defrost terminator/thermostat opens, six minutes of dwell time occurs before the compressor and condenser fan motor will operate. After defrost terminator/thermostat open, 10 minutes of dwell time occurs before the evaporator fan motor will operate.
May 04, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
The tv is a samsung DLP model sp-50l2hx the plroblem is the tv does not turn on every time and when it does it gives a raster with yellow patch and remote,OSD does not function.
Sounds like you have two seperate problems. First one may be a system control issue, or power supply issue, the second one sounds like a bad light engine and that is expensive! Good Luck!
May 31, 2008 | Samsung Televison & Video
Frige is not cooling
Check the power start relay. This is what turns on the compressor. I had same problem ( one of many) and the power start relay was bad.
Dec 27, 2007 | KitchenAid Superba Architect KSCS25INSS...
GE Refrigerator: GSS22SGRF SS - Not Cooling; Not dispensing ice or water; clicking noises
U need a new wr51x10101 heater harness 35.50 $ there is an ice build up on your coil defrost coils replace the heater harness U should B good to go
Oct 25, 2007 | Refrigerators
GE GSS22sgrf ss - Side-by-side refrigerator
I need to make sure that your refrigerator model and make numbers are listed correctly. Im having trouble with the information listed above your comments. I have GE data base and want you to look at the hyper link listed below.  and let me know if this or I can help lead you in the correct direction, Thanks, Sea Breeze
http://www.appliance-parts-warehouse.com/general-electric-parts/General-Electric-Refrigerator-Parts-Page-6901.cfm
Oct 25, 2007 | GE GSS22JFMWW Side by Side Refrigerator
Frige not cooling and click noise.
Sounds like a relay is chattering on the board. First thing would be to change that circuit board, it controls pretty much the whole unit. Make SURE the clicking is coming from the board and NOT the compressor though! See item 801 below http://www.partselect.com/Schematics/GE/00118404i08.gif
Feb 05, 2007 | GE GSH25JSRSS Stainless Steel Side by Side...
LG LFX25975ST (247 cu ft) Side by Side Bottom Freezer Commercial French Door Refrigerator Logo
303 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
