How do you replace the bulb in a philips dlp model number 60pl9220d/37?
  • 8,457 Answers
Go to website like Youtube.com.Type in ur DLP tv make and model.U will have a tutoring video by some body doing the projection lamp bulb replacement.
Posted on Nov 15, 2010
I have a 60pl9200d/37 philips dlp tv. I replaced the bulb with a brand new one and I am still receiving the bulb issue indicated by the blue lights. Any ideas?
I don't know the model but it would seem a reset would do the trick. See if there is a button on the cpu board and that should do the trick if not try unplugging a re plugging unit . Logic needs reset by a switch or by removing power
Feb 19, 2015 | Philips Televison & Video
I have a Phillips DLP model # 60pl9220d/37 and when I turn the tv on I get a really dim screen. It's almost impossible to see. I have been able to mess with the brightness, contrast and all that but it...
Are you able to make out the picture, does the brightness and contrast do anything when you turn them up?...Below is a link to the manual, not sure if that will help or not
Philips 50PL9200D User Manual
Feb 09, 2018 | Televison & Video
Philips tv 60pl9220d/37 flashing red and blue light on power button
This is a fault code. You must look for it in its repair manual. Check this, and see whether it can help you. There is detail about how to count these blinking, and convert them into code. This blinking code will help you to locate the faulty section circuit board inside it.
Jan 08, 2013 | Televison & Video
I have a philips 60pl9220d/37, and when I turn the power on there's a red light i'n the middle of the blue circle and was wondering what it ment and what caused it.
It means your tv is over heating, the bulb. In this case you are most likely to buy a new bulb soon as the bulb is heading into the end of it life.
Apr 24, 2011 | Philips Televison & Video
I have a Philips model number 50PL9220D/37 and it turns off after about 30 seconds and a red light on the left hand side of the power button comes on. Not sure what to do.
I have a Philips model Problem with the Philips 50PL9126D/37B 50 in. HDTV DLP TV I have a Philips model number 50PL9220D/37 and it turns off after about 30 seconds and a red light on the left hand side of the power button comes on. Not sure what to do.
Apr 22, 2011 | Philips 50PL9126D/37B 50" DLP TV
Philips 60pl9200D/37. Two Red lights on power button.
If the power button is displaying the bulb fault indicator AND overheat indicator lights at the same time, it indicates a faulty cooling fan. The television is smart enough to detect when either of the two cooling fans in the chassis have failed, or aren't spinning fast enough. To prevent overheating and damage, the set will not turn on if a fan is faulty. You'll need a replacement fan.
Jun 20, 2010 | Philips 60PL9200D Projection Televisions
MY TV TURNS ON AND STAYS ON FOR 5SECONDS AND THEN THE SCREEN TURNS BLACK BUT CAN STILL HEAR THE SHOW PLAYING. TURNED IT OFF AND EVEN UNPLUGGED IT FOR ABOUT 5 MINUTES, BUT STILL THE SAME THING HAPPENS.
the lamp is likely bad .. they only work a few thousand hours .. then must be replaced .. your lamp can cost a couple of hundred (maybe even more if bought locally) .. here is one for less if you have someone handy that can change it.......
http://www.purelandsupply.com/50PL9126D-37-Bulb-Philips-DLP-TV-Bulbs.html
..... of course make sure power is off (unplugged) and make sure things are not hot .. there is usually a little cubby in the back where the lamp is located .. you an see what the lamp looks like at the above URL .. dont get finger prints on the bulb . that will cause it to crack when hot .. if you are unable to change the bulb then a call to philips service should do the trick. make sure you ask what the bulb replacement and labor will cost ..
Jan 27, 2010 | Philips 50PL9126D/37B 50" DLP TV
Do I need a new lamp?
99% chance your lamp needs to be replaced. Prices are in $120 -180 range. Search for "50PL9126D/37 lamp". they are available with or Without cage. Version with cage is preferred because it will be easier to install it.
Oct 08, 2009 | Philips Televison & Video
Problem with philips dlp tv
This sounds like one if not both of your cooling fans are not functioning properly. Therefore, you'll need to replace a fan more than likely.
Apr 16, 2017 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
