Click start control panel view devices and printers you should see your webcam from there if you are have trouble with your webcam. Click start right click on my computer select properties then device manager scroll down image devices you could see a yellow question exclamation mark? ! or a red X right click to reinstall drivers or update driver W7.
Click start control panel view devices and printers you should see your webcam from there if you are have trouble with your webcam. Click start control panel administrive tools computer management device manager scroll down image devices you could see a yellow question mark? right click to reinstall drivers or update driver
Some webcams and programs require additional software, although that should be installed with the webcam if things are right. But is does not harm to check if your
Java, Flash and
Quicktime software are installed and up to date. But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP:
DirectX 9.0c - Windows Vista
: DirectX 10).
http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer Also during a video call at the top of your screen you will see an option to for a video call using yahoo messenger this might vary if you are using another messenger service Open skype go to tools from the drop down list select options scroll to audio settings you can make a free test call before you try to make a call. Make sure the microphone is using the same as your computers audio you can make a free test call if you cant get the microphone to work you can select learn about setting up your audio equipment. Click start control panel sounds and audio devices audio and also voice it's the same make sure that you have the right default microphone selected you should be able scroll to video settings to make sure you have the right settings. Open skype go to tools options scroll to audio settings or video settings on the right you will see webcam setting you can change the settings from there click apply after changing any settings also you can see the webcam there you can even take a snapsot also make sure your settings are correct for a video call. Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or Select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it Hope this
helps.
