Question about Acer Computers & Internet
Hi there i have just changed from ADSL cable in put to ADSL2 wi-fi but my wi-fi needs updating is this correct ? if so how do i do this
    President:
  • 2,340 Answers
Just changing or replacing the ADSL Cable ie if it is the Network cable (RJ45) will not affect the configurations of the router in your WIFI modem. Update is not necessary.
Replacing your WIFI modem set, you have to reconfigure the wireless modem router settings to get acess to your internet.
Read the setup instructions manuals if you are replacing your WIFI set.
Hope it helps.
Posted on Nov 15, 2010
I forgot my router password so i want to know what can i do to reset it
You will have to reset the router to factory defaults
BEWARE - this means you will lose all the router settings and will have to set them up again including the ADSL settings which your internet provider should be able to help you with. Then when you setup wi fi security all the computers will need the encryption key and sddi broadcast name changed to match
To reset to default settings, turn off the device first. Hold the Reset button and then turn on the device; wait for 5-8 seconds and then release the button. Reset device's configuration to factory default.
http://setuprouter.com/router/trendchip/hg520/manual-1089.pdf
(the default username/password is admin/admin)
you will need a direct connection ethernet cable between a computer and the router as the wi fi will be not set up after the reset.
Sep 28, 2016 | Huawei HG520 ADSL Wifi Router
Connection to itunes
Hi Yvonne
Several things you can try...
To check for updates, tap Settings > General > Software Update. You can also connect your iPhone, iPad, or iPod touch to iTunes and click Check for Update on your device's Summary page. To check that you're in range of a Wi-Fi router or base station.
  1. That your date, time, and time zone are correct. Tap Settings > General > Date & Time. Time Zone might list another city in your time zone.
  2. That your iOS software is up to date. To check for updates, tap Settings > General > Software Update. You can also connect your iPhone, iPad, or iPod touch to iTunes and click Check for Updateon your device's Summary page.
  3. To check that you're in range of a Wi-Fi router or base station. If you're using cellular service, make sure that cellular data is turned on from Settings > Cellular. If you're connected to cellular data, larger items might not download. You might need to connect to Wi-Fi to download apps, videos, and podcasts.
  4. That you have an active Internet connection. For help with your connection, check your device's user guide.
  5. To see if other devices, like portable computers, can connect to the Wi-Fi network and access the Internet.
  6. To reset your Wi-Fi router by turning it off and then on again.
Jul 07, 2016 | Apple iPhone Cell Phones
How to connect Satellite 4090XCDT laptop to ADSL?
You computer was set up to use a modem to access the internet.
You computer does not have USB, so you cannot use Wi-Fi.
You need to purchase a 2 x PC Card Type II or 1 x PC Card Type III Ethernet card. Then you can plug a Ethernet cable into the ADSL router.
Jul 01, 2014 | Toshiba Satellite 4090XCDT Notebook
How do I configure My 10 Computers to connect internet, I am using an ADSL WI-FI Modem+Router(ADSL DSL2730U).
This is an unmanaged switch so it is very simple. Plug a network cable from each PC to the switch and plug a network cable from any port on the switch to an available port on the router. That is pretty much it.
Jun 07, 2012 | D-Link DES 1016 16-Port Ethernet Switch
How to connect to the wifi with 3g iphone
Hello Jane,
When using a Wi-Fi network with your iPhone, you may occasionally encounter the following issues,Unable to locate or join a nearby Wi-Fi network,Weak or low Wi-Fi signal strength,Connected to Wi-Fi network, but unable to access the Internet.
Tap Settings > Wi-Fi and turn Wi-Fi off and then on again. Verify that you are in range of your Wi-Fi router or base station. Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on. Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet. Update your Wi-Fi router to the latest firmware.
Jun 03, 2011 | Lands Phones
Speed is very slow from modom
Try not use a modem when you have a Router,Connect the ADSL cable Directly from the Spliter to the Router and try using it.
Router does the same thing which modem does but wi-fi connectivity is found in routers.
Nov 27, 2010 | Cisco Linksys E1000 WirelessN Broadband...
I have wireless - router with built in dsl modem DGN2000. Working fine with my desktop but I have just purchased a laptop and have not been able to connect signal to it.
1. Dear! Check your notebook wireless settings and correct it if it is necessory.
2. Chekc your wireless router settings may it need to update for your notebook.
Good Luck
Sep 28, 2009 | Computers & Internet
Is a Speedtouch ST536 v6 capable of ADSL2 or just adsl?
It is just an ADSL modem.585 series are adsl 2
May 05, 2009 | Computers & Internet
Start evrything
You have to take internet connection on your land line or mobile and put your lap in the range of adsl and conigure your lap for net.
Hop this solution works.
Jul 28, 2008 | Internet KM-2501P Enhanced PS/2 Multimedia...
LinkSYS ADSL2 -AG241Modem + Router Ethernet
First : check your cables if its plugged in securely on each each
port
Second: Try to change their ends
Third : Try to replace your Ethernet cable.
If your router is connected to a modem try to isolate the problem by connecting your router directly to your computer and check f light would turn on. IF YES then thers something wrong with your modem, check it out.
Hope those simple steps ive provided helped you in way, If not pls let me know and lets keep the ball rolling.
Cheers.
Jun 19, 2008 | Linksys ADSL Modem + Router With 4-Port...
Computers & Internet Logo
80 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
