Question about Moen Home
I have a new single handle kitchen faucet with a pull out handle. The button on top goes from stream to aerator. Just recently the water comes from both stream and aerator and the button doesn't make just one or the other work. How can I fix this?
  • 4,472 Answers
Hi, If this is new it should still be under warranty. I would contact the manufacturer about sending a replacement. Most likely the valve inside is bad/defective. If you need further assistance please let me know.
Thank you,
Lee
Posted on Nov 15, 2010
New faucet in December - water barely comes out of spout - sprayer works fine
Remove the areator see if water comes out spout better if so clean out aerator they get limed up or get junk in it..
Apr 03, 2011 | Delta Faucet Signature Single Handle...
New moen kitchen single handle. Worked for one full day. Now no water pressure.
Unthread end of faucet (aerator) where the water comes out into sink, under the aerator is a screen & a plastic valve.It has sediment & rust which will disrupt the flow & pressure.Careful not to flush it down the drain. Tip upside down, while holding it together with finger. Flush it under the faucet. It is not uncommon to get plugged up initialy because of the new installation.
Nov 01, 2010 | Moen 7310 Legend Single-Handle Kitchen...
Low water pressure from faucet, but plenty of pressure in water lines.
1-Remove aerator from end of faucet spout to check to make sure it is not obstructed by anything. Grit builds up there and causes flow to decrease , but it can be taken appart and cleaned out.
2-If you have a sprayer attachment to it sometimes the diverter goes bad. This sends water to spray head.
Cut water off remove handle with allen wrench and loosen collar on top to gain access to remove spout. after removing handle and collar you can pull up on spout or work it side to side easily to remove it.
In the middle at the bottom it has a removeable diverter that can be removed and replaced.
If it comes appart it will restrict water flow.
3- If you have to remove faucet to make sure no obstructions any where esle.
I hope this may be some help for you to have a starting point.
May 20, 2010 | Kohler Fort© Single Lever Handle Kitchen...
How do I remove the aerator on a moen pull out kitchen faucet?
It should just unscrew. You might need some needle nose pliers as the aerator may be slightly recessed.
Jan 27, 2010 | Blanco Classic Single Handle Faucet with...
I installed a Moen single-handle kitchen faucet last weekend and the water stream gets weaker every day. I've cleaned the aerator. Where do I look next?
Check for debris in the lines. It's possible some type of debris was freed when you turned the valves back on and the water rushed in.
Jan 23, 2010 | Moen Plumbing
The kitchen sink makes a loud popping noise
Try removing the aerator on the faucet. If that resolves the popping sound, try replacing it with one that allows for a higher flow of water. (Also the existing aerator may be clogged).
Jan 05, 2010 | Moen 87555C Trianna Single Handle Pulldown...
My Moen kitchen faucet stopped working suddenly in that only a thin stream of water would flow at most when I turned on the hot water handle or the cold water handle to the maximum positions. I replaced...
wow... I wish you hadn't gone thru the expense of replacing the faucet... it's perfectly good... your problem was the aerator, it unscrews at the tip of the water spout and had collected too much sediment which eventually blocked water flow. Often happens quickly after your water is shut off at the main valve. Aerators cost about 50 cents...
Aug 30, 2009 | Moen Chateau Loop-Handle Kitchen Faucet...
Home Logo
29 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
