Question about Acer Aspire One PC Notebook
My computer was not connected to power and the battery ran down and now I cannot turn the computer on, even when plugged in.
  • joecoolvette
    joecoolvette Nov 15, 2010
    Laptop off, plug the laptop into power for 24 hours, then try again. This also charges the CMOS battery.
  • Acer Master
  • 4,338 Answers
You need to fully charge the battery, at least overnite.
Posted on Nov 15, 2010
  • Acer Master
  • 629 Answers
Take out the battery and disconnect the charger. press and hold the power button for 10 secs. Connect only the charger making sure its power indicator is lit up, then try to turn on the computer. If same thing happens, try a spare charger and if this does not work, it would sound like a motherboard problem. hope this helps you move to the right direction
4 Suggested Answers
jasonkoe
  • 64 Answers
SOURCE: New battery runs down fast
bad battery.. RMA that back to where you bought it from. probably wasnt a new battery they sold you. id charge it from completely dead to completely full one more time and if you dont get at least an hour out of the batt then i would return it..
Posted on Jan 18, 2008
  • 31 Answers
SOURCE: I ran the battery all the way down and now it
you will most likely need to replace the battery.
Posted on Jun 24, 2010
rcw1962
  • 2571 Answers
SOURCE: My IBM R51's battery ran down. Connected the
If it is the first time its happened, has your charger fused/broke.
Is the lead from the power block to the laptop loose??
Posted on Jul 09, 2010
Why wont my computer turn on macbook air. what do you think?
could be a number of things including the power block faulty, a break in the power lead, the power regulator in the macbook or even it's just plain old dead. if the macbook lights come on when it's plugged in and nothing else happens when you press the power button, odds on it's just dead.
Jan 30, 2015 | Apple MacBook 13"White /2.0Ghz Intel Core2...
My Acer Aspire 6530-5753 laptop stopped charging the battery even though the power supply light was on--it's an aftermarket charger from Radio Shjack. The battery ran dead and it wouldn't run on...
This is not the motherboard. The batteries in laptops have electronic sensors in them. When they reach the end of life, they stop the computer from turning on. Once that happens it wont power on with the battery in or out. Batteries are not that expensive. Only about 25 dollars.
Mar 27, 2017 | Acer (ACERMOTHERBOARD)
It started with the computer not getting power weeks ago but you could play the cord it would kick on no big deal. I figured I needed a new cord. Then yesterday it started turning itself off. If it sat...
Your power jack is bad. The cable and DC jack are a one piece cable that can be unplugged from the motherboard and replaced. They are available on EBay for around 30 bucks or less and takes approx. 30 minutes to change out.
Jun 27, 2010 | HP Pavilion dv7-1132nr Notebook PC
There seems to be no power getting to the computer. checked the fuse. The last time used, the laptop went off because the power ran down and it was not plugged in. Now it will not power up at all.
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
Dec 18, 2009 | Lenovo ThinkPad T61 Notebook
Yaesu VX-3R ham radio will not turn ON!!!!
Even though this is several months old, I thought I would post this reply. I had the same problem when I ran the battery completly down. The charge light didn't come on and the unit would not turn on with the power or battery. Sent the unit back to Yaesu for warranty work and they replaced the switch board. Unfortunately after I got it back and ran the battery down again..... Well, it's back at Yaesu AGAIN! Looks to me like there could be a problem with the power circuit being overloaded when it tries to charge the flat battery!!
Nice little rig, but it may be for sale once I get it back!!
Mar 29, 2009 | Radio Communications
No power
As far as a reset button is concerned you can hold down the power button for a few seconds to turn the power off completely and then power it back up.
If your having power issues and you have a new power adapter thats known working you can try disconnecting the power take out the battery leave for a few seconds then re-insert plug in power and try again.
If this fails try starting just with battery power, if this fails try taking out the battery and attaching just the power adapter and starting up.
Also check that the battery is getting charged there should be a light on the notebook that tells wether its charging.
If this all fails you may have damaged the power adapters connection to the notebook when you bumped it. Hence the battery cannot get recharged to start up.
Let me know how you go.
Mar 23, 2009 | Compaq Presario V4000 Notebook
Computer doesn't start up
reset is take the battery out hold the power button down 15sec obviously with the lead in
actionman
Feb 24, 2009 | Apple MacBook Mac Notebook
Laptop is not responding
1) Try holding down the power button for 5 secs. Let go and try to turn it on again. This is a signal that bypasses the OS and tells the motheboard to power down. This helps if the computer is actually still running but with no display.
2) If that does not work, unplug the computer, remove the battery and leave it at for 1 min. Replace the battery, plug it in and try to turn it on again. Corrupt data in RAM can cause problems like yours, this clears out the RAM so you start fresh.
If the above did not help it might be your motherboard. A bad motherboard does not usually damage your data. You can remove the hard drive and put it in a portable hard drive enclosure (about $30), the enclose plugs into a USB slot in a working computer and shows up as another hard drive.
Check to make sure your power is ok, I ran into a situation where the power bar was accidentally turned off and then the battery ran down.
Jan 08, 2009 | IBM ThinkPad 600X Notebook
Jan 18, 2008 | Averatec 3200 Notebook
Power up problem
Your laptop needs a new battery. Buy a new one and have it replaced by a service technician for free.
Sep 15, 2007 | Computers & Internet
Acer Aspire One  PC Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
