Question about Car Audio & Video
I recently installed a amp to my sound system I have a pioneer deck when hooking it up everything works but when I turn it off the car theamp light stays on I check everything I think it is my remote wire.
    President:
  • 624 Answers
You are correct!
If you have a volt meter or a test light you can use it to see if you have some voltage on the remote terminal on the amp.
If you do not have either of those items, just disconnect the remote wire and see if the light goes out.
If the light goes out, you have voltage coming from your radio that is keeping the amp turned on, that is normally a problem with the radio. The remote output of the radio may have a shorted transistor in the circuit.
If the light stays on, you have a problem with the amp. It is rare to have an internal electrical problem with an amplifier and the amp still works normal. That is not to say it can not happen, there may be a component that is shorted in the turn-on circuit of the amp that is isolated to the turn on cicuit only, and it keeps the amp on all the time.
This will become a big problem soon if not repaired. If the amp is staying turned on even when the car is off you will drain your car battery rather quickly. Most amplifiers will draw between 1 amp and 2 amps of current with no signal applied, this is called the idle current.
Find out which unit is causing your problem and take it to be repaired, it is most likely an electrical problem that will need good electrical troubleshooting skills to locate.
If you need any more help with this feel free to ask, with the model number of the unit at fault I can even find you some likely suspects to be checked.
Don't forget to give me a "FixYa" if this information turns out to be helpful.
Posted on Jun 19, 2008
Haveing trouble wireing a Pioneer A-400X INTERGRATED AMP, Need the user manual really.Where can i download tthis manual can you help. .
I can't find the manual but there's no real mystery to any generic stereo amp.
http://hifi4sale.fullboards.com/t5345-pioneer-a-400xusedsold
OUTs go to INs.
Just about any standard output of an audio device will connect to any Input on theamp EXCEPT PHONO, which is for a turntable.
Tape loops are for tape decks or sound processors like equalizers. When a tape loop is selected the program goes out, gets processed and comes back - all before any volume or tone controls.
May 21, 2011 | Pioneer Audio Players & Recorders
Pioneer deh p3100ub shuts off when i touch deck
sounds like the faceplate is not seated right or has dirty connections but it is in your detachable face plate. your still under warenty.
May 24, 2010 | Pioneer DEH P3100UB Car CD/ MP3 Player
I hooked up my Pioneer DVD-5000 to my Amp and all I did was hook up the Remote Wire to the Amp and when I turned on my care my deck doesn't light up or work any more? Did I fry my deck? Can I fix it? What...
sounds like a connection is wrong and if it shorted it prob blew the fuse for the radio. Disconnect the radio from the amp then pull the connecter out of the radio and check the ten amp fuse...
Jul 24, 2009 | Car Audio & Video
Rockfordfosgate P6002 amp protect light goes on
are u sure u have them running at the right ohms, for not only the subs but the amp too...if you go lower than your amp is rated you can fry stuff...via protect mode......hopefully this helps
Mar 17, 2009 | Rockford Fosgate p-450.4 Car Audio...
My subwoofers will not play
go into the menu screen on the pioneer unit and go to setting if you have a loud function there turn it on.... if that doesn't activate the amp ...(did you hook up the blue wire from pioneer deck to amp and run it threw the car to the amp)..if no than your pioneer deck does not realize there is an amp present in system....... if yes scroll threw menu till you see audio look for Sub Woofer or Amp you may even have a button on pioneer deck marked SW go press it and turn amp to on this will provide signal from pioneer unit to amp if this doesn't work other thing could be you hooked RCA to AUX input (but if you have a SW for RCA plugs on back of unit make sure the RCA wires are in it) the loud or SW button should activate it (if there is only F and R for RCA plugs on back of unit use R hope this helps)
Mar 04, 2009 | Pioneer AVH-P4900 Car Video Player
No rear output
yea your ic in the deck is going so i suggest you buy one which is cheaper than buying a new deck
Sep 15, 2008 | Pioneer DEH-P5800MP CD Player
RCA jacks not working DEH-P470MP
does the amp turn on when the deck is turned on ? is the ground hooked to the body of the car to bare metal w/out paint ect ...under it ? you may want to take it to a installer there are many things it could be they can also test your rca outputs if thats the problem. curcuit city is a cheap place to have your equipment tested if you live close to one
Aug 07, 2008 | Pioneer CD Receiver - DEH-P470MP - CD/MP3...
Pioneer DEH-225 Car Audio
The system remote control is usually a blue wire on your decks harness and it is for an amplifier for a sub or other speakers. It sends power to the subs amp when the deck is turned on. You may need to find the wires coming off the antenna and splice them into the red power switching wire 12v on you decks wire harness. Good luck
Oct 07, 2007 | Pioneer DEH-225 CD Changer
Amp is on, Subwoofer works, but no sound.
here is a short test you can try, remove the rca audio cable from the amp & connect a diskman or toher audio o/p device that you can hook up with the same rca wires, turn on the amp & see if you have sound. you can also remove the speaker wires from the sub & using multi meter read the ohm's of the sub, most subs are 4 ohm. Hope this help locate your problem
Oct 24, 2006 | Pioneer GM-7200M Car Audio Amplifier
Car Audio & Video Logo
80 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
