Question about ASUS P5S800-VM Motherboard
Asus p55800-vm takes what kind on ram the probleme is i want to order ram i need? thanks for the help
  • 2,296 Answers
Asus P55800-VM motherboards support up to 2GB of DDR DIMMs of either 266, 333, or 400 MHz.
Posted on Nov 15, 2010
Dear Expert, I have Asus motherboard P5S800-VM. Now,There is 1.5 Gb ram(512MB+1 GB).If I plug 2Gb ram (1+1), then PC is working very slowly.What can I do for this problem . ram:2x1Gb Kinsgton thanks
First verify that you are using the proper speed of RAM. Second, check the BIOS and make sure that recognizes the RAM you have installed. Sometimes you have to manually set the RAM size in the BIOS in order to get it to work. Finally, I have had several issues with Kingston RAM on different motherboards even when it is the proper type so you would want to try a different manufacturer.
Jul 08, 2011 | ASUS P5S800-VM Motherboard
Mobo has led lit up but nothing comes up on the screen
Try the following
Disconnect all components including all hardrdrives and memory.Only CPU and on board graphic if available. if not insert only graphiccard. start up and see error message on screen. Then restart and press delete to access bios setup. swictch off connect only Hdrive and start up. see if you can access bios. start connecting components one by one and go through the whole procedure. remember no power before you connect a component.
Aug 11, 2009 | ASUS P5S800-VM Motherboard
Which kind of RAM my motherboard is compatible?
It supports maximum of 2 GB of DDR RAM
DDR here means DDR 1 and not DDR2 or DDR3
Rate it, if it helps.
Aug 04, 2009 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
DDR2 RAM for P5RD1-VM
The ASUS P5RD1-VM takes the PC2700/3200 DDR SDRAM DIMMs. You can upgrade your ASUS P5RD1-VM to up to a maximum of 2.0 GB Memory, the system has 2 sockets to install Memory. For best system performance use the maximum amount of allowed Memory per slot for your system i.e. 1 GB.
Thanks
Iqbal
Apr 14, 2008 | ASUS P5RD1-VM Motherboard
Asus p5rd1-vm motherboard problem of graphics card
Hi shuter. Your Asus P5RD1-VM has an integrated video adapter ATI® Radeon 9600 GPU. You need to enter your bios & change the video start up order. Pg.2-22 in your manual.
Configuration options: [IGD] [PEG/IGD] [PCI/IGD]
Boot Graphics Adapter Priority [PEG/IGD]
Save & exit. Check system at boot up for correct memory count.
Thanks for using FixYa & if you need more help just re-post here. Have a good one!
please vote...
Feb 29, 2008 | ASUS P5RD1-VM Motherboard
Motherboard ASUS P5RD1-VM ram problem
More people should complain with Asus support. Checking Asus forums, you'll find there's an obvious problem with a PCI-E video addon + 2 used memory slots. In my case, I had 2Gb (1 + 1), mb with bios version 1104, and it worked fine; when I installed a new PCI-E card, the system was very... very sluggish. Now I have uninstalled 1 memory, I'm using only 1Gb of RAM with the PCI-E card, and it's working well.
Again: checking Asus forum, this is a reported problem, and a bios bug... Asus should release a new bios version, but they seem not to bother, as this is a relatively "old' mb...
Feb 16, 2008 | ASUS P5RD1-VM Motherboard
Slow data transfer rate
Do you have this Bios version? P5LD2-VM BIOS version 1303
Support new CPU's. Please refer to Asus website at: http://support.asus.com/cpusupport/cpusupport.aspx
Your board came out around June-2005 so improvements are here. I'm not saying its all about the CPU & FSB but it may help.
Jan 27, 2008 | ASUS P5LD2-VM Motherboard
Intel ASUS P4 845 GL Motherboard
Hi, For an ASUS P4BGL-VM Intel 845GL Chipset Ultra ATA100 MATX CPU Type: Intel Pentium 4 478-Pin (OEM), the Asus site specifies max of 2 x 184-pin DIMM Sockets support max. 2GB PC2100 / PC1600 non-ECC DDR or SDRAM memory but not "and". Personally, I find it more practical to install 2 X 1Gb rather than a single 2Gb. Hope this gives you some idea. Kind regards.
Aug 07, 2007 | Intel ASUS P4BGL-VM 845GL Chipset Ultra...
ASUS P5S800-VM Motherboard Logo
247 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
