My Samsung ML-2510 laser printer is frequently not pulling the printer paper through. What can I do to correct this?
  • johnyimnd Nov 15, 2010
    Tried suggestions and did not help.
    President:
  • 2,923 Answers
Pull out the paper tray and clean the feed rollers with alcohol or water. Use a clean cloth as well.
Thank you and good luck!
Posted on Nov 15, 2010
  • 629 Answers
Check if the paper feed roller are working without any damaged on them, Then try to turn off the printer, remove the power cord, press the power button for 10 seconds. Check if the rollers are align and the paper guides, and that no obstruction that may cause paper jams, then try a new **** of compatible paper and see how it goes.
  • Rodie Nov 17, 2010
    if no physical or mechanical issues found in the printer, you may need to make sure the papers are placed properly on the tray and I'll recommend updating the driver and firmware for your printer if this has not been done. You can check the Samsung web site to look for the updated driver and firmware.
My Samsung laser printer ML-2510 keep wont stop running (two lights are blinking same time) until I manually turn off the switch.
After removing the pickup rubber (and not removing the rubber band from it's plastic drum) I cut a thick piece of card stock paper the width of the rubber band and slid it under the rubber. I thought it would make it contact the paper with more force and it worked great.
Dec 04, 2011 | Samsung ML-2510 Laser Printer
Samsung ML 2510 will not print in landscape
Dear
select the driver setting for land scape also select the paper size to actual size used. Also if the application has the paper setup here you can also set to landscape.
Thanks.
Sep 26, 2011 | Samsung ML-2510 Laser Printer
If the paper is jam in the printer
Without more specific information on where the jam is occurring in the printer difficult to provide a specific solution.
However, if you are having problems with paper jams you may find it helpful to work through the interactive troubleshooting guide found on this page under the Troubleshooting tab:
http://www.samsung.com/sg/consumer/pc-peripherals-printer/printer-multifunction/mono-laser-printer/ML-2510/XSS/index.idx?pagetype=prd_detail&tab=support
Under the FAQs tab on the same page you will find 3 guides for avoiding paper jams and 1 guide for clearing paper jams.
Trust this is helpful. Please vote. Thank you. :)
Dec 21, 2010 | Samsung ML-2510 Laser Printer
Page prints, but jams, samsung ml 2510 and toner is smeared over page
Your toner might be faulty, also remove toner and clean place with a cloth. Look to see inside if their are any loose pieces of paper in machine.
Feb 21, 2010 | Samsung ML-2510 Laser Printer
I have an ink spot on my paper when my samsung ML-2510 prints
hello sir; If the spot line up by certain distance, that's drum cartridge need to replace,
Feb 01, 2010 | Samsung ML-2510 Laser Printer
My printer is stuck and it is a ML-2510 the paper is jammed how i get it out?
Do you know where the paper is jammed? After you have removed it, you need to open the front panel and close it again to reset the printer and allow your document to print.
Nov 13, 2009 | Samsung ML-2510 Laser Printer
Samsung ML-2510 Laser Printer Jams
printer only supports up 120gsm,anything thicker will jam.
Jun 08, 2009 | Samsung ML-2510 Laser Printer
Samsung ML-2510 Series: the error red light is blinking
reset the printer by opeing the front over and closing it again.
check all area for paper jam. i.e.: paper tray, ink cartridge, out put tray.
Feb 28, 2009 | Samsung ML-2510 Laser Printer
Ml-2510 doesn't work any more after i unjammed paper, the Diagnose Program says the cartridge is not installed.
take out the printer see that any more paper or contact points contaminated. and any jamm in fuser area etc. and also see that toner is correctly installed or any part is broken ,
May 09, 2008 | Samsung ML-2510 Laser Printer
35 people viewed this question
jasbo
jasbo
