Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Frigidaire (Kenmore C970-657022) door won't lock; neither door lock button nor self-clean works. When I press the door lock button I briefly see "no" on the right side of the display, then I get "F2 err". The door switch works (oven light turns on/off automatically). Temp sensor reads around 1200 ohms (oven temperature regulates normally). The lock switch N.O. side is open (high resistance approx 100K ohm), and the N.C. side is closed. Other switch on lock motor is closed (otherwise none of the burners would work). Tried disconnecting/reconnecting all sensor wires and the 8-pin ribbon cable from the keypad to the control board. Also, if I press and hold the <Cancel> button for a couple seconds I get the same "no" and then "F2 err". I'm puzzled, and without having a schematic diagram of the control board (already have the electrical diagram of stove) I can't go much further. It seems like there is some other self check the microcontroller is doing, but I'm not sure what that is. Everything else on the stove works normally. What should I be looking for?
2 Suggested Answers
  • 185 Answers
SOURCE: my stainless frigidaire professional series
F1 is an EOC (electronic oven control) failure. The control is expensive. But before you go and buy this board, you need to find a diagram to see of this model oven lock is controlled by the EOC or by a micro switch. If you have a lock button on the board the you have to replace the EOC.
Posted on Mar 24, 2010
How does the self-clean feature work on a Frigidaire CFEF366EMB model?
Hi Beverly,
I understand that you are looking to run your self-clean feature on your Frigidaire range, model# CFEF366EMB.
-To start this you will remove all racks and make sure that any excessive spillovers are cleaned up as best as you can.
-Next you will press the "Clean" button, and the display will show "---".
-Press the up or down arrows to select the length of time you want the oven to clean. Usually 2 or 3 hours.
-The door will automatically lock once your time has been chosen and the "LOCK" indicator light will flash. DO NOT open the door while the light is flashing. (it takes about 15 seconds for the oven door to lock).
-"Cln" will appear in the display during the self-clean cycle and the "LOCK" light will continue to glow until the self-cleaning cycle is complete or cancelled and the oven has cooled.
When the self-clean cycle has completed:
-The time of day or "END" will appear in the display window and the "Clean" and "LOCK" light will continue to glow.
-Once the oven has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened.
-If "END" is in the display and the Clean indicator light remains ON, press the "CLEAR/OFF" button and the time of day will appear on the display.
-When the oven is cool, wipe away any residue or powdered ash with a damp cloth or paper towel.
-Best Regards-
Jan 23, 2014 | Frigidaire Ovens
Tip
SELF CLEAN - FRIGIDAIRE OVEN
I JUST CALLED FRIGIDAIRE AND GOT INSTRUCTIONS FOR SELF CLEANING:
1. TAKE OUT THE RACKS UNLESS YOU DON'T MIND THEM TARNISHING
2. TURN THE "SELECTOR" AND/OR "OVEN" DIALS TO THE LOCK (OR CLEAN) POSITION
3. PRESS THE "COOK TIME" BUTTON
4. SET THE CLOCK TO 2 OR 3 HOURS (I.E., "2:00" OR "3:00"), DEPENDING ON HOW DIRTY THE OVEN IS
5. PRESS "START" BUTTON
6. YOU WILL HEAR THE MOTORIZED LOCK MOVE INTO PLACE; WAIT ABOUT 30 SECONDS, THE DOOR SHOULD BE LOCKED AND CLEANING WILL BEGIN.
7. CLEANING WILL STOP AFTER THE TIME SELECTED (I.E., 2 / 3 HRS) AND THE DOOR SHOULD AUTOMATICALLY UNLOCK
on Oct 09, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire door lock won't reset
Hello Steven Krenz - Was the unit in self-clean mode? Try pressing and holding the "Clear/Off" button to stop any operation of the EOC. Do this at the same time while pushing and hold the light switch to the left of the door lock. Usually this will trick the oven into unlocking the door. If it is ineffective, try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and redo the steps. If door continues to maintain locked while open, the unit may possibly have a faulty door latch or a communication problem with the EOC. Contact a professional to move forward accurately.
Apr 02, 2013 | Frigidaire GLEB27S7A Electric Single Oven
Closed door, pushed clean button, but door lock button keeps flashing and door won't lock.
Hello there and welcome to Fixya
This is a fairly common problem with self cleaning ovens
The problem normally is that the user has interrupted the clean cycle and the door is locked by default or the door lock assy has failed all together .
Now here is the thing these ovens have a built in memory module that stores a number of commands that the user has input in it like self clean or broil ect.ect so what you will have to do is to clear the memory and it is done like this.
First unplug the oven and do not touch it leave it sit for a minimum of 1 hour this will reset the memory module
Now only after the hour is up plug in the oven and you may hear a beep ora click if so great wait a few min then you can press the cancel button then try to open the door again.
Sep 16, 2011 | Frigidaire GLEB27S7A Electric Single Oven
I have a Kenmore gas range model # 7907578890. I pushed the clean button to clean the oven, door locked and cleaning started briefly then stopped. Door stayed locked. Now oven won't respond to any buttons...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Jan 18, 2011 | Kenmore Ovens
How do I get self clean to work on older fridgidare stove
Move the safety lock/lever at the top of the oven door to the right and press the self clean button on the oven control panel, it is an automatic cycle so it will lock the door from opening and then will proceed with the auto clean cycle. Good luck !
Jan 06, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Door locked after cancelling self clean option
Open the door. In the upper left corner, press and hold the door switch (the one that controls the inside light). Start a self clean cycle and wait for lock motor to engage. When the lock stops moving it should be in the unlocked position. Press cancel to stop the self clean.
If you need more assistance let me know.
Mar 29, 2009 | Ovens
Frigidare Self Clean Oven
Sep 30, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire oven
2. TURN THE "SELECTOR" AND/OR "OVEN" DIALS TO THE LOCK POSITION
Sep 14, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Self cleaning oven directions
Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
Oct 24, 2006 | Kenmore 40494 / 40495 / 40499 Electric...
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
102 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
