Question about Hitachi EC12 Portable Electric 2hp Air Compressor, Oil Lubricated
How do you remove the Fan to replace the cover
  • Hitachi Master
  • 7,733 Answers
Try at eReplacementParts.com : Power Tool Parts and Tool Repair Diagrams.
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Nov 17, 2010
How do i remove the squirrel cage type blower fan.
Most fans of this type have a cover between the motor and the actual fan. The cover is usually metal, sometimes plastic and usually has 4 or more screws holding it down. Remove the screws and the fan and cover will come out as one assembly (Sometimes there's a rubber seal between the cover and the housing that may be sticky you may have to gently pry up around the cover to free it from the base its screwed down to). To remove the motor you need to remove the squirrel cage from the shaft, then the cover can be removed and the motor replaced.
Jul 29, 2014 | Dometic Rooftop RV Air Conditioner
Tip
Broan Bathroom Fan Care and Cleaning
<p>One of the most common <b>bathroom fans</b> is the <b>Broan brand ventilation fan</b>. These fans come in many configurations and variations. Because of the environment that these fans are in and the placement of these fans they will get very dirty over a period of time and will need to be cleaned from time to time. <b>Cleaning bathroom fans </b>can be fairly easy if you have a few tips about how to do it.<br /> <p> <br> <p>To clean the fan the inside of the fan must be accessed first. To get to the inside of the fan the cover must be removed. Most of the covers simply will pull downward and away from the ceiling. There are a couple of springs, one on each side the snap the cover up and hold it in place. On some models there can be a screw that holds the cover. It will be visible right in the center of the cover. If no screw is visible then you can assume that it is a spring type cover. If there is a light in the cover you can remove the plug and the light will come right with the cover.<br> <p> <br> <p>After pulling the cover down simply squeeze the springs together slightly and the cover will come completely out and you can take it to your sink to wash it. Then take a vacuum or a damp rag and clean the inside of the fan compartment. If you look closely you will see that the fan assembly has a plug that can be pulled and the fan assembly can be removed by either removing a couple of screws or by placing a screw driver between the fan assembly and the side of the box and snapping out the fan assembly.<br> <p> <br> <p>Once you have the fan assembly out you can then use compressed air, like you use on your computer keyboard, or a damp cloth to clean the fan assembly. The compressed air works the best on the blower wheel and in some cases a small screw driver may be needed to remove caked on dust inside the fins of the fan.<br> <p> <br> <p>With you vacuum, you can now clean out the rest of the box and even into the vent hose a little bit. Be careful not to destroy the flapper, as that is what stops cold air from being pulled back into your home while the fan is off. Wipe down the box to complete the cleaning.<br> <p> <br> <p>The fan can now be reassembled by reversing everything and placing it all back as it was before you removed it. Be sure to remember to plug the fan motor back into the socket. The light may also need to be plugged in if you have a light in the cover.<br> <p> <br> <p>You will now have a nice clean fan again. <br> <p> <br> <p>If you want to <b>replace the fan</B> because it is broken worn out or noisy you can often <b>buy replacement bathroom fan parts</B> or even a new fan that will fit in the same box. Upgrades are available to fit existing boxes also. To find <b>bathroom fan upgrades</B> and replacements go to <a href="http://www.broan.com/">www.broan.com</A><br> <p> <br> <p>At <a href="http://www.broan.com/">www.broan.com</A> you can also <b>order <span> </SPAN>broan replacement parts</B>, <b>download broan manuals</B>, and get <b>installation tips for your broan fan</B>.
on Nov 17, 2010 | Home
How to remove the glove box from a 2006 porsche cayenne
Replacing the fan doesn't take many tools, just skill. The fan is under the passenger side dashboard. Remove the cover that is held in with a T25 screw. After removing the screw pry the cover down. Disconnect the light from the cover. Remove the foot vent under the dashboard by pulling it down. Using a 5.5mm socket remove the screws holding in the blower fan. Removing the fan can be very difficult because the main wire harness goes under one edge of the fan. When you get the fan out check it for water damage. When installing the new fan make sure it slides into the channel in the hva/c box. Working around the wire harness can be frustrating. After reassembling check that the fan works. There are 4 places water can leak into the fan. The hva/c water drain can be plugged. The wiper cowl cover at the base of the windshield can be unclipped from the windshield. And one of the two wiper cowl water drains can be plugged.
May 25, 2014 | 2004 Porsche Cayenne
How to replace the ac blower fan on a 2006 cayenne?
normally the armature of the fan is supported by phosphor bronze bushes that are self lubricating. However if there has been water present then the bushes dry out and make a noise or seize up . If you are mechanically minded and you can get to the motor ,pull it apart and lubricate the bushes with sewing machine oil . If not replace it with one from the wreckers .
May 24, 2014 | 2004 Porsche Cayenne
Front seal replacement 5.9 cummins
Hi Dale, I'm glad to help! Below is the removal procedure for the front crankshaft seal on your 5.9 cummins engine. Hope this helps and have an awesome day!
REMOVAL
  1. Disconnect both battery negative cables.
  2. Raise vehicle on hoist.
  3. Partially drain engine coolant into container suitable for re-use (Refer to 7 - COOLING - STANDARD PROCEDURE).
  4. Lower vehicle.
  5. Remove radiator upper hose.
  6. Disconnect coolant recovery bottle from radiator filler neck and lift bottle off of fan shroud.
  7. Disconnect windshield washer pump supply hose and electrical connections and lift washer bottle off of fan shroud.
  8. Remove viscous fan/drive assembly. (Refer to 7 - COOLING/ENGINE/RADIATOR FAN - REMOVAL).
  9. Remove cooling fan shroud and fan assembly from the vehicle.
  10. Remove the accessory drive belt (Refer to 7 - COOLING/ACCESSORY DRIVE/DRIVE BELTS - REMOVAL).
  11. Remove the cooling fan support/hub from the front of the engine.
  12. Raise the vehicle on hoist.
  13. Remove the crankshaft damper and speed indicator ring.
  14. Remove power steering pump.
  15. Remove accessory drive belt tensioner.
  16. Remove the gear cover-to-housing bolts and gently pry the cover away from the housing, taking care not to mar the gasket surfaces. Remove crank seal dust shield with cover.
  17. Support the cover on a flat work surface with wooden blocks (Removing Seal from Cover), and using a suitable punch and hammer, drive the old seal out of the cover from the back side of the cover to the front side(Removing Seal from Cover).
Apr 10, 2014 | 2004 Dodge Ram 2500
Replace fan
Replacing a broken fan in a Kirby is not an easy job. You have to take off the handle, the top cover, the front piece covering the fan and then stick a wrench down onto the motor shaft to hold the shaft tight while you stick an awl or small screwdriver into the hole on the spindle sticking out the front of the vacuum. Turn the spindle to remove it so you can remove the fan. Install the new fan and reassemble the vacuum.
Mar 11, 2014 | Kirby Vacuums
How to change the inside bulb in a ge spacemaker microwave that has a top vent fan
My Spacesaver bulb replaces from the top. You have to remove 2 screws that hold the upper vent cover. W/ cover off you will find a phillips head screw about the center that holds the bulb cover. Remove the cover screw & lift up & remove the cover, then replace the bulb, the cover & screw then put the vent cover & it's 2 screws back. There may be some variance but they are all similar.
Mar 16, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
How to change the cooling fan in a toshiba laptop model p200d-139
Instructions
Shut down your Toshiba laptop, and then disconnect all cables. Close the LCD lid, and then place the laptop face down on a flat surface. Position the laptop with front edge facing you.
Locate the battery pack near the top section of the laptop's bottom casing. Press on the battery release button. Remove the battery from the laptop.
Locate the cooling fan compartment cover. Its location varies from laptop to laptop, but it will be the only hardware cover with a vent in it. Remove the Phillips-head screws securing the fan's cover in place. Remove the cover from the laptop.
Disconnect the fan's cable from its connector on the motherboard. Remove the Phillips-head screws securing the fan in place. Lift the old fan out of the fan compartment and set it aside. Removing the old fan will reveal the processor chip. Apply a thin coat of thermal grease to the processor's surface using a clean paper towel. This will prevent your new processor from frying once you power on your laptop.
Place the new cooling fan assembly inside the fan compartment. Align the screw holes on the new fan with the screw holes inside the compartment. Replace the four retaining Phillips-head screws, and then reconnect the fan's power cable to the motherboard. Replace the fan compartment's plastic cover, and its retaining Phillips-head screws.
Replace the battery pack and reconnect all power cables and external devices. Turn on your laptop to test the new cooling fan
Jul 28, 2012 | Toshiba Computers & Internet
Fan blade noise
This is most of the time due to excessive dust covered on processor heat sink try cleaning in side with pressure air by removing keyboard.
Mar 13, 2009 | Acer Aspire 5050 Notebook
Eureka High filtration Commercial vacuum fan
One of 2 ways, remove the plate on the bottom, the is a clear cover covering the fan. Just unbolt the belt pulley and remove the fan. If there is no cover covering the fan, then you will have to remove the top, take out the 4 screw holding the motor and turn motor over, then you can remove the fan.
Jan 10, 2008 | Eureka Smartvac 7975 Vacuum
Hitachi EC12 Portable Electric 2hp Air Compressor, Oil Lubricated Logo
53 people viewed this question
Top Hitachi Air Tools & Compressors Experts
John Trevino
Jim Thurston
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Hitachi Air Tool and Compressor Expert? Answer questions, earn points and help others
