Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
Printhead carriage jam facult is showing. No jam, I tried calling the help line. I still have the printhead error fault.
  • Anonymous Mar 27, 2014
    clear any obstructions
  • 1,218 Answers
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Posted on Nov 15, 2010
Mx 316
Error 5100 typically means that something has jammed the carriage. Unplug printer, open, and examine the print area for anything that might be blocking the print heads from moving back and forth. clear...
Sep 07, 2014 | Canon PIXMA MP160 All-In-One InkJet...
We have a ESP 7250 the print head carriage shows jammed but I can't get the ink cases to move. So I can check it
To resolve this error: Open the printer access door. Disconnect the power adapter from the printer. Gently hold both sides of the carriage, located immediately behind the printhead, and make sure the carriage moves freely. Remove the printhead and ink cartridges. Reinstall the printhead and ink cartridges, making sure each clicks into place. Connect the power adapter to the printer. Turn the printer on. Close the printer access door Hope this helps resolve your problem
Jan 04, 2013 | Office Equipment & Supplies
Code 3527 Printhead carriage jam on Kodak ESP 5210 All in one
the only thing i can think off is there is a problem with the head sensor, the heads move back and forth on a rigid belt but the head case also runs along a see through plastic strip, this has lines in it and tells the printer were it is, other thing i can think of is the head cleaner, they can get stuck in them sometimes and cause misalignment and damage the reader. also anything they like to use on printers is a inc use chip that can make faults come up so you have to buy a new printer. this has been in a few articles. business printers don't have this feature. hope this helps
Jun 05, 2017 | Office Equipment & Supplies
HP 500ps showing error is System error 86:01
System Error: 86:01
Problem Description: Carriage-Axis shutdown.
If this error code appeared but was NOT caused by a paper jam, then try the following:
* Too much friction in the Slider Rod. lubricate the Slider Rod.
* The Carriage is bumping into the Service Station. If the carriage
is stuck at the right hand side of the Printer and cannot be moved
out to the center of the Print Platen it is because the Service
Station cannot uncap the Printheads. In this case replace the
Service Station/Aerosol Fan Assembly
Apr 16, 2010 | HP DesignJet 500ps InkJet Printer
Hp designjet 500 plus
Problem Description: Carriage-Axis shutdown. Corrective Action: If this error code appeared but was NOT caused by a paper jam, then try the following:
1) Too much friction in the Slider Rod. Enter the Printer Information utility and check the Scan-Axis usage. If the percentage is close to 100%, then lubricate the Slider Rod.
2) The Carriage is bumping into the Service Station. If the carriage
3) Perform the Carriage Movement test
Aug 19, 2009 | HP DesignJet 500 InkJet Printer
My HP Officejet 7210 all in one is showing the following error message: Carriage Jam. Open carriage door, clear jam, then press ok". There is no jam, I have looked through the back door and the front of...
Carriage jam means the carriage, where you put the inks, can't move right to left properly. Sometimes ink on the clear strip behind it is the cause. You can carefully clean with damp Q-tip, and check also that the cleaning assembly on the right where the printhead parks, is not stuck.
Jul 24, 2009 | HP Officejet 7210 All-In-One InkJet...
System Error 060308000008 on HP Designjet 1050C plus
that error show a problem with the pintheads
Remove ALL the Printheads and clean the flex contacts on the
Printheads and in the Carriage Assembly, if that dont solve the problem change printheads, if after that have the same problem call HP, was a hardware error.
Apr 30, 2009 | HP DesignJet 1050c plus InkJet Printer
Canon mx700 5100 error
The 5100 error usually indicates a problem with the printer knowing where the printhead carriage unit is.
Chances are that when you cleared the jam you dislodged, damaged or otherwise skewed the little calibration strip at the back of the printer.
This strip is a clear bit of plastic that has lots of thin black lines on it and it's used by the printer to sense where it is.
If it's not that then it's most likely something jamming the printhead carriage somehow... ink soaked bits of paper are a favourite that I used to miss a lot.
Hope that helps.
Jan 30, 2009 | Canon MX700 Office All-In-One InkJet...
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
493 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
