I m looking for a wiring diagram for an AC motors and how the capacitors are connected model baldor reliance part number fdl3612tm
    Guru:
  • 1,524 Answers
Motor wiring- Capacitor usually gets two brown wires, 120 Volt Black= Power, White neutral.
220Volt usually no white Black =L1 Power, Red,Blue, Speeds. Yellow=L2
Posted on Nov 15, 2010
How do I change wiring on 1080 motor from ac to dc . And what do I use for speed control?
You can't. You buy AC motors to work from a mains supply, or DC motors to work off a battery. You can't alter the wiring to change one to the other.
Wiring a small 2 speed AC motor - Forum - All About Circuits
https://forum.allaboutcircuits.com > ... > Circuits and Projects > The Projects Forum
  1. Cached
Jul 10, 2011 - 6 posts - ‎3 authors How do I wire up a small 2 speed AC fan motor? It has three wires, ... The switch to which it was previously wired had Low and High. It has been ...
[PDF]AC & DC Motor Installation & Maintenance - Baldor.com
www.baldor.com/mvc/DownloadCenter/Files/MN416
  1. Cached
  2. Similar
MN416. AC & DC Motor Installation & Maintenance ... intended only for lifting the motor and motor mounted standard ... regrease or change rusted bearings.
change wiring on 1080 motor from ac to dc Google Search
Jul 13, 2017 | AC Cars & Trucks
What type and size capacitor goes on a Baldor 1/3 HP bench grinder
Much would depend on whether it is a start capacitor or a start/run capacitor.
If there is a switch on the end of the rotor operated by centrifugal weights it will be a start capacitor only but if there is no centrifugal switch the capacitor will need to do double-duty and the value could be critical.
Contacting a dealer or the manufacturer would be favourite but a motor specialist might be able to make a recommendation. Guessing isn't really an option and the working voltage of the capacitor is equally important. Most generic capacitors are rated in dc volts and for them to be safe used on ac mains the working voltage must be considerably higher than the rms value of the ac mains. It is best to use only capacitors rated for ac mains.
You will probably find the capacitor as a spare part from a dealer will be prohibitively expensive but once the value has been discovered and if possible the manufacturer, part number and so forth, great savings can be made by sourcing direct from the capacitor manufacturer.
I recently paid less than £5 plus carriage plus VAT for a capacitor the machine manufacturer wanted more then £60 for.
Nov 04, 2015 | Baldor Grinders
Baldor motor wiring diagrams
The diagram is almost always either on a label on the side of the motor or on a label inside the little connection hatch.
Jul 26, 2014 | Baldor 7.5hp 3450RPM 213T Frame ODP...
I have a 1022w bench grinder with a missing capacitor. The baldor catalog doesn't list the part number or spec for the cap. Nor is there a wiring diagram that shows the connections to the cap. Anyone...
OC3012F12SPCYL OIL CAP 12MFD/370V
Thats number the neccesary part for your grinder 12 mfd think about a fitting size of the capacitor and model if you will know for sure here is the information to get .
http://www.baldor.com/brands/baldor-dodge/contact-us/contact
https://www.baldorvip.com/servlet/productInfoPacket/1022W.pdf
Jun 15, 2017 | Baldor 1022w 10" Bench Grinder, 1 Hp,...
I need a wire diagram for a high voltage Baldor motor CAT # 054180 79151 connect to 440VAC it's a 40HP, RPM 3525 , 3PH and it's SPEC# 40F97Z22 please help
Normal wiring for this type of 9 lead motor to 440VAC is
Connect #4 to #7 Connect #5 to #8 Connect #6 to #9
Connect supply phase A to #1 Connect supply phase B to #2 Connect supply phase C to #3
Can you confirm the CAT and SPEC numbers? They do not show up on the Baldor site. If they are correct as listed, you need to call the Baldor help line and find out if this is a special motor.
Aug 05, 2010 | Gb Electrical 100 Amp GE Load Center
I need a multi 110/230 volt wiring diagram for a baldor non reversible motor
http://www.baldor.com/support/literature_load.asp?ManNumber=MN1240
You didn't give a model,here's a manual on their motors and the wiring diagrams,they start on page 2-9.It should get you there,or you can check out their other manuals on the same page .Take care!
Jan 13, 2010 | Target Portable Masonry Saw PS1411S...
Need a wiring schematic for a dual voltage masonry saw motor. it s a baldor motor on a target saw
http://us.husqvarnacp.com/
drop down menu "service"
click "service literature"
click "old target, dimas, partner literature"
enter model number
pdf has basic wiring diagram page 4 or so
Dec 12, 2009 | Target Portable Masonry Saw PS1411S...
Need wiring diagram for Landa T1011. It has a single phase Baldor motor. Need to know capacitor wiring.
info@landa.com
Send a request to the email above, they will email a pdf of the wiring diagram
Sep 03, 2009 | Garden
Heating & Cooling Logo
248 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
