I am running Windows 7, and I am get a DPLAY error when it tries to lode up. Can you give me a solution?
  • 629 Answers
Would help if you can get the exact error, but first thing you can try is to boot in safe mode to remove the existing display driver and download the latest version for your video card or see if Windows will automatically install a native driver
Posted on Nov 15, 2010
How will lode camera in my Pc?Windows 7.
If the drivers are loaded then use a programme like Skype.
Jun 26, 2015 | Computers & Internet
I cant run cricket.exe in my windows 7 ultimate ..im using sony vaio laptop it is giving error like"problem cause stop working " please give me solution as early as possible
try to reinstall the software but first you need to remove it completely. You can use revo uninstaller to completely remove the application and its safe to use. After uninstalling the application, restart the laptop then reinstall cricket. hope this helps
Feb 09, 2013 | Computers & Internet
I am trying to install master of orion II on a windows 7 64 bit operating system and it won't open, because DPLAY.dll cannot be found. I have downloaded the driver, put it in the sys32 folder, the...
First install MOO2 on a computer were it runs and copy the entire micropose directory to the program files (x86) directory.
Then copy the dplayx.dll file from the windows\sysWOW64 directory and renamed it dplay.dll and put it back in the sysWOW64 directory (be sure the dplayx.dll file is still there) or if you have the 32 bit version it should be found in the system32 directory (I am guessing, but you will need a dplay.dll)
Found this great post about getting MOO2 to run in Windows 7, and even with the compatibility enabled it still has a graphics palette problem. The reason is because of Windows explorer, and to fix the problem you need to disable explorer.
I know this can be a little too much for some, there is an easier way.
Simply create a notepad file on your desktop, and paste the following.
(If you have 32-bit version of Windows 7.)
TASKKILL /F /IM "explorer.exe"
cd C:\"Program Files"\Microprose\Orion2
start /w C:\"Program Files"\Microprose\Orion2\Orion95.exe
start C:\Windows\explorer.exe
(Copy and paste below if you have 64-bit)
cd C:\"Program Files (x86)"\Microprose\Orion2
start /w C:\"Program Files (x86)"\Microprose\Orion2\Orion95.exe
Make sure you rename the text file to Moo2.bat, then it will launch Moo2 and disable explorer. Moo2 plays perfectly fine this way, even without any of the compatibility enabled.
The Batch file will also restore your explorer when you exit the game.
Alternatively, you could use DosBox to play the game.
Click Here for instructions
Hope this helps,
G33k
May 11, 2011 | Spectrum Holobyte Masters Of Orion 2 -...
I want to lode windows operating system it not loding
Shut down the computer and reboot, watch for the black screen as soon as it starts up and press F2 to change the boot sequence. Use CD/DVD rom as first in boot order, log into windows and insert the disc, and windows should boot in auto run mode.
Apr 15, 2011 | Computers & Internet
Missing dplay.dll what do i do?
Hello.
Boot your system to Safe Mode (press F8 repeatedly). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, all your updates will roll back to that date.
To access System Restore in Windows 7: Open the Start Menu. Click on All Programs, Accessories, System Tools, and System Restore.
Hope this helps.
Feb 27, 2011 | HP Computers & Internet
When i am installing the game, appears a message with this: "General gile transfer erros." Please check your installation location and try again. Error Numbe: -1 Related File: C:\Program...
To fix this problem download or search your pc for a directx file called Dplay.dll copy an paste in hyperblade main directory, sont install the game use the game .bat file or hyperdex or something like that to play
Aug 26, 2010 | Activision Hyperblade for Windows
New pc core i3 intel orignel mother board DH55TC DDR3 2+2 RAM DVD R/W VIP SMPS PROBLEMI NSTOL WINDOWS 7 &VISTA BOOT CD 1 STEP :- WINDOWS IS LODING FILE STEP :-2 ERROR LODING WINDOWS 1 PLS INSURT CD AND...
Here is a possible fix found at the Microsoft knowledge base .
read and follow the instruction given.
If you are not comfortable with the registry fix then you may have to call the mother board tech support for further instructions but this is found in the Windows 7 environment or operating system.
Article ID: 927392
Apr 01, 2010 | Computers & Internet
Cant install windows 7? i put the cd in and go to auto boot but it gives me a code 5 error.
To resolve Windows 7 Error Code 5, all you need to do is start the installer through a different installer. Either find an old Windows XP boot disk and then direct it over to the Windows 7 installation DVD and run Setup.exe. This should kick off the installer normally and allow you to install the operating system.
Jan 10, 2010 | Asrock K7VM3 Motherboard
How can i give product key to windows vista ultimate from windows 7 operating system . my windows vista OS is not opening, and asking me to give product key. i have tried 3 product keys but it is giving...
u can run only one OS at a time...if u have booted from Win7 u cannot access Vista and viceversa....
For activating vista visit my website and downlaod a patch...how to run is is detailed there
www.sureshayyar.110mb.com
go to download page in there...
all the best
Dec 25, 2009 | Computers & Internet
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
