Question about Sport & Outdoor - Others
What is the proper gas/oil mix ratio, and the spark plug # ?
50 to 1 the plug# is on the old plug
Posted on Nov 15, 2010
I mixed correct oil,gas, but still runs bad,acts like wants to bog out
Plugged air filter or exhaust,maybe?
Fuel restriction?
Nov 12, 2012 | Garden
I have a Craftsman 2-cycle blower/vac and its only 3 years old and have changed out the spark plug and fresh mixed gas and still won't start. I need some help anyone know?
Check age of gas. Cannot be more than 30 days old. Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage. May need to clean or replace carburetor.
Sep 18, 2011 | Craftsman Garden
Ran out of gas put gas in wont start,pulled spark plug and put a little gas in ,it fired but wont stay running,the primmer bulb seems to be not working
Hate to tell you this but if you didn't mix oil with the gas properly (most likely a 40:1 ratio) then the chain saw will seize up and won't work again.
Jun 17, 2011 | Garden
I can't get it started
Check 1. Compression 2. Gas/oil mix 3. Air filter 4. Spark at spark plug. This is just the beginning of troubleshooting a 2 stroke. They develop fuel line problems and carburetor problems and magneto air-gap problems. Critical though is the oil/gas fuel mix that is used. It needs to be fresh and mixed at the correct ratio. Check all these things that you can and post back.
Dec 14, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Hello,I have Mac 110 model#600016c It`s in need of a little TLC The saw is about 25yrs.old and has never hadany work done on it.I need to know what the spark plug gap should be and what the gas/oil mix...
Spark plug gap should be: 0.020" and the fuel to oil ratio is 40:1. Be sure to use fresh fuel and a modern synthetic saw oil available at home centers, hardware stores, and saw dealers. Mix well in it's own container and be sure to shake the container thoroughly each time just before filling the tank to prevent oil starvation. Hope this helps!
Dec 01, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
I do not know the proper gas-oil mix for a sears craftsman backpack 2 cycle leaf blower; i am using 1 gallon of gas; how much of the oil do i put into it? thanks
Craftsman engines typicallty run a 40:1 fuel ratio mix. That is 3.2oz./gal. I suggest synthetic oil It helps the engine to run cooler with less friction/stress. If you make the mix a little richer; say 3.5 to 4 oz./gall. it will assist the engine if it is tuned to the "lean" side (that is with more air/less fuel). The extra oil will not hurt or foul your spark plug.
Nov 21, 2010 | Garden
Homelite ut 10695 spark plug gap, gas oil ratio?
Gap the plug at 0.020", and the fuel to oil ratio is 50:1. Be sure to use a modern synthetic saw oil, fresh fuel, and mix in it's own container (don't make up more than a gallon at a time unless your business is sawing). Be sure to shake the container thoroughly each time just before adding fuel mix to the tank to prevent oil starvation. Hope this helps!
Nov 04, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Filled with gas/oil mix and won't start. Was running fine 30mins before. No issues at that time.
Remove the spark plug and test for snappy blue spark. If ok, pour a little fuel mix into the plug hole and try for start. If it pops several times, check the fuel filter, air cleaner, and muffler for plugging. Check the condition of the fuel lines and the primer bulb. Did you make sure that you used proper mixing of the fuel/oil? Be sure to use a modern synthetic saw oil with fresh fuel at the required ratio and use it's own can for mixing/storage. Shake the can thoroughly just before filling the saw. Hope this helps!
Sep 05, 2010 | Garden
My weedeater brand trimmer won't start
I believe you have the wrong GAS AND OIL MIXTURE. MOST WEED EATERS are a Ration of 90:1 or even less 75:1 For WEEDEATER I would use a 50:1 or if you choose 32:1 should work. Use a good 2-stroke oil. DO NOT USE ANY OTHER OIL> You see the more oil you use the harder it is to start. Don't forget to Pump the fuel Bulb on the side before trying to start it.About 3 x should do it. GOOD LUCK and it is and does effect me when their is death by a LOVED ONE. My prayers are with you! From Mddoc13 ( BOB)
Aug 28, 2009 | Craftsman 25cc Gas Line Trimmer
Sport & Outdoor - Others Logo
46 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
