Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I have a craftsman garage door opener 41AC150-1M The problem is I think the antenna or sensitivity is too low. I can open with my remote only if it's next to the opener. If I tried to open with the remote or wireless keypad while the garage door is close, it would fail to open. I did change the the battery for the wireless keypad and it made no difference. I do not see an antenna sticking out of the opener assy?
    President:
  • 3,197 Answers
Limited range of your remote controls could be related to radio frequency interference that comes from something in your home or in the surrounding environment. Certain electrical devices can radiate interference; this could be almost anything that is plugged into an electrical outlet.
Please keep in mind that the device can be brand new, or can be an item that has been in use for quite a while. Also, the item may continue to function properly as far as you are able to tell. The only problem with the item may be that it has started to broadcast the interference, with no other symptoms noted.
Some devices are more likely to generate interference than others. This includes TV cable, cable amplifiers, surge protectors, fluorescent lights, battery charging devices (power tools, golf carts, etc.), anything that utilizes a timer (sprinkler systems, lights, alarm systems, etc.), and a myriad of others. If the problem seems sporadic, we can safely assume that the device responsible for the interference is only being operated during these times. Again, please keep in mind that the age of the device does not determine if it is capable of broadcasting unwanted interference. Any electrical device can be the source of the problem.
Power Down test:
To isolate potential sources of interference, turn the circuit breaker off to the garage and plug the garage door opener into an extension cord from another room. If the range improves, then the interference is coming from a device in the garage. If no improvement is seen follow the same procedure, this time turning off the circuit breakers to your home, with the exception of the garage and test the remote controls. If improvement is noted, turn the circuit breakers back on, one by one, until the range problem resurfaces. This will allow you to narrow down what room the problem device is in. You will have to go from there to isolate it further, by unplugging and re-plugging the items in that room.
If you are unable to determine any source of interference, then the receiver logic board in the overhead unit will need to be replaced.
Posted on Nov 15, 2010
GARAGE DOOR OPENER REMOTE ONLY WORKS IN GARAGE WILL NOT WORK IN DRIVE WAY
1st, try replacing the battery in the remote. If that doesn't work, you will need to replace the logic board on the opener, which is typical in the craftsman openers.
Oct 02, 2014 | Sears Craftsman LiftMaster Chamberlain...
We are having trouble opening our garage door with the car remotes. The remote inside the garage is working fine. Can you help us out?
Make sure you have good batteries in the remotes, also make sure the antenna on the garage door opener is hanging down,intact and not blocked by anything.
Mar 01, 2011 | Sears Craftsman LiftMaster Chamberlain...
My Craftsman remote won't close my garage door
If the remote opens and closes while inside the garage but not outside , there are a few things it could be. Assuming it was working fine before..
1. weak battery in remote.
2. remote itself could be bad. (unless you have more than 1 remote acting the same)
3. Logic board in opener is going bad causing limited range.Is the wire that hangs down from the opener straightened out? That is your remote antenna.Some people have coiled or even cut it off..reducing range.
4. Less likely but this can happen- interference from another electronic device, wireless routers, cell phone, new appliances etc.. can reduce remote range. Any new electronics recently purchased?
Jan 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
My craftsman remote keypad and remote car opener don't work in the morning but work at night. I changed the batteries on both. Did I do something wrong. Ron
You didn't do anything wrong. Electronic components sometime become sensitive to temperature. It may require a new logic board.
Oct 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Older model 1/3 hp craftsman goes up not down with remote
Your door sensors are either bad or need simply to be aligned. They must be pointed at one another to work properly. Each of them has a small light that will be lit when they are pointed correctly.
Sep 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Mysrerious ups and downs
It sounds like the signal coming from your car remote is quite a bit stronger than the signal from the original remots. Many garage door openers have a sensitivity dial. check your owner's manual as you may have one also. Get back and let me know as there are other things to try
May 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
CHAMBERLAIN WILL NOT RESPOND TO REMOTES FROM STREET.
Sounds like "cross talk" interfence from the other operator. You can get a plugin external reciever that should work with your current remotes. Try to get as much distance as you can between the working operator and the new reciever.
Jan 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remotes don't work
I recently had Verizon FIOS equipment installed in my garage (for phone, internet and TV), which is plugged into a 110 volt electrical outlet. Thinking this equipment might be causing some RF interference, I unplugged the FIOS equipment, and both garage door openers immediately worked perfectly again!
After reconnecting the FIOS equipment, I then plugged the garage door opener into a different electrical outlet approximately 15 ft. away via an extension cord, and the openers continue to work fine. Fingers crossed, I hope the issue is permanently resolved.
Aug 03, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
991 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
