When spinning it makes loud noise and vibrates quite alot, what could be causing this problem? thanks
  • 12,061 Answers
This is usually caused by an out of balance Tub, or bad bearings or a broken mount.or the balance weight has come off.
Sometimes it can be a simple unbalanced load, distribute the clothes more evenly in the tub.
You need to strip down the unit to examine it and tell.
Obtain a service manual for your exact make and model. Work through the troubleshooting steps to isolate and repair your unit.
Posted on Nov 15, 2010
What causes our front loading washer to make exceeding loud noise when it enters a spin?
Sounds like a bearing seal is going. The seal has ruptured and grease of seeping out. The loud noise is the bearings rubbing against each other without adequate grease to reduce the friction. Failure will come soon if it is not fixed. The vibration is coming from the friction and possibly damaged ball bearings .
Mar 11, 2015 | Washing Machines
What is cause of loud vibration noise
In most cases, vibration sounds come from which ever helps the drum to spin with no resistance, In most cases those would be drum support wheels or bearings depending on the model.
In some rare cases, blower or belt pulley could also cause similar symptoms.
Feb 11, 2015 | Dryers
Wash machine won't spin all the time and makes a loud banging noise.
Check to make sure that your clothes are not piled to one side causing the load to be off-balance. If that does'nt fix it then, It may be that your machine has a balance stabilizer on it that has worked its way loose or even off.
Jun 11, 2012 | Frigidaire Affinity ATF7000E Front Load...
Maytag Neptune - MAH5500BWW makes loud, loud noise during spin cycle. What parts are necessary to repair the unit? I assume there are bearings and seals needed. Thank you.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
May 26, 2011 | Maytag Neptune MAH5500B Front Load Washer
My unit outside is working fine but it is making a lot of noise. All my neighbors are telling me that this is not normal. What can I do to reduce the noise. It is spinning fine but it makes loud noise.
Is the condenser coils clean..... If not take a hose and wash the condenser coils But make sure you shut the Main power off to it. Has the unit been charged with Freon lately??? If so they may have gotten it overcharged which will cause High head pressure and make the compressor noisy..... Or is it out of level and not setting on a stable surface. causing a vibration noise. You can put rubber pads under the AC if it is a vibration noise...... Also the Compressor may be going out..... It is hard to tell with out hearing it first hand....Hope this helps If you can't get it to quite down I would setup a Service Call to have them Service the AC and that you are having a loud noise coming from the unit....
May 05, 2011 | Goodman CLT48AER48 Air Conditioner
My xbox 360 is making clicking noises, vibrates alot, and is extreamly loude while running, i think its the fan in it but im not sure, so what should i do?
Hi Charles
There are several reasons your console is noise , First remove your game and
listen and see if the noise is reduced also the vibration should stop too.
I have seen or heard rather this before . The cause was a the drive spindle
hub some how got skew so the disk wobbled as it was spinning.
The fix was simply to replace the hub/spindel motor .
The rattling sound may be from the tilt switch or pieces of plastic
bouncing around . you will have to open your console to remove the
the small chunks of plastic + blowing it out will help cooling also.
The fan should not make that much noise . If it seems to be loud
then you may need to replace the heat sink compound on the G.P.U.
and the C.P.U.
if you have any questions feel free to ask.
Rob
Mar 31, 2011 | Microsoft Xbox 360 Console
Loud noise on spin cycle
most common cause for this is pump bearing on water pump. remove belt and attempt to turn pump by hand. if it grinds get a new pump.
Oct 08, 2009 | Maytag PAV2300 Top Load Washer
Hotpoint VBSR2080WOWW washing machine vibrates with loud noise
hi,
this is a generic problem with top-loading washing machines. when the distribution of load is not uniform, it gives sound when spinning. if it produces noise even after equal distribution of clothes, the problem lies in the suspension. this is not a major fault, and can be put up with, rather than spending dollars on fixing it. this will in no way cause any special wear and tear for the machine.
cheers
Jul 22, 2009 | Hotpoint VBSR3100D Top Load Washer
GE washer (wjsr4160gww) makes loud noise during spin cycle
Remove the front panel and you will see two metal guides attached to the front of the frame. One of them will probably be bent and the transmission assembly will have jumped over one or the other of the guides. You need to manually pull it back to center then straighten the bent guide. May have been caused by load being out of balance or machine not properly leveled. Good luck.
Feb 18, 2009 | Washing Machines
Loud noise on Spin Cycle
CENTER SUPPORT BEARING IS BAD. VERY COSTLY IF NOT UNDER WARRANTY USE FOR BOAT ANCHOR. GOD KNOWS I HATE TELLING PEOPLE THAT. SORRY, FXIT
Oct 11, 2007 | Admiral AW22 Top Load Washer
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
